tapping into headlight relay?
-Savage-
PostPosted: 22:12 - 31 Jan 2006    Post subject: tapping into headlight relay? Reply with quote
could someone point me in the right direction for information.
i have heated grips on my bike now, and im scared of leaving them on and draining the battery. so i want to wire them into the headlight/ignition wiring so that it only comes on when the ignition is on.
how do i do this?
i have a wiring diagram for the cbr, but im not sure what wires i want to use and what i want to do with them..
Guest
PostPosted: 23:48 - 31 Jan 2006    Post subject: Reply with quote
You obviously need a feed that's only live when the ignition is turned on. Horns or brake lights are usually the easiest to splice into.
I've an 01 - 03 CBR 6 manual and it looks like white with green tracer is favourite
fazed
Korn is my hero!
PostPosted: 02:33 - 01 Feb 2006    Post subject: Reply with quote
Run it to the rear brake light switch wires, it's a positive feed and will turn off when ignition is switched off. Thumbs Up
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
JMH
PostPosted: 03:49 - 01 Feb 2006    Post subject: Reply with quote
If you decide to tap the rear brake light switch, do so _before_ the switch! Otherwise, the grips will only heat up whenever you apply the brakes!
--JMH
Jrod
Page 3 Girl
PostPosted: 15:22 - 01 Feb 2006    Post subject: Reply with quote
--JMH
Yep, I'd of said that f*cking obvious. Wink
-Savage-
PostPosted: 15:29 - 01 Feb 2006    Post subject: Reply with quote
haha yea, musttest wires to make sure they are live before i cut them anyway lol
PostPosted: 16:23 - 01 Feb 2006    Post subject: Reply with quote
Don't cut any wires. Get yourself a piggy-back terminal and connect in using that. This avoids damaging the original loom. You can then easily remove the grips if you want to leaving everything as it was before.
https://www.autosparks.co.uk/store/catalogue/images/m/000098.jpg
You want a single throw relay and an inline fuse. Run your 'heavy' wire from the battery positive, through your fuse to terminal 30 of the relay. Attach the heated grips to Terminal 87.
Terminal 86 connects to earth. Terminal 85 connects to your 'switching' input (eg brake light switch/flasher relay).
Spend some time planning where the wires are going to go (ie. not near anything hot or where they will get rubbed) and where you are going to put the relay (ie. somewhere out of the weather).
The last post was made 20 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 52.94 Kb
