| greatmoorred |
 greatmoorred Nearly there...
 Posted: 10:23 - 17 Apr 2006 Post subject: Redex. |
Now i was always a big fan of redex when i was younger, and used to treat my knackered old fiestas to it.
Question is, can i put it into my bandit ?
Its got carbs as its quite old, and it seems to be burbling ( ! ) a bit when you drop the revs down, at a set of lights for instance. I was just wondering if a shot of redex would clear out the carbs a bit. |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
 Posted: 10:38 - 17 Apr 2006 Post subject: |
Engine is an engine, so won't hurt to try it in the Bandit!  ____________________ aKa: Ducky |
| DynaMight |
 DynaMight World Chat Champion
| greatmoorred |
| Teaman |
 Teaman World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 15:26 - 17 Apr 2006 Post subject: |
| phantomtek |
 phantomtek Lil Joe Tek
 Posted: 15:28 - 17 Apr 2006 Post subject: |
ZRX61 - Hater of Redex.
I used Redex, seemed to work. Expensive though. |
| Flip |
 Flip Super Spammer
| Mark_petty |
 Mark_petty Brolly Dolly
 Posted: 15:45 - 17 Apr 2006 Post subject: |
My bandit was sat for ages (1999 reg and only done 3k miles )
What I did was changed spark plugs, new oil, new oil filter, new fuel, drained old fuel from carbs, new air filter, charged battery and also added some fuel additives and that seemed to do the trick then went for a long ride .
It now starts first time (even if left for days without any use) It also idles fine.
It well worth doing it if its been sat there for a while ____________________ [Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed] |
| ZRX61 |
| phantomtek |
| DucatiEVO |
 Posted: 16:22 - 17 Apr 2006 Post subject: |
Automatic Transmission Fluid
They're both red I suppose....  ____________________ aKa: Ducky |
| phantomtek |
 Posted: 16:30 - 17 Apr 2006 Post subject: |
| DucatiEVO wrote: |
They're both red I suppose....  |
Cheers  |
| Teaman |
 Posted: 16:35 - 17 Apr 2006 Post subject: |
blood is also red ,
or tomato sauce  ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| TOM M |
 TOM M World Chat Champion
 Posted: 16:58 - 17 Apr 2006 Post subject: |
What is redex and what does it do??  ____________________ Now owner of a 1200 Bandit |
| phantomtek |
| TOM M |
| phantomtek |
| greatmoorred |
 Posted: 17:30 - 17 Apr 2006 Post subject: |
or take the plugs out and pour it into the cylinder, leave it for a few minutes, pop the plug back in and then start it up.
Best to do this when your parents/neighbours have just hung out a whites wash on the washing line.  |
| phantomtek |
| Teaman |
 Posted: 18:01 - 17 Apr 2006 Post subject: |
it removes all the shite on the valves, stops sticky valves, if you do the carb injection you use more aswell but that does the same thing, just gradually, and if you mix it in the fuel it will do the needles and carb valves,
it doesnt improve fuel consumption whist your using it as it burns hotter,
you shouldnt really need to use it in new bikes though unless they have done loads of miles, best to check what state your plugs are in before using it as it will burn off anything on them stopping you from finding out why you might need to be using it in the first place
i would check those, check the tank petrol filter, check the float bowls and see if the ht leads are hard before using it or your just throwing money away ,. ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
| MikeH |
 MikeH Brolly Dolly
 Posted: 18:11 - 17 Apr 2006 Post subject: |
When I got the XJR a couple of weeks ago it used to start missing if you ran it over a ton for more than a minute or two, I put half a bottle of Redex in two tankfuls and it now runs sweet as a nut.
Gets my vote
It's worth getting the carbs balanced too, it makes a huge difference.
Mike  ____________________ Busa Junkie |
| ZRX61 |
 Posted: 19:50 - 17 Apr 2006 Post subject: |
If you want to put some stuff in the fuel to clean up the valves etc theres one thing thats WAY above the others: Techron from Chevron. Don't buy the diluted stuff, get the full monty.  |
| DucatiEVO |
| ZRX61 |
 Posted: 15:04 - 18 Apr 2006 Post subject: |
Yup, thats the bugger. Use about 1/3 bottle to a tank of gas on a bike. I think it's about $15/bottle here in the US.
It actually does what it says it does. Just be sure to get the one ya posted, the concentrate version. |
The last post was made 19 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
