| shaba2000 |
 shaba2000 Nitrous Nuisance
| simon1221 |
 simon1221 World Chat Champion
| Chiz |
 Chiz Trackday Trickster
| Guest |
 Guest Brolly Dolly
 Posted: 20:28 - 16 Apr 2006 Post subject: |
According to the fiche on https://www.buykawasaki.com/Default.asp? it's a 'Plug, main gallery'
What this means is, when they machine the crankcases they have to have holes in the inside for the oil to flow through, but you can't drill a hole from half-way.
So they drill it all the way through and then fit a plug like this to stop the oil squirting out all over your right foot  |
| ZRX61 |
 ZRX61 Victor Meldrew
| shaba2000 |
| ZRX61 |
| shaba2000 |
| BFG |
 BFG Brolly Dolly
 Posted: 12:57 - 17 Apr 2006 Post subject: |
It's sump plug.
Never mind what the manual says, call it a 'sump plug' or you'll get funny looks. Take the old one with you.  |
| ZRX61 |
| ZRX61 |
| stinkwheel |
 Posted: 17:54 - 17 Apr 2006 Post subject: |
It is not a sump plug, but it does have a function. That one is there for an engineer to remove and screw an oil pressure guage into to check the oil pump is functioning properly.
You wanted the sump plug which is located (surprisingly) in the sump as opposed to the side of the crankcase. It is underneath the bike, near the front.
Now give yourself a slap alongside the head for unscrewing bits off your bike when you don't know what they are and what they do.
https://www.bikechatforums.com/download.php?id=29082 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| BFG |
 BFG Brolly Dolly
| stinkwheel |
 Posted: 18:56 - 17 Apr 2006 Post subject: |
In my Kawasaki workshop manual it is called an "Oil passage plug".
Yopu need to replace it with the correct one, should be hollow with a hole in it like a brake banjo bolt and has an o-ring under it. DO NOT replace it with an ordinary bolt or you will interfere with the oil flow to your engine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| shaba2000 |
| ZRX61 |
| carvell |
 carvell Scuttler
| ZRX61 |
The last post was made 20 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
