removing clothing security tags
White Noise
Mr Dudwee
PostPosted: 19:04 - 05 Feb 2006    Post subject: removing clothing security tags Reply with quote
Wonder id someone can help me out. i brought a few clothes last weekend. got the jacket out the other day and a security tag has been left in the pocket still attached to the jacket.
the shop i brought it from is 180 miles away so i can't get it removed there. my next action is to take it to a random shop and get it removed but wonder if anyone knows an easy way of removing them?
WN
McGee
O RLY?
PostPosted: 19:06 - 05 Feb 2006    Post subject: Reply with quote
Strong magnet ? pulls the pin out doesnt it ?
Its pronounced Jixxer!
phantomtek
Lil Joe Tek
PostPosted: 19:10 - 05 Feb 2006    Post subject: Reply with quote
https://www.supplyamerica.com/images/rent-concrete-stihl460.jpg
That should do the trick.
No in all seriousness, take it to a random shop, department store and show them receipt and tell them you need it removing. They will be able to do it without any risk of damaging the jacket itself.
Karma
cagiva gezzer
Someone here asked the same question a few months ago. Have a search and you might find it.
colin1
Captain Safety
PostPosted: 19:13 - 05 Feb 2006    Post subject: Reply with quote
if it were me, id use a hack saw on the steel pin that goes through the cloth
ashley_46
PostPosted: 19:17 - 05 Feb 2006    Post subject: Reply with quote
Cant you use a paper clip or coat hanger on certain types of them to release it as thats basically all the thing they use has. Just a thin bit of metal pushed in the hole on the side of the clip. I may be totally wrong or it might be a different type of tag but it might be worth looking at first.
Rookie
PostPosted: 19:27 - 05 Feb 2006    Post subject: Reply with quote
No they're all magnetic these days; in fact without the proper equipment it's virtually impossible to remove them without leaving a hole, which would be at minimum half a centimetre in diametre. You could hack it off, but chances are you'd damage the clothing doing so.
See if there's another branch of the store close to you, and take the receipt with. If not, be cheeky and try a different branch.
If you don't have the receipt you might be screwed, as they'd all think you nicked it.
Going2fast
PostPosted: 19:28 - 05 Feb 2006    Post subject: Reply with quote
I'll 2nd that action, a strong enough magnetic should release the tag from the pins. Thumbs Up
Passed My Test 15/03/05 Very Happy Very Happy
BikePics Profile ||| 96' RVF 400 ||| 01' CBR 600 F Sport ||| 2009 Yamaha YZF-R6 Delivered 23/06/09
/-\ndy
Rookie
PostPosted: 19:30 - 05 Feb 2006    Post subject: Reply with quote
Define strong enough? If there was an easily obtainable, pocket-sized magnet which could get these off, they'd be redundant for shoplifters, wouldn't they?
carvell
Scuttler
PostPosted: 19:35 - 05 Feb 2006    Post subject: Reply with quote
https://cgi.ebay.co.uk/Rare-earth-magnet-very-strong-powerful-NdFeB-32SH_W0QQitemZ7586044933QQcategoryZ36338QQrdZ1QQcmdZViewItem
Yamaha TDM 850
Handsome
PostPosted: 19:54 - 05 Feb 2006    Post subject: Reply with quote
Two forks to lever the tag apart are supposed to work.
Never tried it myself.
numark1
Scared of girls
PostPosted: 19:55 - 05 Feb 2006    Post subject: Reply with quote
I posted this a while ago, had one left on one of my ralph jackets.
Can you get a picture of it? Some are liquid tags so when you remove them they leak ink.
If its just grey then i used a screwdriver and prised the pin out as much as i could (only about 5mm Laughing ) I then hack sawed the pin off. Worked a treat and you can't tell at all it happened. Thumbs Up
White Noise
Mr Dudwee
PostPosted: 19:59 - 05 Feb 2006    Post subject: Reply with quote
markcatate wrote:
If its just grey
thats the puppy!
