| White Noise |
 White Noise Mr Dudwee
 Posted: 16:33 - 11 Feb 2006 Post subject: carb balance help |
i am balancing my carbs on my yam divvy after borrowing a set of guages from davo (cheers mate) unfortionatly the brass tube threads are too small, i think i need 6 mm port adapters
https://www.holeshot.com/tools/images/tool_carb_sync_gauges.jpg
does anyone have/know where i can get them in a larger thread size or a way round the problem
WN
edit: carbtune sell the adaptors but not sure if they will be ok as at the end of the brass adaptors i have in the kit there is an opening about the width of a pin, concerned that this difference will cause errors in the readings
https://www.carbtune.com/carbaccs.html ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
| Ichy |
 Ichy World Chat Champion
| White Noise |
 Posted: 02:40 - 12 Feb 2006 Post subject: |
there is no pipe, just a thread that the adaptor should go and i can't see anyway of bodging it
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
| Guest |
 Guest Brolly Dolly
| Jrod |
 Jrod Page 3 Girl
 Posted: 14:43 - 12 Feb 2006 Post subject: |
I used those gauges and it said I had a intake manifold leak or soemthing, got someone else to do it fo me as I dunno what I was doing wrong.  |
| Guest |
 Guest Brolly Dolly
 Posted: 17:15 - 12 Feb 2006 Post subject: |
You have to remember to blank off the vacuum tap take-off if fitted - took me an hour to find that out the first time I did my GS thou.
An M6 screw down the pipe usually works. |
| bish777 |
 bish777 World Chat Champion
| White Noise |
The last post was made 20 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
