carb balance help
White Noise
Mr Dudwee
PostPosted: 16:33 - 11 Feb 2006    Post subject: carb balance help Reply with quote
i am balancing my carbs on my yam divvy after borrowing a set of guages from davo (cheers mate) unfortionatly the brass tube threads are too small, i think i need 6 mm port adapters
https://www.holeshot.com/tools/images/tool_carb_sync_gauges.jpg
does anyone have/know where i can get them in a larger thread size or a way round the problem
WN
edit: carbtune sell the adaptors but not sure if they will be ok as at the end of the brass adaptors i have in the kit there is an opening about the width of a pin, concerned that this difference will cause errors in the readings
https://www.carbtune.com/carbaccs.html
Ichy
PostPosted: 16:55 - 11 Feb 2006    Post subject: Reply with quote
Will the rubber tube fit onto the pipe between the carb and the cylinder?
To be honest those type of gauges are not the most accurate in the world so the carbtune adaptors are unlikely to cause you much of a problem.
White Noise
Mr Dudwee
PostPosted: 02:40 - 12 Feb 2006    Post subject: Reply with quote
there is no pipe, just a thread that the adaptor should go and i can't see anyway of bodging it
WN
Guest
PostPosted: 08:46 - 12 Feb 2006    Post subject: Reply with quote
Go for the adaptors. A set of gauges like that are perfectly adequate unless you're after the last smidgeon of power - I have some and I get good results as long as all the gauges read the same.
If the pipe is a good fit over the adaptors (cable tie if you're desperate) they'll be ok and you can damp out the fluctuations with those plastic valves.
Jrod
Page 3 Girl
PostPosted: 14:43 - 12 Feb 2006    Post subject: Reply with quote
I used those gauges and it said I had a intake manifold leak or soemthing, got someone else to do it fo me as I dunno what I was doing wrong. Embarassed
Guest
PostPosted: 17:15 - 12 Feb 2006    Post subject: Reply with quote
You have to remember to blank off the vacuum tap take-off if fitted - took me an hour to find that out the first time I did my GS thou. Embarassed
An M6 screw down the pipe usually works.
bish777
PostPosted: 17:42 - 12 Feb 2006    Post subject: Reply with quote
either drill out an M6 bolt, or i think mig welder gun tips are 6mm threaded and have the hole.
GSXR1100J
White Noise
Mr Dudwee
PostPosted: 17:52 - 12 Feb 2006    Post subject: Reply with quote
i was wondering about this as i have the take off operating a scottoiler, so do i definatly need to block it off even if that not the way it is in usual bike operation.
cheers bish for that suggestion but going to order some carb tune
WN
The last post was made 20 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.03 - MySQL Queries: 13 - Page Size: 56.58 Kb
