| dransy |
 dransy World Chat Champion
 Posted: 01:59 - 20 Jan 2006 Post subject: Bike wont start :( |
Hi all , i press the start button on my bike , rs125 and nothing happens at all?.
Only thig i can think of is my battery or my starter motoro is fucked , i hope its just my battery but when i go to start up my bike it jus does nothing?
any ideas?
cheers
marc ____________________ Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 02:58 - 20 Jan 2006 Post subject: |
First off, it is in neutral, isn't it? Other than that, I would think a safety cutoff switch (sidestand or clutch) or fuse are the most likely options. If the battery is dodgy, it should probably still make the starter relay click or make some noise at least. Charge it up and have a play. It is unlikely that there is a problem with the starter motor, it is quite likely to be the battery or something silly like a loose connection/ duff switch. ____________________ I must not be a troll...
Mmmm, Guinness
| Scorpius |
 Scorpius Scooby Slapper
| BFG |
 BFG Brolly Dolly
 Posted: 10:11 - 20 Jan 2006 Post subject: |
Do the lights work? Put lights on and hit starter, do the lights dim?
If they dim, charge your battery (not with a car charger) and give that a go. Or you could try bump starting.
If they don't dim, check the interlocks as suggested above. After that, check starter solenoid.  |
| kenny |
 kenny Nearly there...
| Crafty786 |
 Crafty786 L Plate Warrior
| BFG |
 BFG Brolly Dolly
| Crafty786 |
| liquidiz3d |
 liquidiz3d L Plate Warrior
| BFG |
 BFG Brolly Dolly
| ancientd |
 ancientd Renault 5 Driver
| Crafty786 |
| BFG |
 BFG Brolly Dolly
| Crafty786 |
| BFG |
 BFG Brolly Dolly
| Crafty786 |
The last post was made 20 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
