Daytime MOT
Gazdaman
I did a trackday!!!
PostPosted: 15:26 - 09 Jan 2006    Post subject: Daytime MOT Reply with quote
Info seems quite scarce.
Since I'm race prepping the MZ, the engine will still be standard, and I don't have a trailer, I'm going to have to keep it semi road legal.
Anyone care to speculate on what I'll need?
Chain guard? Mudguard? Brake light, horn, no indicators, no headlight.
I know Korn's R6 was on a daytime MOT, Would I need a light to illuminate the number plate?
I've got a website with the exact MOT criteria for a standard MOT, but not for daytime.
Gaz
mrchips
PostPosted: 15:40 - 09 Jan 2006    Post subject: Reply with quote
I'd imagine you'd need a horn and a brakelight.
Northern Irish? www.nibikers.com
yzf750r
PostPosted: 16:16 - 09 Jan 2006    Post subject: Reply with quote
and a chain guard for sure! Thumbs Up
PostPosted: 16:26 - 09 Jan 2006    Post subject: Reply with quote
Daylight MOT has the same requirements as a normal MOT, expect it's for use in daylight only so you don't need any lights apart from a brake light. Rest of it is the same or at least it was when I got one.
PostPosted: 16:27 - 09 Jan 2006    Post subject: Reply with quote
It is rather vague, there is not really such a thing as a 'daytime' MOT. There are certain circumstances under which you can be exempted from some of the requirements.
It also contains a lot of 'in the oppinion of the tester' type stuff so I would suggest getting in with a backstreet mtoorcycle garage that does MOTs, look for customised/old/bodged bikes outside it as these guys:
a) Actually know the rules rather than failing something because they haven't seen it before and it isn't Japanese and less than five years old.
b) Are more likely to let a grey area slip past as they usually appreciate what you are trying to do.
How old is the bike? This can have a bearing on things.
With regard to headlamps and position lamps:
This inspection applies to: all machines, except those which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are
. only used during daylight hours, and
. not used at times of seriously reduced visibility
If this situation occurs the vehicle presenter should be issued with an advisory notice recording the above and it should also be recorded on the carbon copy of the VT20.
Stop lamps:
This inspection applies to; all machines except those which have neither front nor rear position lamps, or has such lamps permanently disconnected, painted over or masked that are (see 1.1).
Exemptions
For this test if a stop lamp is fitted, it must meet the requirements of this inspection, but need not be fitted to a machine which:
a. cannot exceed 25mph, or
b. was first used before 1 January I936.or
c. was first used before 1 April 1986 and which has an engine capacity of less than 50cc.
Indicators:
If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
You need a red reflector at the back of the bike.
You need a horn, but if it was made before 1st August 1973 you can use a squeezy bulb horn Cool
https://www.motuk.com/bike/6-1.htm
EDIT: You don't have to have a mudguard if you don't want to UNLESS the front mudguard acts as a fork brace in which case it must be securely fitted or a fork brace fitted in its place.
You need a chain guard of some sort, but some of the ones fitted to custom bikes are so minimal it takes the piss (I would have thought you'd need one anyway to get through scrutineering).
Gazdaman
I did a trackday!!!
PostPosted: 16:39 - 09 Jan 2006    Post subject: Reply with quote
You need a chain guard at the entry and exit points of the sprocket for scrutineering. I'll just keep the MZ chain enclosure.
Ok, so I can safely junk the headlight, and change the rear light for just a brake light.
The bike is a 1990, so none of the age exemptions help too much. The horn thing is annoying, because it means I'll probably have to keep the switchgear.
I would cut off the mudguard, but then I might have problems fitting the numberplate and brake light. But I'm sure I can get inventive with that one.
Any more input? I appreciate that Stinkwheel, I'll go and pester some MOT stations in the week.
Gaz
PostPosted: 16:40 - 09 Jan 2006    Post subject: Reply with quote
Bit dubious as to whether, legally, there really is such a thing as a daytime MOT. Never yet seem anything official to support the existance of one.
Further bit from the website Stinkwheeel quotes from.
MOT Manual wrote:
A motor bicycle first used before 1 January 1931 does not need a headlamp.
A motor bicycle is only required to have a dipped-beam headlamp (but may also have a main beam) if it:
. was first used on or after 1st May 1995 and cannot exceed 30 mph / 50 kph with an engine capacity not exceeding 50cc. or
. was first used before 1 January 1972 and with an engine capacity of less than
50cc.
. any machine having a maximum speed not exceeding 50km/h/30mph
From that it reads that a bike first registered after 01/01/1931 does need a headlight, with a few exemptions to allow mopeds to only have a dipped beam headlight in certain circumstances.
Gazdaman
I did a trackday!!!
PostPosted: 16:46 - 09 Jan 2006    Post subject: Reply with quote
Surely that contradicts what Stinkwheel pasted?
And I guess I can only get away without indicators if I can convince the tester that it's an off-road machine designed to carry only me. Which is true.
I now realise this isn't a 'daytime MOT' as such, it's just a normal MOT exploiting a few loopholes.
Gaz
PostPosted: 16:52 - 09 Jan 2006    Post subject: Reply with quote
Not really, just fully quoting it. I would say it is meant to be read that on a very old machine a headlight is not required, but on a newer machine (ie, 1930ish or newer) a headlight is mandatory.
I suspect that a "daytime MOT" is really an MOT using loopholes in the MOT rules that do not really exist but which selective reading can give the impression that they do exist.
Gazdaman
I did a trackday!!!
