| Alastair |
 Alastair Borekit Bruiser
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 13:55 - 19 Dec 2005 Post subject: |
Depends. Probably the same as heat siezing as there is often a fair bit of oil floating about in the bottom end which would keep the mains and big-ends lubed for longer than it takes to dry sieze the bore.
Only way to find out is pull it apart and have a look.
At a minimum it will need a rebore/plate and new piston/rings (may as well replace the small ends while you are at it).
At worst the mains and big end will be gubbed which would mean a service exchange crank, new bearings, conrod kit, piston and rebore. Might still be cheaper than a new engine though, especially if you fit the parts yourself. The only real biggy would be the crank...and the barrel if it is nikosil coated. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dischord |
 Dischord World Chat Champion
 Posted: 20:03 - 19 Dec 2005 Post subject: |
try bump startin it first, it might unseize and ride away, it happened to me twice! but they free'd up within 2minutes of seizing, so if you left it seized chances are it will need a rebore! ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| DM |
 DM Scooby Slapper
 Posted: 00:52 - 20 Dec 2005 Post subject: |
I seized a 50cc Runner's piston around 10-12 times (out of oil) and it still ran fine. Of course, opening it later revealed a sickeningly scored piston/cylinder, yet the compression stayed at a very acceptable level so I never told my friend when I gave it back . |
| Alastair |
| stinkwheel |
 Posted: 16:51 - 20 Dec 2005 Post subject: |
Probably safer to split it. Although I have flushed the crankcases in 2-strokes before. What we did with my mates H100 that was in a river for a few days before we bought it (cheap) was to flush all the silt out with diesel.
Just repeatedly filled the crankcase with diesel, swooshed it about, spun the crank in it then turned the whole engine upside down and emptied it out. When we were happy it was clean, we flushed it again with 2-stroke pre-mixed petrol to make sure the bearings had plenty of oil then banged it back together again. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alastair |
| Kickstart |
 Posted: 11:54 - 21 Dec 2005 Post subject: |
That doesn't sound like it has run out of 2 squeak oil. Not certain about the TDR but it is rare that road bike 2 stroke oil tanks take less thanb a litre in size.
It is possible to get air in the 2 stroke oil line (leave the bike running on its side for a while might do it, but likely to cause other problems first), but not common.
If it has destroyed the piston in style as you say then it is possible that it has cold seized (were you thrashing it when cold?) but most likely it is just bad luck as to when it has failed.
| John C |
 John C World Chat Champion
| Alastair |
| lilredmachine |
 lilredmachine World Chat Champion
 Posted: 15:42 - 21 Dec 2005 Post subject: |
nice one
certainly does not look like a lack of oil seize TBH. ____________________ Bikes: too many, too much for one man to maintain anyway. |
| John C |
 Posted: 16:05 - 21 Dec 2005 Post subject: |
ace
Looks like you've been feeding it ball bearings.  |
| Kickstart |
| stinkwheel |
 Posted: 18:41 - 21 Dec 2005 Post subject: |
Guy up the road from me has a Z650 piston with a valve embedded in the piston crown so firmly you can't pull it out.
I have a Jawa 350 piston somewhere with the skirt ripped off, gudgeon pin ripped out and three needle rollers from the opposite side small end embedded in the crown.
EDIT: looking at that picture, it looks like the piston crown is 'dinged over' at one point? Has it hit the head? If it has, this would suggest one of the main bearings or big end has let go.
It will need pulling apart and the crank spinning up with a dial guage, if there was enough force to rip the gudgeon pin out through the bottom of the piston, there was enough force to make a bent crank a possability. The conrod is almost certainly gubbed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 22:46 - 21 Dec 2005 Post subject: |
I seized my old TZR250 pretty badly before.... some little pikey on my estate had cut the oil line... no amateur really but it still happened... rode fo about 20 miles at about 25 MPH cos it wudnt pull.. then it died n pissed petrol n coolant everywhere....
the left hand piston had gone all the way throough on the top and the rings had melted into the barrel... and the right hand one looked like a rat had been in the barrel chewing at it....
end result pair of new barrels, pistons, n a crank rebuild as it done the main bearings too etc... very messy  |
| Alastair |
| Knowlsey |
 Knowlsey Scooby Slapper
| faith183uk |
 faith183uk Nitrous Nuisance
| Alastair |
| Alastair |
 Posted: 14:14 - 24 Jan 2006 Post subject: |
I'm still in exactly the same situation and but had decided to get it rebuilt. I have been let down by a mechanic twice that was going to come and pick up the bike though. If he doesn't want my money, fine, someone else will get it.
Have had time today to take the engine out but I've spotted something that to my untrained eye looks pretty terminal. See the bit inside the red circle on the attched pic, that shouldn't be bent should it!?!
Does it look like a replacement engine is the only way to go now? |
| Gazdaman |
 Gazdaman I did a trackday!!!
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| ancientd |
 ancientd Renault 5 Driver
| Alastair |
 Posted: 21:11 - 24 Jan 2006 Post subject: |
Wasn't going to try and use that engine without a full rebuild don't worry. If it is fixable it'll be a full strip job
Air filter is still in place and the reeds actually still look pretty decent (to my eye and it's the first time I've ever seen reeds), so it probably is the big end but i wont know till I split it and I don't know if I'd ever get it back together! |
The last post was made 20 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
