Dropped your bike? How do you lift it back up?
Flying Dutchman
PostPosted: 13:21 - 19 Apr 2006    Post subject: Dropped your bike? How do you lift it back up? Reply with quote
I wanted to find out amongst you all if anybody ever had the mishap of dropping the bike, and how did you get the bike back up again?
Bearing in mind that some motorcycles do weigh up to 360 kilos this could not be an easy task to say the least!
Were you by yourself, did you get help from somebody in helping you to lift it,
What do you do if nobody else is around in the middle of nowhere?
What did you do?
Redd
PostPosted: 13:29 - 19 Apr 2006    Post subject: Re: Dropped your bike? How do you lift it back up? Reply with quote
Shocked yeah, but you take the passenger out the side-car before trying to lift it Wink
My XJ600 probably weights about 190kg. I've dropped it and had no problems picking it back up at all. Crouch down, turn the bars to full lock, get your hip against it, and use your legs Thumbs Up
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
mr.z
PostPosted: 13:32 - 19 Apr 2006    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=80177
As said, use your legs (anyone whos done any job will have been taught to lift loads with your legs) leg muscles are the bigest in the body for good reason Wink
Its not only the weight its the weight distrobution.. a top heavy bike is a bit harder work..
Itchy
PostPosted: 14:38 - 19 Apr 2006    Post subject: Reply with quote
But then Honda thought of that and was smart in that the Gold wing can pick itself up if you turn the bars and push a little using the reverse gear.
JeffT
PostPosted: 14:50 - 19 Apr 2006    Post subject: Reply with quote
I have 1 muscle bigger than my legs Wink
bish777
PostPosted: 15:00 - 19 Apr 2006    Post subject: Reply with quote
lift it as far as you canfrom the bars then get your hip in and shove it up!
GSXR1100J
innominate
PostPosted: 15:05 - 19 Apr 2006    Post subject: Reply with quote
I managed to lift my FJR back up after it fell directly on my legs.
I kicked the sidestand the wrong way and it just fell on me.
Sat on the floor with 200kg+ of bike resting on my boots.
Not too hard to pick back up, if your not a complete weakling.
I, as a responsible adult human being, will never concede the power to anyone to regulate my choice of what I put into my body, or where I go with my mind. From the skin inwards is my jurisdiction, is it not? I choose what may or may not cross that border. Here I am the customs agent. I am the coast-guard. I am the sole legal and spiritual government of this territory, and only the laws I choose to enact within myself are applicable.
Itchy
PostPosted: 15:10 - 19 Apr 2006    Post subject: Reply with quote
its about technique not brute strength , that UK woman weightlifter who went to the last Olympics wasn't too beefy.
And in my previous job I could shift a pallet on a little pump truck weighing 3 tons.
colin1
Captain Safety
PostPosted: 15:13 - 19 Apr 2006    Post subject: Reply with quote
I crouched by the side with the bars, held onto the the handlebar nearest the floor which was turnd in next to the bike, and straghtened my legs. When it was most of the way up, my hands moved to underneath the tank and i pushed it up the last bit of the way.
I think adrenalin flowing from the off helped.
You are not actually lifting 170kg or whatever, as a lot of weight is supported by the wheels which are resting on the ground. Initially you are supporting quite a lot of the weight, but as you lift, more of the weight is supported by the wheels, until its vertical and then its all supported by the wheels.
Sparks!
Sir Tart-a-lot
PostPosted: 16:57 - 19 Apr 2006    Post subject: Reply with quote
Don't be a poof, depending on bike anyway, anything up to a 600 sport bike is easy to pick up.. thous arent much harder.. im only 5" 6 and not particular strong too
This is how you do it Rolling Eyes
McGee
O RLY?
PostPosted: 17:00 - 19 Apr 2006    Post subject: Reply with quote
Thats exactly how I do it sparks Thumbs Up
Its pronounced Jixxer!
