URGENT - Help a forum member (yokogeri)
White Noise
Mr Dudwee
PostPosted: 23:12 - 08 Jan 2006    Post subject: URGENT - Help a forum member (yokogeri) Reply with quote
Hi all
need urgent help for yokogeri (scott) he is stuck in southampton, on his way back from his sheep shagging trip in wales.
he has ridden back from wales fine and gone to see a mate in southampton, he has just left his mates place and the the bike has died at a junction, just spoken to him on the phone, it seems that the bike is just ticking over when he has pressed the starter and doesn't want to catch. tried with choke fully on and off and the bike doesn't want to play ball and start. it sounds like the bike has either a electrical or fuel problem. yes he does have fuel in the bike, but can't figure out what could have caused it so suddenly as the bike was runing fine for the rest of his trip. the only think it maybe due to is the fact its very wet but doult this myself. so we are trying to figure out whats going on and things to try to get him home. battery getting flatter as we try so not a good situation
can you help?
plus does anyone have the breakdown number for motorcycle direct?
WN
Quote Me Happy
PostPosted: 23:13 - 08 Jan 2006    Post subject: Reply with quote
Probably a silly question but has he tried bump starting it?
White Noise
Mr Dudwee
PostPosted: 23:16 - 08 Jan 2006    Post subject: Reply with quote
aye he has with no joy. he is in the process of walking it back to his mates to get him to push him on it.
but his mate has no battery charge at his! Confused
WN
riichy
PostPosted: 23:21 - 08 Jan 2006    Post subject: Reply with quote
try these 08451 285 285.
(might not work though Neutral ) Thumbs Up
.......... PLOD ............ zx636 2004
Davo
Davo To The Rescue!
Just spoken to scott, probably going to go and get him & his bike.
veeeffarr
PostPosted: 23:22 - 08 Jan 2006    Post subject: Reply with quote
I've had my bike cut out on my in the pissing wet, think it was water in the fuel... Kicked it over a few times and fired up fine again.
Quote Me Happy
Clapping Angelic
PostPosted: 23:23 - 08 Jan 2006    Post subject: Reply with quote
Check the fuel pump is running. Also check the side stand switch (although I would expect that to stop it cranking over on the starter motor as well).
White Noise
Mr Dudwee
WN
White Noise
Mr Dudwee
PostPosted: 23:24 - 08 Jan 2006    Post subject: Reply with quote
how?
WN
DucatiEVO
PostPosted: 23:25 - 08 Jan 2006    Post subject: Reply with quote
What bike does he have, is it carbs/injection etc?
Has/can he:
Checked fuses
hear the fuel pump
is there fuel at the carb
does he have a spark
checked sidestand bypass (if fitted)
checked kill switch (need multimeter)
aKa: Ducky
Davo
Davo To The Rescue!
White Noise wrote:
how?
WN
Listen for it Laughing
DucatiEVO
PostPosted: 23:27 - 08 Jan 2006    Post subject: Reply with quote
Also, does it have an alarm, perhaps the immobilser has activated.
aKa: Ducky
White Noise
Mr Dudwee
PostPosted: 23:29 - 08 Jan 2006    Post subject: Reply with quote
i mean a particular sound, fool! Laughing
i.e clicking on yamahas when ignition key is turned
WN
Silver
PostPosted: 23:30 - 08 Jan 2006    Post subject: Reply with quote
It's a carb R6.
White Noise
Mr Dudwee
PostPosted: 23:31 - 08 Jan 2006    Post subject: Reply with quote
would of thought that would not let the starter motor kick in, aswell as the kickstand switch.
BTW bikes a carbed R6
WN
PostPosted: 23:32 - 08 Jan 2006    Post subject: Reply with quote
Yamaha fuel pumps are normally pulse pumps. They tick loudly. However might be better to just hold it as you should feel it.
Think the bikes should trigger the pump for a short while when you turn the ignition on (about 5 seconds I think, but they only work up to a certain pressure so when the carbs are full they cut off).
Numerous other things it can be, but pump is one thing that can be traced by the side of the road. Had odd problems with the Bimota fuel pump once.
DucatiEVO
PostPosted: 23:44 - 08 Jan 2006    Post subject: Reply with quote
Ok, I'd check for a spark (does it sound like it's trying to fire, or just turning over)?
Then check for fuel from the pump and go from there. Thumbs Up
aKa: Ducky
White Noise
Mr Dudwee
PostPosted: 23:48 - 08 Jan 2006    Post subject: Reply with quote
from what i can hear on the phone sounds like it was just turning over, the fuel pump is working (ticking being heard on ignition on). so could be a lack of spark, though quite hard to tell as the bikes got its fairing on
WN
Davo
Davo To The Rescue!
PostPosted: 23:58 - 08 Jan 2006    Post subject: Reply with quote
The spark plugs are a night mare to get to on the R6, requires removing the tank, airbox etc..
jonnay
PostPosted: 00:03 - 09 Jan 2006    Post subject: Reply with quote
Got an alarm? I've heard of the rain getting into cheapish ones causing the alarm to cut out, thus causing the whole bike to fail Shocked
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
PostPosted: 00:04 - 09 Jan 2006    Post subject: Reply with quote
If he has pressed the kill switch he is gonna get a slap.
Otherwise I'd try WD40-ing everything you can get at.
White Noise
Mr Dudwee
PostPosted: 00:09 - 09 Jan 2006    Post subject: Reply with quote
as said before if it was the alarm fecking everything up i would expect the starter motor not to engage
WN
White Noise
Mr Dudwee
PostPosted: 00:10 - 09 Jan 2006    Post subject: Reply with quote
your telling me! Laughing
but i have asked him that and he says no!
WN
The View Askew
PostPosted: 00:18 - 09 Jan 2006    Post subject: Reply with quote
This reminds me of a time i was at the BP once buying some engine oil. and this bloke on an xr650 appears, his bike covered in mud up 2 the fuel tank. i could just about read the bike model. he proceeded to the jet wash, and theres me thinking, sureley not, surely he wouldnt. and he did. went and got his token, then used the foam mop all over the bike, then blasted it with the jet. now i thought here comes trouble this will not start. lol, but it never got that far, he uses the tissues by the pumps to dry his seat off. and then he goes to reach for his keys. oh dear. it seems he had left them in the barrels, and the combination of being scrubbed and blasted, had knocked them into the metal caged resovoir underneath.
i had left before he retrieved them.
I think if anything THAT deserves a slap around the face.
The last post was made 20 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 132.57 Kb
