Going to look at an NC30...
mrchips
PostPosted: 14:54 - 21 Jan 2006    Post subject: Going to look at an NC30... Reply with quote
Going to ring about one here, anything in particular to check for?
Northern Irish? www.nibikers.com
Shaun
Likes 'em bent
PostPosted: 15:04 - 21 Jan 2006    Post subject: Reply with quote
If it has an aftermarket exhaust fitted make sure it isn't blowing anywhere!
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:10 - 21 Jan 2006    Post subject: Reply with quote
Make sure the chain adjuster on the rear hub isn't mashed from people abusing it with a hammer and screwdriver.
mattd
PostPosted: 15:21 - 21 Jan 2006    Post subject: Reply with quote
Also, similiar to what Maurice said, make sure there's a chain adjuster (honda c-spanner) if not, it's a good bargaining point for a price drop (they're not cheap).
Check the downpipes carefully too, if they're in bad shape they require the engine to be dropped to change!
Also ask if the reg/rec had been changed recently, they have a habit of dying and can take out the generator, if the engine starts but stalls when you switch on the lights, or hit the brakes (brake lights) then a new one might be required.
Professional Hobo
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:28 - 21 Jan 2006    Post subject: Reply with quote
To add to that, if they've managed to wreck the stainless steel downpipes (never heard of them needing replacement), the bike is probably a dog anyway.
Why would you need to drop the engine to replace?
DynaMight
PostPosted: 15:53 - 21 Jan 2006    Post subject: Reply with quote
The connector pipe under the sump where the front down pipes meet the rest of the system is made of mild steel! these will corrode away over the years causing it to blow. Easy for a welder to fix but it's a arse getting the whole system off.
Make sure it's had the valve clearences checked and it's been well serviced.
There isnt alot that can go wrong with them if they're looked after
Lee_367
PostPosted: 16:06 - 21 Jan 2006    Post subject: Reply with quote
See if they've got a tool kit and stand to sweeten the deal, they come in very handy.
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
quacker_boy
Cuddle Bitch
PostPosted: 16:21 - 21 Jan 2006    Post subject: Reply with quote
cuz of the engine configuration.
it's impossible to simly undo the bolts and take it off!
the bolts can be slackened, then the engine has to be dropped to get em right off, it's a real bitch job.
mrchips
PostPosted: 12:02 - 22 Jan 2006    Post subject: Reply with quote
D'oh it was actually a cbr400, I was passed information that it was a vfr!
Valentino Mossy
PostPosted: 18:17 - 22 Jan 2006    Post subject: Reply with quote
Check the spark plugs as they can be expensive.
See if its derestricted (from japan with a max box or simular)
Check the oil sump,i had fractures on mine which i had to get a new sump.
Tool kit will be very handy as would be a rear stand Very Happy
If theres a racing can ,ask he/she for the original as you will need this for the mot.
Edit.... Just read last post.. Doh ! ignore the restricted bit ! Wink
The last post was made 20 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.36 - MySQL Queries: 13 - Page Size: 63.23 Kb
