my breaks are squeeking and it annoying
Teaman
PostPosted: 20:45 - 03 Apr 2006    Post subject: my breaks are squeeking and it annoying Reply with quote
right then
breaks were squeeking,
fitted new pads,
sprayed with break and chain cleaner
wiped with thinners, , ran emery paper on pads,
copper grease on rear of pads and all bolts
checked bobbins,
checked the bolts that hold the disks to the wheel
the fuckers still squeek,,,,
any ideas?
ZZR1200 02
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
veeeffarr
PostPosted: 20:47 - 03 Apr 2006    Post subject: Reply with quote
Hahahaha.
Haha.
Ha.
PostPosted: 21:19 - 03 Apr 2006    Post subject: Reply with quote
Take the calipers off the bike and clean them with a toothbrush. Will need the system bleeing completly as you reassemble the bike and that'll help as well.
Are the wheel bearings alright, it is the brakes that are squeaking and not anything else?
mr jamez
PostPosted: 21:22 - 03 Apr 2006    Post subject: Reply with quote
Some disk/pad combinations squeek, are you using uprated items?
Teaman
PostPosted: 21:45 - 03 Apr 2006    Post subject: Reply with quote
break fluid is new, ,recent full service inc break fluid,
bearings are fine,
no sign of any leaking from the calipers
the new pads are carbone lorraine, sports touring ones same as I had before, its only been a recent thing since having new tyres about 700 miles ago, bearing mind the breaks have been on for 360 of that
meooo
PostPosted: 23:28 - 03 Apr 2006    Post subject: Reply with quote
did you re-fit the anti-squeal shims? those thin bits of shim type metal that appear to be part of the pad and so often get tossed into the bin with the old pads?
kawakid
PostPosted: 01:21 - 04 Apr 2006    Post subject: Reply with quote
Have you changed the pins/clips?
Have you tried sawing a vertical line on your pads with a hack saw?
I've a twin and a 4.
nrml76
PostPosted: 20:31 - 04 Apr 2006    Post subject: Reply with quote
I have found in the past, that it disappears in a few hours or days. Just ignore it for a while, till it beds in.
BigChris
PostPosted: 21:12 - 04 Apr 2006    Post subject: Reply with quote
cleaned the discs with brake cleaner too? Helped for me...
Teaman
PostPosted: 22:49 - 04 Apr 2006    Post subject: Reply with quote
doen all of the above,
pads have vertical line,
wiped disks with cleaner, and sprayed bobbins with it,
disks squeek every now and again now, depending on how hard I break,
they shut up for a while then start again.
and a note to toby,,,,
fuck off cos next time I sneak up on you to slap you round the head you WONT hear me coming
PostPosted: 09:47 - 05 Apr 2006    Post subject: Reply with quote
First off, can I be the first to say it's 'brakes' Smile.
I would go with ste's suggestion of the tooth brush.
Get the pads out, push the pistons out a bit (make sure they don't pop out Smile ). Then clean the pistons. Ideally I believe you should apply rubber grease to the pistons before you push back in.
Also apply copper grease to the pins which the pads slide on, if you're haven't.
Bendy
Mrs Sensible
PostPosted: 10:02 - 05 Apr 2006    Post subject: Reply with quote
Get a louder exhaust.
finpos
PostPosted: 10:28 - 05 Apr 2006    Post subject: Reply with quote
Sounds like you've done all the right things.
To try as a last resort:
Chamfer the leading edge of your brake pad with a file.
Rough up the disk surfaces.
whistle a tune to yourself whilst braking..
finpos
Teaman
PostPosted: 12:26 - 08 Apr 2006    Post subject: Reply with quote
I like bendys Idea tbh. Smile
right then, done all of the above, even took it to the bike shop, the disks are not warped, checked em with a clocking tool, they squeek constantly if you hover over the brake and push the bike forward yet they done when pushing it backwards.
the brake disks also get stupidly hot after braking, but then they dont squeek as often.
The pads are sports touring and Ive been told they are a harder compound, and Ive been recomended to buy some organic compound ones. These are supposed to give you a slightly more progressive braking force and shouldnt squeak. £30 for the pair made by EBC. also been looking at ferodo. the reason I bought Carbone Lorraine is because I can get mine at trade.
The last post was made 20 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 80.1 Kb
