what is this plug called? pic attached.
shaba2000
PostPosted: 19:42 - 16 Apr 2006    Post subject: what is this plug called? pic attached. Reply with quote
can someone tell me what this plug is for and what it is called as i snapped it trying to take it out? its from a 1996 gpz 500s
location of plug is:
https://img.photobucket.com/albums/v449/atashahbazi/gpz4.jpg
plug up close:
https://img.photobucket.com/albums/v449/atashahbazi/screw1.jpg
simon1221
PostPosted: 20:16 - 16 Apr 2006    Post subject: Reply with quote
"Oil sump plug" ?
Gearbox oil plug I think.
But i dont recognise the bike so I could be wrong.
Chiz
PostPosted: 20:20 - 16 Apr 2006    Post subject: Reply with quote
I think it's a sump plug. But isn't all oil shared in a 4 stroke, so not just gearbox oil?
Could be wrong though
Guest
PostPosted: 20:28 - 16 Apr 2006    Post subject: Reply with quote
According to the fiche on https://www.buykawasaki.com/Default.asp? it's a 'Plug, main gallery'
What this means is, when they machine the crankcases they have to have holes in the inside for the oil to flow through, but you can't drill a hole from half-way.
So they drill it all the way through and then fit a plug like this to stop the oil squirting out all over your right foot Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 21:01 - 16 Apr 2006    Post subject: Reply with quote
Yup, what he said, It's the seal for the main oil gallery, WTF did you try to remove it for???
The bike is now grounded until you find a replacement, probably free or a quid at most from any salvage yard... but make sure ya get one from another Kaw 500...(or whatever that is)
shaba2000
PostPosted: 21:16 - 16 Apr 2006    Post subject: Reply with quote
i thought it was the oil plug! dont ask why!
but whats the proper name for it? also does anyone know of any salvage yards in london that i can try?
ZRX61
Victor Meldrew
PostPosted: 21:32 - 16 Apr 2006    Post subject: Reply with quote
It was already posted: "Plug, main gallery". Just explain where it goes/what it does over the phone & anyone with half a brain (the usual IQ requirement for employment in salvage yards) will know what it is.
shaba2000
PostPosted: 12:48 - 17 Apr 2006    Post subject: Reply with quote
if i was to put a standard bolt in there but with no hole going through it would it damage the engine in any way? whats the purpose of the hole going through it?
also any one know of anywhere i can get one today in london or close to london?
BFG
PostPosted: 12:57 - 17 Apr 2006    Post subject: Reply with quote
It's sump plug.
Never mind what the manual says, call it a 'sump plug' or you'll get funny looks. Take the old one with you. Very Happy
ZRX61
Victor Meldrew
PostPosted: 16:02 - 17 Apr 2006    Post subject: Reply with quote
BFG wrote:
It's sump plug.
No it bloody isn't FFS. Rolling Eyes
ZRX61
Victor Meldrew
PostPosted: 16:05 - 17 Apr 2006    Post subject: Reply with quote
It should be a blind hole (ie, doesn't actually go anywhere). If thats the case you could put a bolt in there but use a copper crush washer to seal it otherwise you'l have oil spraying all over.
I've got a few of the correct bolts sitting in my garage, but I'm 6500 miles away..
PostPosted: 17:54 - 17 Apr 2006    Post subject: Reply with quote
It is not a sump plug, but it does have a function. That one is there for an engineer to remove and screw an oil pressure guage into to check the oil pump is functioning properly.
You wanted the sump plug which is located (surprisingly) in the sump as opposed to the side of the crankcase. It is underneath the bike, near the front.
Now give yourself a slap alongside the head for unscrewing bits off your bike when you don't know what they are and what they do.
https://www.bikechatforums.com/download.php?id=29082
BFG
PostPosted: 18:48 - 17 Apr 2006    Post subject: Reply with quote
Oops. Neither it is. Wink
PostPosted: 18:56 - 17 Apr 2006    Post subject: Reply with quote
In my Kawasaki workshop manual it is called an "Oil passage plug".
Yopu need to replace it with the correct one, should be hollow with a hole in it like a brake banjo bolt and has an o-ring under it. DO NOT replace it with an ordinary bolt or you will interfere with the oil flow to your engine.
shaba2000
PostPosted: 19:21 - 17 Apr 2006    Post subject: Reply with quote
okay thanks mate thats a great help..
ZRX61
Victor Meldrew
PostPosted: 20:42 - 17 Apr 2006    Post subject: Reply with quote
On some the hole is blind, so oil doesn't actually go anywhere via the bolt/plug. Thats why I said "IF" it's a blind hole, a normal bolt & copper crush washer will be ok for while Smile
carvell
Scuttler
PostPosted: 21:00 - 17 Apr 2006    Post subject: Reply with quote
Just as a side note, the sump plug on a Honda Bros is located in the side, about where this oil passage flow plug is. It's designed so that you drain the oil on the side stand.
I can see it wouldn't be too hard for someone inexperienced to get confused.
Yamaha TDM 850
ZRX61
Victor Meldrew
PostPosted: 23:20 - 17 Apr 2006    Post subject: Reply with quote
Except it's a kaw & the kickstand is on the other side Wink
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 94.7 Kb
