1 Cylinder SV650
henri
PostPosted: 08:26 - 21 Mar 2006    Post subject: 1 Cylinder SV650 Reply with quote
I was on my wayi nto work this morning on the A13 when the bike lost power, I am now running on 1 cylinder, any ideas? is this common on the SV650?
SV650s Warrior
PostPosted: 08:27 - 21 Mar 2006    Post subject: Re: 1 Cylinder SV650 Reply with quote
Water around the front spark plug?
If so, yes, quite common.
Darth Monk
PostPosted: 17:09 - 21 Mar 2006    Post subject: Reply with quote
Probably you have a problem with the spark.
The water may be the cause, but try to control the carburation, or the exact distance of the electrodes.
DON'T UNDERESTIMATE THE POWER OF THE DARK SIDE
Wave2k
G's Stalker
PostPosted: 17:43 - 21 Mar 2006    Post subject: Reply with quote
technically its an SV325
Razz
Ducati 1299 Panigale
2009 Corvette C6 z51
loply
PostPosted: 17:54 - 21 Mar 2006    Post subject: Reply with quote
In all instances where one pot isnt firing but the others are, checking the spark to that pot is the first thing to do. Probably a 90% chance it isnt sparking.
Yamaha SZR660 Caution to the wind, the throttle pinned!
FreshAL
Sir Crashalot
PostPosted: 17:55 - 21 Mar 2006    Post subject: Reply with quote
yup, very common - was it raining?
Happened all the time on mine till I asked on here and www.sv650.org. Gave it a good clean round the front plug, squireted a bit of WD40 and fitted a fender extender - problem solved!
fazed
Korn is my hero!
PostPosted: 18:30 - 21 Mar 2006    Post subject: Reply with quote
As people have said, also check the water drain hole on the front cylinder see if it's blocked with road crud. Thumbs Up
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
henri
PostPosted: 08:09 - 22 Mar 2006    Post subject: Reply with quote
Front cylinder fine rear cylinder no spark any ideas?
SV650s Warrior
jamieclayton9
PostPosted: 10:26 - 22 Mar 2006    Post subject: Reply with quote
i had the same problem with my sv to. used to do it on cold damp mornings to. fender extener is a great idea mate. cheers. jamie
all my previous rides, c50 steppie, h100s, cb250n superdream, gpz500s, gsf600s bandit, gsf1200s bandit, zx6r, thunderace, dr350, sv650s, cb600f hornet ooohhhhh and the mrs
fuzz
PostPosted: 12:36 - 22 Mar 2006    Post subject: Reply with quote
Front cylinder fine? Well that's put the water idea out of the question. Do you have a manual? If so, check the rear coil resistances. Check the HT lead for corrosion. If the front is fine, I doubt the rear will be corroded, but you never know.
The last post was made 19 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 62.73 Kb