PostPosted: 16:53 - 09 Jan 2006    Post subject: Reply with quote
keeping the headlight isn't the end of the world, but it's annoying.
I need to find more people that have actually done this!
Maybe it's time to go and annoy visordown.
Gaz
PostPosted: 16:58 - 09 Jan 2006    Post subject: Reply with quote
To be honest I think you are slightly mad to have a bike to ride to a race then aim to ride home again. You will wear out decent race tyres more quickly, stand a good chance of blowing the engine or crashing and have to ride home at the end of the races rather worn out.
Gazdaman
I did a trackday!!!
PostPosted: 17:05 - 09 Jan 2006    Post subject: Reply with quote
I completely agree Keith. It's not a long term arrangement.
I'll be keeping my road tyres, which are a bit too sticky for long range motorways, but not quite sticky enough for racing, but will be perfect for some nutty trackdays.
The engine is standard, so chances of blowing up are minimal, although obviously not impossible.
The main aim of this is only to get me as far as Llandow, which should be about an hour? from Bristol. Then after that, hopefully a trailer will be on the cards.
Gaz
DucatiEVO
PostPosted: 17:26 - 09 Jan 2006    Post subject: Reply with quote
If you have switchgear for lights etc, then they must be fitted and working.
aKa: Ducky
numark1
Scared of girls
PostPosted: 17:33 - 09 Jan 2006    Post subject: Reply with quote
Gaffa tape an air horn on. Laughing
Dangerous Dorris
PostPosted: 18:45 - 09 Jan 2006    Post subject: Reply with quote
Hi Guys, im new on this site but gotta put my two penny worth in, for what its worth (yep im a girl) ive got a day time MOT on one of my track bikes, as said earlier all you need is a horn and reflector. A good tip though is to always keep your docs on you though cos you are guaranteed to get stopped, bit of a grey area about number boards with numbers on them though, if they have the police Twisted Evil think you are racing on the road, yeah right. They will be out there with the yellow flags then eh? Wink
PostPosted: 18:59 - 09 Jan 2006    Post subject: Reply with quote
The simple way to avoid being accused of racing on a public highway is to make one of your group (usually the fastest rider) the "designated leader". Put an armband on him and make sure everyone knows who it is, don't pass him. That's what we do on big rideouts.
Copper stops you, starts ranting about racing, you just tell them you were following the designated leader as indicated by his armband.
Gazdaman
I did a trackday!!!
PostPosted: 19:37 - 09 Jan 2006    Post subject: Reply with quote
Doris have you got any pics of the bike with a daytime MOT?
Does it have a brake light?
And what's your view on the headlight situation? I'm not sure what to believe now we've got 2 contradicting statements.
Gaz
PostPosted: 19:48 - 09 Jan 2006    Post subject: Reply with quote
Both of which appear on the same page of the MOT manual. Which is where the "oppinion of the tester" I mentioned earlier comes in. Take it to a Honda main dealer with no headlight, it will fail. Take it to "Jims Backstreet Choppers" after suitable previous discussion on the point, it could well pass.
Shame you aren't near me. There is this place locally where you leave the bike in the yard and give them your old MOT then come back in an hour to pick it up. Let's just say, if you still had the keys in your pocket, it wouldn't matter.
Gazdaman
I did a trackday!!!
PostPosted: 19:52 - 09 Jan 2006    Post subject: Reply with quote
Luckily enough, I think I know a place around here, that once MOT'd an old BSA of my dads by looking at it out the window.
"Looks alrite lad" *writes certificate*.
Gaz
Dangerous Dorris
PostPosted: 20:12 - 09 Jan 2006    Post subject: Reply with quote
Hi Gaz this is the best i can do, you can see how i stand on the light issue. The wiring loom was taken out, ive got a rocker switch ignition under the seat, its kick start anyway. It was a pretty cut and slash to start with and theres really no going back.
Dangerous Dorris
PostPosted: 20:17 - 09 Jan 2006    Post subject: Reply with quote
Sorry Gaz did try to paste a picture, dont know what happened to it. will have another go.
Gazdaman
I did a trackday!!!
PostPosted: 21:37 - 09 Jan 2006    Post subject: Reply with quote
you have to click add attachment, then a box will appear, click browse, navigate to file, then click add attachment, then click submit.
I guess it's a case of suck it and see, I'll get it all sorted, then go and ask Mr MOT man.
Gaz
TiN
Pocket Tin
PostPosted: 23:23 - 09 Jan 2006    Post subject: Reply with quote
With all this speculation on the daytime MOTs - does this mean that you get a full MOT certificate? Or are restrictions logged on the certificate/register?
If it's the latter, what happens if you eventually make the bike fully road legal? Will you need to get it re-MOT'd?
TiN
dotgems.net
fast_tzr
PostPosted: 23:28 - 09 Jan 2006    Post subject: Reply with quote
as far as I know for a "daytime" MOT, you either need all your lights, or none at all. You cannot have a brakelight without a headlight, indicators without the other lights etc. read this in performance bikes a couple of years ago, maybe the rules have changed now, but I could be wrong about the whole thing, its just what I read.
Gazdaman
I did a trackday!!!
PostPosted: 01:00 - 10 Jan 2006    Post subject: Reply with quote
https://www.motuk.co.uk/manual/mc_contents.htm
This link is good. I think it says I don't need a brake light either. I'm unclear as to whether it says I need a reflector or not.
But the way I understand it, as long as I have neither lights front or back, I don't need a brake light, or indicators.
Hmm..
Gaz
The last post was made 20 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 135.11 Kb
