Redex.
greatmoorred
PostPosted: 10:23 - 17 Apr 2006    Post subject: Redex. Reply with quote
Now i was always a big fan of redex when i was younger, and used to treat my knackered old fiestas to it. Very Happy
Question is, can i put it into my bandit ?
Its got carbs as its quite old, and it seems to be burbling ( ! ) a bit when you drop the revs down, at a set of lights for instance. I was just wondering if a shot of redex would clear out the carbs a bit.
DucatiEVO
PostPosted: 10:38 - 17 Apr 2006    Post subject: Reply with quote
Engine is an engine, so won't hurt to try it in the Bandit! Thumbs Up
aKa: Ducky
DynaMight
PostPosted: 10:45 - 17 Apr 2006    Post subject: Reply with quote
Sounds like the carbs needs to be balanced, Redex is worth a try tho.
greatmoorred
PostPosted: 10:50 - 17 Apr 2006    Post subject: Reply with quote
yeah, im thinking it probably needs a bit of a service as it was stood for a long time before i bought it. But i thought i would give it a couple of runs first, just to see if it needed to clear its throat.
Teaman
PostPosted: 11:09 - 17 Apr 2006    Post subject: Reply with quote
take the float bowls off and check em , if theres loads of shit in the bottom i guess a lot would have got into the engine and would have stuck to the valves,
redex is good for removing the varnish that unleaded leaves on things,
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
ZRX61
Victor Meldrew
PostPosted: 15:26 - 17 Apr 2006    Post subject: Reply with quote
Rolling Eyes
phantomtek
Lil Joe Tek
PostPosted: 15:28 - 17 Apr 2006    Post subject: Reply with quote
ZRX61 wrote:
Rolling Eyes
ZRX61 - Hater of Redex.
I used Redex, seemed to work. Expensive though.
Flip
PostPosted: 15:30 - 17 Apr 2006    Post subject: Reply with quote
Redex does work though.
Mark_petty
PostPosted: 15:45 - 17 Apr 2006    Post subject: Reply with quote
My bandit was sat for ages (1999 reg and only done 3k miles Surprised )
What I did was changed spark plugs, new oil, new oil filter, new fuel, drained old fuel from carbs, new air filter, charged battery and also added some fuel additives and that seemed to do the trick then went for a long ride Very Happy .
It now starts first time (even if left for days without any use) Very Happy It also idles fine.
It well worth doing it if its been sat there for a while
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
ZRX61
Victor Meldrew
PostPosted: 16:03 - 17 Apr 2006    Post subject: Reply with quote
So use ATF instead, thats all Redex is....
phantomtek
Lil Joe Tek
PostPosted: 16:11 - 17 Apr 2006    Post subject: Reply with quote
Sorry for being naive but what is ATF?
Karma
DucatiEVO
PostPosted: 16:22 - 17 Apr 2006    Post subject: Reply with quote
ATF
Automatic Transmission Fluid
They're both red I suppose.... Laughing
aKa: Ducky
phantomtek
Lil Joe Tek
PostPosted: 16:30 - 17 Apr 2006    Post subject: Reply with quote
DucatiEVO wrote:
ATF
Cheers Laughing Confused
Teaman
PostPosted: 16:35 - 17 Apr 2006    Post subject: Reply with quote
blood is also red ,
or tomato sauce Smile
TOM M
PostPosted: 16:58 - 17 Apr 2006    Post subject: Reply with quote
What is redex and what does it do?? Embarassed
Now owner of a 1200 Bandit
phantomtek
Lil Joe Tek
PostPosted: 17:03 - 17 Apr 2006    Post subject: Reply with quote
Basically cleans out your engine system.
Put it in your fuel and it supposedly increases MPG, cleans your carbs and makes the bike more efficient.
TOM M
PostPosted: 17:20 - 17 Apr 2006    Post subject: Reply with quote
Cheers for that Thumbs Up
Im going to pop down halford tomorrow to buy a couple bottles, one for the bike and one for the car.
Is it easy to use???
phantomtek
Lil Joe Tek
PostPosted: 17:27 - 17 Apr 2006    Post subject: Reply with quote
Just pour it in the petrol and you are all set. Usually use 1/8th at a time.
For the intensive carb treatment you spray it into the carbs while the engine is running - have a fire extinguisher to hand. I would just stick to pouring it into the petrol.
It's £10 a litre at Halfrauds. But you can buy smaller bottles.
greatmoorred
PostPosted: 17:30 - 17 Apr 2006    Post subject: Reply with quote
or take the plugs out and pour it into the cylinder, leave it for a few minutes, pop the plug back in and then start it up.
Best to do this when your parents/neighbours have just hung out a whites wash on the washing line. Very Happy
phantomtek
Lil Joe Tek
PostPosted: 17:40 - 17 Apr 2006    Post subject: Reply with quote
What does this clean by the way?
What are the benefits?
Teaman
PostPosted: 18:01 - 17 Apr 2006    Post subject: Reply with quote
it removes all the shite on the valves, stops sticky valves, if you do the carb injection you use more aswell but that does the same thing, just gradually, and if you mix it in the fuel it will do the needles and carb valves,
it doesnt improve fuel consumption whist your using it as it burns hotter,
you shouldnt really need to use it in new bikes though unless they have done loads of miles, best to check what state your plugs are in before using it as it will burn off anything on them stopping you from finding out why you might need to be using it in the first place
i would check those, check the tank petrol filter, check the float bowls and see if the ht leads are hard before using it or your just throwing money away ,.
MikeH
PostPosted: 18:11 - 17 Apr 2006    Post subject: Reply with quote
When I got the XJR a couple of weeks ago it used to start missing if you ran it over a ton for more than a minute or two, I put half a bottle of Redex in two tankfuls and it now runs sweet as a nut.
Gets my vote Thumbs Up
It's worth getting the carbs balanced too, it makes a huge difference.
Mike Cool
Busa Junkie
ZRX61
Victor Meldrew
PostPosted: 19:50 - 17 Apr 2006    Post subject: Reply with quote
If you want to put some stuff in the fuel to clean up the valves etc theres one thing thats WAY above the others: Techron from Chevron. Don't buy the diluted stuff, get the full monty. Thumbs Up
DucatiEVO
PostPosted: 09:19 - 18 Apr 2006    Post subject: Reply with quote
This one?
https://www.chevron.com/products/prodserv/fuels/additives/concentrate_plus.shtml
Damn, I work for the buggers and I've never come across this stuff before... Laughing
aKa: Ducky
ZRX61
Victor Meldrew
PostPosted: 15:04 - 18 Apr 2006    Post subject: Reply with quote
Yup, thats the bugger. Use about 1/3 bottle to a tank of gas on a bike. I think it's about $15/bottle here in the US.
It actually does what it says it does. Thumbs Up Just be sure to get the one ya posted, the concentrate version.
The last post was made 19 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 126.18 Kb
