| -Savage- |
 -Savage- World Chat Champion
| Guest |
 Guest Brolly Dolly
| fazed |
 fazed Korn is my hero!
 Posted: 02:33 - 01 Feb 2006 Post subject: |
Run it to the rear brake light switch wires, it's a positive feed and will turn off when ignition is switched off.  ____________________ gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack. |
| JMH |
 JMH Two Stroke Sniffer
| Jrod |
 Jrod Page 3 Girl
| -Savage- |
| stinkwheel |
 Posted: 16:23 - 01 Feb 2006 Post subject: |
Don't cut any wires. Get yourself a piggy-back terminal and connect in using that. This avoids damaging the original loom. You can then easily remove the grips if you want to leaving everything as it was before.
https://www.autosparks.co.uk/store/catalogue/images/m/000098.jpg
You want a single throw relay and an inline fuse. Run your 'heavy' wire from the battery positive, through your fuse to terminal 30 of the relay. Attach the heated grips to Terminal 87.
Terminal 86 connects to earth. Terminal 85 connects to your 'switching' input (eg brake light switch/flasher relay).
Spend some time planning where the wires are going to go (ie. not near anything hot or where they will get rubbed) and where you are going to put the relay (ie. somewhere out of the weather). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 20 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
