Bike wont start :(
dransy
PostPosted: 01:59 - 20 Jan 2006    Post subject: Bike wont start :( Reply with quote
Hi all , i press the start button on my bike , rs125 and nothing happens at all?.
Only thig i can think of is my battery or my starter motoro is fucked Sad , i hope its just my battery but when i go to start up my bike it jus does nothing?
any ideas?
cheers
marc
mchaggis
PostPosted: 02:58 - 20 Jan 2006    Post subject: Reply with quote
First off, it is in neutral, isn't it? Other than that, I would think a safety cutoff switch (sidestand or clutch) or fuse are the most likely options. If the battery is dodgy, it should probably still make the starter relay click or make some noise at least. Charge it up and have a play. It is unlikely that there is a problem with the starter motor, it is quite likely to be the battery or something silly like a loose connection/ duff switch.
I must not be a troll...
Mmmm, Guinness
Scorpius
PostPosted: 03:25 - 20 Jan 2006    Post subject: Reply with quote
what noise does it make? is there any sound at all?
Cagiva Mito 125 (sold)
Honda CBR400RR NC23 (sold)
Currently riding: Honda CBR600F
BFG
PostPosted: 10:11 - 20 Jan 2006    Post subject: Reply with quote
Do the lights work? Put lights on and hit starter, do the lights dim?
If they dim, charge your battery (not with a car charger) and give that a go. Or you could try bump starting.
If they don't dim, check the interlocks as suggested above. After that, check starter solenoid. Smile
kenny
PostPosted: 14:26 - 20 Jan 2006    Post subject: Reply with quote
try bumping it off to see if it will start with out any electrical help i.e starter motor
if it does get a multi meter across your battery and check the voltage if its 12volt or above then its ok if its below it either flat or had it
if thats ok then it will be your starter motor
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
Crafty786
PostPosted: 23:50 - 21 Jan 2006    Post subject: Reply with quote
Just out of intrest why shouldn't he charge the battery with car battery charger?
BFG
PostPosted: 14:43 - 23 Jan 2006    Post subject: Reply with quote
Current is too high. The majority of car chargers will damage a bike battery.
Crafty786
PostPosted: 16:14 - 23 Jan 2006    Post subject: Reply with quote
I see what if the current was low enough becuase the battery on bike keeps going dead but i can't find no Bike Battery Chargers.
liquidiz3d
PostPosted: 17:12 - 23 Jan 2006    Post subject: Not starting Reply with quote
When you press the start button what kind of noise is it making?
Does it start when bumping it off ok?
Daz
BFG
PostPosted: 18:01 - 23 Jan 2006    Post subject: Reply with quote
That's not normal. Your battery should remain charged and if it isn't then your bike has a problem. Post a new thread and we'll help you work it out. Smile
Question Have you tried a motorcycle shop?
ancientd
PostPosted: 18:16 - 23 Jan 2006    Post subject: Reply with quote
If that keeps happening get the Regulator checked out, with the bike reving to 2,500-3,000 RPM the voltage accross the battery should be about 13 volts. If its much higher you will most likely have a regulator fault, if much lower an altenator fault.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
Crafty786
PostPosted: 19:45 - 23 Jan 2006    Post subject: Reply with quote
I can even get the bike started. When press ignition button the starter motor goes round a few times very slowly then it gets slower and slower. I can't bump as i don't know how as I am very new to biking. MY bike is Rieju Rs2 Matrix
BFG
PostPosted: 20:08 - 23 Jan 2006    Post subject: Reply with quote
You can get a bike battery charger from any motorcycle show
Of course, what I should have typed here is "motorcycle shop". Very Happy
Crafty786
PostPosted: 20:19 - 23 Jan 2006    Post subject: Reply with quote
okay thanks mate i will try it.
BFG
PostPosted: 14:17 - 24 Jan 2006    Post subject: Reply with quote
That was wierd, my last post overwrote the one before it!
I wrote long stuff about trying a battery supplier from the yellow pages and all sorts. Sorry about that - don't know what happended. I must have pressed the wrong button.
Crafty786
PostPosted: 12:46 - 25 Jan 2006    Post subject: Reply with quote
Can you write it briefly again because it was very useful
The last post was made 20 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.03 - MySQL Queries: 13 - Page Size: 87.14 Kb