MRX Steve
PostPosted: 17:10 - 19 Apr 2006    Post subject: Reply with quote
Lean down, put hands on handle bars, lift. Your bike is now the correct way up. Works with mine, but then my bike does only weight like 100kg Laughing
Rieju MRX 50 Castrol Edition
Flying Dutchman
PostPosted: 18:30 - 19 Apr 2006    Post subject: Reply with quote
Thank you Sparks Laughing That was very usefull to watch! Thumbs Up
Mrs Kickstart
PostPosted: 18:34 - 19 Apr 2006    Post subject: Reply with quote
Hi,
Take off hemlet, smile, watch several men struggle to pick it up.... works nearly every time Very Happy.
On my own put the steering lock on an lift (put its only a GPZ or AF1) I have tried this with I think with the anything heavier I would have to wait for plan 1 to work.
Regards
C
Help fight the safety camera partnerships Twisted Evil -- www.pepipoo.com
Dom_
Points Mean Prizes
PostPosted: 19:49 - 19 Apr 2006    Post subject: Reply with quote
Dropped an old gsxr1100 at work, i am not hugely built as some of you may know (5'8") picked it up no probs.
Just bend ur legs next to it, grab it and lift up using your legs.
hellkat
PostPosted: 20:03 - 19 Apr 2006    Post subject: Reply with quote
I've got no upper body strength, despite my size, I'm as weak as a kitten, so ...
I just cry a bit, or maybe look girlie and helpless.
Usually some bloke comes along and picks it up for me.
*shrugs*
DynaMight
PostPosted: 20:19 - 19 Apr 2006    Post subject: Reply with quote
*shrugs*
Doesnt always work, my girlfriend dropped her bike on the ice around the corner. early morning in the middle of the road, some guy walks past with his dog, theres another guy about 2m away de-icing his car!! no-one offered. I had to run all the way around the corner to pick it up. Neutral
Flying Dutchman
PostPosted: 20:20 - 19 Apr 2006    Post subject: Reply with quote
*shrugs*
That's the stuff Laughing Laughing
Nb
PostPosted: 20:24 - 19 Apr 2006    Post subject: Reply with quote
I dropped mine a few weeks ago, picked it up no sweat due to the embarrassment and anger. Embarassed Just grabbed the bars and heaved. Laughing
SoND
PostPosted: 20:56 - 19 Apr 2006    Post subject: Reply with quote
I just grab the handlebar and lift it. Easy when you've got a 125 Wink
Although one time it fell on top of me and my foot was stuck. 2 women came over and picked it up off me Laughing Embarassed
GearboxGeezer
PostPosted: 21:55 - 19 Apr 2006    Post subject: Reply with quote
I just got a rather funny but also disturbing image in my head of a naked man picking his bike up...
kawakid
PostPosted: 22:37 - 19 Apr 2006    Post subject: Reply with quote
I just pulled mine up, no problems, used to lifting things.
I've a twin and a 4.
Flying Dutchman
PostPosted: 00:57 - 20 Apr 2006    Post subject: Reply with quote
Twisted Evil Don't take this the wrong way, may be it was the erection that pushed the bike up that you got when the two women came over to "lift it"? Twisted Evil
St0rmer66
PostPosted: 01:17 - 20 Apr 2006    Post subject: Reply with quote
I had a bit of an off in December last year, I just got up and picked it up! I think it was the adrenaline doing the work though because the next day my arms were aching like hell! Think I pulled a muscle picking it up too fast Embarassed Rolling Eyes .
The other time I had to pick it up was when I left it in the school car park at night (was doing an all night charity football event!) and some chav had came over and taken it off the stand just to knock it over! Evil or Very Mad . I was really pissed off and ended up picking it up on the opposite side of the stand, then letting go once I had it vertical only for it to fall onto the other side because the stand was still down Embarassed . The second time pulling it up seemed a lot harder! I'm 6'1" and built like a ... rake! Razz .
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
Bendy
Mrs Sensible
PostPosted: 17:12 - 20 Apr 2006    Post subject: Reply with quote
Bloke dropped his 'storm right in front of me at Snett and looked mortified when I ran over to help him lift it back up. Laughing
Personally, I'd go with the 'backwards lift with your legs' method if it came down to it, but the only time I've ever dropped it on the road the guys had her back on her wheels before I'd even extricated myself from underneath.
If lifting by myself failed, I'd just accost someone and get them to help me, they might not run to help initially but I'm sure if you asked most people wouldn't mind. Or am I being to optimistic?
The last post was made 20 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 133.61 Kb
