| Guest |
 Guest Brolly Dolly
 Posted: 10:56 - 01 Jan 2006 Post subject: Jump starting a bike from car/other bike |
from this site:- https://www.batterycouncil.org/jumpstart.html
https://www.batterycouncil.org/images/jump.gif
1. Connect positive (+) booster cable to positive (+) terminal of discharged battery.
2. Connect other end of positive (+) cable to positive (+) terminal of assisting battery.
3. Connect negative (-) cable to negative (-) terminal of assisting battery.
4. MAKE FINAL CONNECTION OF NEGATIVE (-) CABLE TO ENGINE BLOCK OF STALLED VEHICLE, AWAY FROM BATTERY.
5. Start vehicle and remove cables in REVERSE order of connections.
The reason you connect to the dead battery first is to avoid sparks. If you've flattened your battery trying to start it then it'll be churning out a lot of Hydrogen.
If you connect the jump lead to the good battery and then to your flat battery you've got a voltage difference - 12 volts on the good 'un, 9 volts or less on your flat one.
Where you've got a voltage difference, you'll get a spark.
Add a spark to hydrogen and ......
Is this worth making a 'sticky'? |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 10:59 - 01 Jan 2006 Post subject: |
very handy |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 11:00 - 01 Jan 2006 Post subject: |
But the sparks are pretty.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| Guest |
 Guest Brolly Dolly
| Bezzer |
 Bezzer World Chat Champion
| Kickstart |
 Kickstart The Oracle
| kwacky |
 kwacky Nitrous Nuisance
| Bezzer |
| Kickstart |
 Posted: 16:26 - 01 Jan 2006 Post subject: |
Voltage is the same on the car and the bike. Both a nominal 12V going up to ~14V when charging heavily.
Only exception would be the few vehicles that use higher voltage electrical systems (eg, buses with 24V electrics), or against a 6V bike. In these cases you would fry the electrics irrespective of whether the engine is running or not.
Most likely way of causing damage is by connecting the -'ve wires first and then touching the +'ve wire to the frame while connecting it.
| Guest |
 Guest Brolly Dolly
| sickpup |
 sickpup Old Timer
| FreshAL |
 FreshAL Sir Crashalot
| LustyLew |
 LustyLew World Chat Champion
| Kickstart |
| Superlight |
 Superlight Nitrous Nuisance
 Posted: 15:49 - 03 Feb 2006 Post subject: |
Agreed.
The one to watch is jumping car from car with the engine running. If the 'donor' battery is a bit weak, the alternator tries to kick out enough to power the starter, and that's not good It is possible to fry the alternator of the donor. ____________________ You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape. |
The last post was made 20 years, 194 days ago. Instead of replying here, would creating a new thread be more useful? |
