Jump starting a bike from car/other bike
Guest
PostPosted: 10:56 - 01 Jan 2006    Post subject: Jump starting a bike from car/other bike Reply with quote
from this site:- https://www.batterycouncil.org/jumpstart.html
https://www.batterycouncil.org/images/jump.gif
1. Connect positive (+) booster cable to positive (+) terminal of discharged battery.
2. Connect other end of positive (+) cable to positive (+) terminal of assisting battery.
3. Connect negative (-) cable to negative (-) terminal of assisting battery.
4. MAKE FINAL CONNECTION OF NEGATIVE (-) CABLE TO ENGINE BLOCK OF STALLED VEHICLE, AWAY FROM BATTERY.
5. Start vehicle and remove cables in REVERSE order of connections.
The reason you connect to the dead battery first is to avoid sparks. If you've flattened your battery trying to start it then it'll be churning out a lot of Hydrogen.
If you connect the jump lead to the good battery and then to your flat battery you've got a voltage difference - 12 volts on the good 'un, 9 volts or less on your flat one.
Where you've got a voltage difference, you'll get a spark.
Add a spark to hydrogen and ...... Thumbs Down Embarassed
Is this worth making a 'sticky'?
Whosthedaddy
PostPosted: 10:59 - 01 Jan 2006    Post subject: Reply with quote
Very Happy very handy
Finglonga
PostPosted: 11:00 - 01 Jan 2006    Post subject: Reply with quote
But the sparks are pretty. Twisted Evil
Andy Sez....
F.Y.Y.F.F.
Guest
PostPosted: 11:15 - 01 Jan 2006    Post subject: Reply with quote
So is my face, and I want to keep it that way Wink
Bezzer
PostPosted: 11:56 - 01 Jan 2006    Post subject: Reply with quote
Should add if you're starting a bike from a car then DON'T have the car engine running. Car alternator is normally much higher output and if you get a power spike then you can cook your bike electrics.
PostPosted: 13:04 - 01 Jan 2006    Post subject: Reply with quote
The ampage should not really matter. Amps are drawn through by the consuming item, not pushed through by the supplying item.
kwacky
PostPosted: 13:05 - 01 Jan 2006    Post subject: Reply with quote
I've always done mine via the wife's car with the engine running. Never had any problems [yet!]
Bezzer
PostPosted: 16:14 - 01 Jan 2006    Post subject: Reply with quote
I'm not on about the bike drawing the current, I'm on about the car pushing voltage into the bikes electrical system, you're bypassing the bike's reg/rec putting the car's output straight to the bikes battery terminals and therefore the whole electrical system via the jump leads any spike could affect electrical items.
The original thread is from https://www.batterycouncil.org/jumpstart.html as stated, but if you read the whole page is says vehicle ignition OFF nowhere does it say start the donor vehicle. Seen a few references to damage caused by it, here's one off VD, blew his CDI, https://www.visordown.com/forums/showthread.php?t=218454&highlight=car+jump+start can't be arsed to search for the others I've seen with similar.
PostPosted: 16:26 - 01 Jan 2006    Post subject: Reply with quote
Voltage is the same on the car and the bike. Both a nominal 12V going up to ~14V when charging heavily.
Only exception would be the few vehicles that use higher voltage electrical systems (eg, buses with 24V electrics), or against a 6V bike. In these cases you would fry the electrics irrespective of whether the engine is running or not.
Most likely way of causing damage is by connecting the -'ve wires first and then touching the +'ve wire to the frame while connecting it.
Guest
PostPosted: 17:02 - 01 Jan 2006    Post subject: Reply with quote
Bezzer wrote:
I'm on about the car pushing voltage into the bikes electrical system, you're bypassing the bike's reg/rec putting the car's output straight to the bikes battery terminals.
As Keith says, all you're pushing out of the car battery is 14 ish volts (if you rev it) - the same as the bike's system would be giving if the engine was revving. If you haven't got somebody in the car flooring the pedal, as soon as you start to crank the bike over the car's voltage is going to drop anyway.
sickpup
Old Timer
PostPosted: 18:31 - 01 Jan 2006    Post subject: Reply with quote
Now I agree with the above but remember a few bikes use a lower voltage CDI. The ER 5 is one, there is a resistor in the ignition which likes to blow and if it does it can take out the CDI but this can happen if the reg/rec fails. A lot of pattern ignitions don't have the resistor in them.
I've heard several times that you can blow the CDI on a bike if you jump start it but still can't work out how.
MAYBE if the battery was very dead it would provide enough resistance to pull a lot of amps but this wouldn't go further than the battery BUT if you managed to start the bike and then disconnected the car battery while reving the bike hard the resitance of the bikes dead battery could I suppose raise the amps high enough to burn out first the reg/rec then the CDI but I really doubt it.
I think most of these things are down to twat mechanics or other problems that haven't been noticed.
FreshAL
Sir Crashalot
PostPosted: 16:02 - 02 Feb 2006    Post subject: Reply with quote
Help!
My SV battery is flat (i left the parking lights on, whata stupid idea they are)
What's the verdict? My mate tells me I'll fry the ignition if I jump it from a car?
LustyLew
PostPosted: 17:22 - 02 Feb 2006    Post subject: Reply with quote
Your mate is talking poop. I've jump started my bike from my mates 4x$ with the engine running.
Just drawing current from the batter wasn't enough, my bike battery was as flat as a pancake!
PostPosted: 18:15 - 02 Feb 2006    Post subject: Reply with quote
Same here, done it loads of times without problems.
What quite possibly will cause a problem is connecting the leads up carelessly and touching the positive to the frame with the negative already connected (one good reason to connect the positive first and the negative 2nd).
Superlight
PostPosted: 15:49 - 03 Feb 2006    Post subject: Reply with quote
Agreed.
The one to watch is jumping car from car with the engine running. If the 'donor' battery is a bit weak, the alternator tries to kick out enough to power the starter, and that's not good Thumbs Down It is possible to fry the alternator of the donor.
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
The last post was made 20 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 89.98 Kb