WN
Skunkcap Freddie
PostPosted: 20:10 - 05 Feb 2006    Post subject: Reply with quote
get an old harddrive. rip it apart for the magnets . they are pretty strong. i have one on my wall and throw my keys at it , and they stick easy there's a good 6 keys, plus a quick release key thingy
Leggy_Girl
PostPosted: 22:37 - 06 Feb 2006    Post subject: Reply with quote
You need a magnet which is big enough to cover the back of the pin, as well as strong enough to grip it and pull it out (used to work in Topshop and Marks and Spencers - lots of clothes tagging etc). You can rip them out with force i.e. forks, pliers, but you do risk leaving a visible hole in your clothes.
Generally though, another shop wont remove something which isn't their product/ responsibility. It's very easy to forge a receipt and most stores wouldn't waste their time checking a rival shops customer out. We were never allowed to, as mean as it sounds.
"One moment can change a day, one day can change a life and one life can change the world." Siddhartha Gautama
numark1
Scared of girls
PostPosted: 22:41 - 06 Feb 2006    Post subject: Reply with quote
White Noise wrote:
thats the puppy!
WN
Same as what i had, saw the end off. It has loads of like metal strands in it though. Confused
mchaggis
PostPosted: 01:10 - 07 Feb 2006    Post subject: Reply with quote
A magnet from a large speaker might do the trick. Otherwise it may not be too difficult to wind a decent electromagnet of your own to power from a car battery, it'd be good for the amusement if nothing else. Smile
I must not be a troll...
Mmmm, Guinness
DEN MONKEY
PostPosted: 03:49 - 07 Feb 2006    Post subject: Reply with quote
So did they really forget or did you do a runner ??
meh
Cog Head
PostPosted: 09:16 - 07 Feb 2006    Post subject: Reply with quote
that there is a mighty chavvy looking jacket you'v go there...
Thumbs Up Wink
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
White Noise
Mr Dudwee
PostPosted: 11:55 - 08 Feb 2006    Post subject: Reply with quote
Thumbs Up Wink
LOL it does in the photo, its just a cheap animal jacket to keep the wind and rain at bay
WN
lozzypop1
Certified MILF!
PostPosted: 11:58 - 08 Feb 2006    Post subject: Reply with quote
do you not have a friend/daughter/neice/next door neighbour that works ina clothing store??? they may be able to do it on the quiet for you!
feef
Energiser Bunny
White Noise wrote:
markcatate wrote:
If its just grey
thats the puppy!
WN
those ones use a curved pin that slides into the tag and releases the catch. they aren't magnetic.
The pins are hardened steel, be casreful when hacksawing them as the blade will slip, and gash the fabric
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
primalcarl
PostPosted: 20:56 - 09 Feb 2006    Post subject: Reply with quote
Same has happened to my girlfriend. She discovered the other day that a jumper she bought 4 weeks ago has still got the tag on it. She's got the receipt, but worried what the shop will think as she's taken so long to notice!
White Noise
Mr Dudwee
PostPosted: 21:06 - 09 Feb 2006    Post subject: Reply with quote
got it sorted! Thumbs Up
went to next (only place i found that used those tags) in burton upon trent while i was up there working, showed them my reciept and they whiped it off! Thumbs Up
only after walking into the shop and setting the alarms off! Laughing
WN
Andy C
Tree Seeking Missile
PostPosted: 21:30 - 09 Feb 2006    Post subject: Reply with quote
this happend to me aswell, brought a buff neck warmer for my bike (well for me while on the bike) and got on the bus (was with my bro and hes to scared to ride on the back of my bike, and hes 20 Rolling Eyes ) and they left the tag on Twisted Evil
My mum was traveling that way the next day and took it in and got a 10% discount for the touble Cool which was £1.70
The last post was made 20 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 131.44 Kb
