Oversize fork stanchions
PostPosted: 21:43 - 14 Feb 2006    Post subject: Oversize fork stanchions Reply with quote
Well, someone pointed out the obvious solution to my ground clearance problems on my KLE500 motard at the weekend. I need a set of 2" over standard fork stanchions, this will return the frame geometry to standard. I can drop them through the yokes if I refit the 21" wheel.
Trouble is, where to get them? (pretty sure they are the same as KLR650 ones)
PostPosted: 22:51 - 14 Feb 2006    Post subject: Reply with quote
Try someone like ABE and see if they will do some one off forks.
MikeH
PostPosted: 22:57 - 14 Feb 2006    Post subject: Reply with quote
Have you jacked up the rear already then ? just wondering why you want to lift the front 2"
I've been looking at the Dogbones for sale on EvilBay and thinking I could get some made up locally for half the price.
Mike Cool
Busa Junkie
PostPosted: 23:13 - 14 Feb 2006    Post subject: Reply with quote
I want to lift the front 2" because I have dropped it 2" by fitting the 17" wheels.
Put some load or a pillion on the back of the bike and it is way too close to the ground for my liking, drags the pegs. Also grounds out on the landing from humpback bridges.
Shortening the dog bones would raise the back, but at the expense of sharpening the rake angle even further. It is about as twitchy as I am happy with already. Lengthening the forks would increase the rake again.
Irezumi aka Reuben
Carrot Top
PostPosted: 23:17 - 14 Feb 2006    Post subject: Reply with quote
Read of length being added to the top of forks in Streetfighter mag, nowhere near you that carry's out such job's. Not sure how 2" would cope, the one's I read of are normally a few centimetres at most.
Pictorgraphicalfantastical
MikeH
PostPosted: 23:20 - 14 Feb 2006    Post subject: Reply with quote
Ahh OK I'd forgot you fitted ickle wheels to it Wink
Busa Junkie
PostPosted: 23:22 - 14 Feb 2006    Post subject: Reply with quote
Used to be quite common to bolt on extension pieces to forks on choppers, but not sure that they would be that rigid which could be pretty bad for handling.
Irezumi aka Reuben
Carrot Top
PostPosted: 23:23 - 14 Feb 2006    Post subject: Reply with quote
Be more concerned about them potentially snapping than bad handling personally. Laughing
woodyfjr
PostPosted: 10:48 - 15 Feb 2006    Post subject: Reply with quote
You could always make a sleave to go over the joint which would clamp & strengthen the weakened area Idea
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
PostPosted: 16:56 - 15 Feb 2006    Post subject: Reply with quote
I AM NOT RIDING A BIKE WITH SLUGGED FORKS! Shocked Praying
Sodding dangerous idea that should have died with its inventors. Probably OK on a lazy chop with massively raked out forks, but even then they still came apart. I can just imagine me going over a humpback bridge only to be overtaken by the entire front-end of the bike just prior to landing.
PostPosted: 17:03 - 15 Feb 2006    Post subject: Reply with quote
Unlikely to happen, unless you can get the bike to go rapidly in reverse Wink .
PostPosted: 17:24 - 15 Feb 2006    Post subject: Reply with quote
Duuuh. It is when I am doing back-flips and 720's. Shifty
The last post was made 20 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 75.17 Kb
