| Gazdaman |
 Gazdaman I did a trackday!!!
| mrchips |
 mrchips World Chat Champion
 Posted: 15:40 - 09 Jan 2006 Post subject: |
I'd imagine you'd need a horn and a brakelight. ____________________ Northern Irish? www.nibikers.com |
| yzf750r |
 yzf750r World Chat Champion
| Ste |
 Ste Not Work Safe
| stinkwheel |
 Posted: 16:27 - 09 Jan 2006 Post subject: |
It is rather vague, there is not really such a thing as a 'daytime' MOT. There are certain circumstances under which you can be exempted from some of the requirements.
It also contains a lot of 'in the oppinion of the tester' type stuff so I would suggest getting in with a backstreet mtoorcycle garage that does MOTs, look for customised/old/bodged bikes outside it as these guys:
a) Actually know the rules rather than failing something because they haven't seen it before and it isn't Japanese and less than five years old.
b) Are more likely to let a grey area slip past as they usually appreciate what you are trying to do.
How old is the bike? This can have a bearing on things.
With regard to headlamps and position lamps:
| Quote: | This inspection applies to: all machines, except those which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are
. only used during daylight hours, and
. not used at times of seriously reduced visibility
If this situation occurs the vehicle presenter should be issued with an advisory notice recording the above and it should also be recorded on the carbon copy of the VT20. |
Stop lamps:
| Quote: | This inspection applies to; all machines except those which have neither front nor rear position lamps, or has such lamps permanently disconnected, painted over or masked that are (see 1.1).
Exemptions
For this test if a stop lamp is fitted, it must meet the requirements of this inspection, but need not be fitted to a machine which:
a. cannot exceed 25mph, or
b. was first used before 1 January I936.or
c. was first used before 1 April 1986 and which has an engine capacity of less than 50cc.
Indicators:
| Quote: | If direction indicators are fitted they must meet the requirements of this inspection, but need not be fitted to a machine which:
. cannot exceed 30mph / 50kph, or
. was first used before 1 August 1986, or
. 'off road' machines which are designed
to carry only the rider.
. 'off road' machines with side car designed to carry the rider and one passenger in the side car.
off road machines are constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise).
You need a red reflector at the back of the bike.
You need a horn, but if it was made before 1st August 1973 you can use a squeezy bulb horn
https://www.motuk.com/bike/6-1.htm
EDIT: You don't have to have a mudguard if you don't want to UNLESS the front mudguard acts as a fork brace in which case it must be securely fitted or a fork brace fitted in its place.
You need a chain guard of some sort, but some of the ones fitted to custom bikes are so minimal it takes the piss (I would have thought you'd need one anyway to get through scrutineering). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Gazdaman |
| Kickstart |
 Kickstart The Oracle
| Gazdaman |
| Kickstart |
| Gazdaman |
| Kickstart |
| Gazdaman |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
| numark1 |
 numark1 Scared of girls
 Posted: 17:33 - 09 Jan 2006 Post subject: |
Gaffa tape an air horn on.  |
| Dangerous Dorris |
 Dangerous Dorris L Plate Warrior
 Posted: 18:45 - 09 Jan 2006 Post subject: |
Hi Guys, im new on this site but gotta put my two penny worth in, for what its worth (yep im a girl) ive got a day time MOT on one of my track bikes, as said earlier all you need is a horn and reflector. A good tip though is to always keep your docs on you though cos you are guaranteed to get stopped, bit of a grey area about number boards with numbers on them though, if they have the police think you are racing on the road, yeah right. They will be out there with the yellow flags then eh?  |
| stinkwheel |
 Posted: 18:59 - 09 Jan 2006 Post subject: |
The simple way to avoid being accused of racing on a public highway is to make one of your group (usually the fastest rider) the "designated leader". Put an armband on him and make sure everyone knows who it is, don't pass him. That's what we do on big rideouts.
Copper stops you, starts ranting about racing, you just tell them you were following the designated leader as indicated by his armband. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Gazdaman |
| stinkwheel |
| Gazdaman |
| Dangerous Dorris |
| Dangerous Dorris |
| Gazdaman |
| TiN |
 TiN Pocket Tin
 Posted: 23:23 - 09 Jan 2006 Post subject: |
With all this speculation on the daytime MOTs - does this mean that you get a full MOT certificate? Or are restrictions logged on the certificate/register?
If it's the latter, what happens if you eventually make the bike fully road legal? Will you need to get it re-MOT'd? ____________________ TiN
dotgems.net |
| fast_tzr |
 fast_tzr World Chat Champion
| Gazdaman |
 Posted: 01:00 - 10 Jan 2006 Post subject: |
https://www.motuk.co.uk/manual/mc_contents.htm
This link is good. I think it says I don't need a brake light either. I'm unclear as to whether it says I need a reflector or not.
But the way I understand it, as long as I have neither lights front or back, I don't need a brake light, or indicators.
Hmm..
Gaz |
The last post was made 20 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
