Is this worth getting?
Jon
Anyone for donuts?
PostPosted: 18:18 - 17 May 2003    Post subject: Is this worth getting? Reply with quote
I lost my disc lock and noticed Big Bike Book are selling the:
OXFORD ENIGMA DISC LOCK £61.99
Now £39.99
"The ultimate disc lock is approved to the highest standards by Sold Secure and Thatcham - insurance discounts are available as a result"
Anyone got one? Worth the cash?
https://www.bigbikebook.com/order.asp?Page=/specials.asp&section=0&subsection=0&Price=0&Start=25&Keyword=&SearchDescription=&Zone=0&product=818
Scotty
Scooter Boi
PostPosted: 18:27 - 17 May 2003    Post subject: Reply with quote
I prefere the old stick in the wheel.
To be honest i'm not a fan of disk locks, i'd probably forget its their.
But all in all there probably worth the money!
Regards
Scott
TiN
Pocket Tin
PostPosted: 18:55 - 17 May 2003    Post subject: Reply with quote
Consider getting a Grip Lock:
https://www.pjbsecurity.fsnet.co.uk/products/disclocks/pjb706.htm
I've got one and it works a treat, and you can't really ride away without taking it off!
It also bleeds your brake system if left on for a while, so be aware when you use your brakes after taking the lock off...
TiN
dotgems.net
Crazy Manx Man
The Fly Swatter
PostPosted: 19:17 - 17 May 2003    Post subject: Reply with quote
Consider getting the pimp lock, found here www.ineedpimping.com
It works wonders a tieing all the bitches up
Too Fast For Even The Plod To Keep Up With
Micro Monkey
PostPosted: 19:31 - 17 May 2003    Post subject: Reply with quote
I bought an oxford monster chain and enigma disk lock off ebay for £53, both these are brand new and thatcham approved. The padlock is absolutely massive so no one will ever nick your bike but before you buy from riossi have a look at ebay as there is a bloke on there that must work for oxford products (sihall2000) as he is always selling oxford security (he currently has 2 monster disk locks at £29, This is the new improved enigma by the way).
If your worried he might be dodgy, he has a rating of 1626 !
Phoenix
Twisted Firestarter
PostPosted: 21:51 - 17 May 2003    Post subject: Reply with quote
I got an Oxford Monster off him for £40, took a while to arrive but it's a £180 chain I believe. I use a disclock when I park at college, I don't forget it usually, sometimes I do, but I always park nose in so I don't ride off with it on.
Ant
PostPosted: 23:34 - 17 May 2003    Post subject: Reply with quote
that looks quite good alough if it bleeds the brakes would it damage the clutch? (at least itd stop your bike rolin away too)
and
you can get them disk locks with a cord that attaches to your bars to remind you!!
PostPosted: 23:42 - 17 May 2003    Post subject: Reply with quote
I'm always a bit worried with those locks someone will just cut the brake hose Confused.
It doesn't actually bleed it as such, it does compress the fluid, which hels air bubbles to join/rise.
It doesn't touch the clutch... and if it did, it'd make it worse because it would be holding it in Confused
Scotty
Scooter Boi
PostPosted: 23:53 - 17 May 2003    Post subject: Reply with quote
I'd also wonder why that was there and probably yank it till it comes off, lol.
Almost as comical when i left the bike at college and came back to see two walkers crips packets on the wing mirrors. oh i wish i had a camera for that one.
Regards
Scott
Ant
PostPosted: 09:58 - 18 May 2003    Post subject: Reply with quote
i meant if you put it on the other side of the bars, to save damaging your brakes
TiN
Pocket Tin
PostPosted: 10:06 - 18 May 2003    Post subject: Reply with quote
They can cut the brake hose anyway, or just push your bike over in frustration...it's a visual deterrent and could make thieves aware that your bike is actually locked.
I thought that the whole point of bleeding was to force air out/through the hose?
Eh? You can fit the lock onto either side of the bike, and there's a slider that you can adjust so the lever can be closer or further away from the handlbar. Even if you have a habit of holding in the clutch, you *will* notice a great big yellow thing getting in your way Razz
TiN
dotgems.net
PostPosted: 10:13 - 18 May 2003    Post subject: Reply with quote
My point was that they could then steal it they cut the brake hose, which they couldn't with a disc lock.
I've allways thought of 'bleeding' as forcing fluid out of the nipple (thus bleeding because there's fluid leaking out Smile)
But *Why* would you want to fit it to the clutch? Okay, it would mean they would have trouble actually using the engine, but would mean they wouldn't even have to put it in neutral to push it away Very Happy
TiN
Pocket Tin
PostPosted: 10:15 - 18 May 2003    Post subject: Reply with quote
So what was your original point about then?
TiN
dotgems.net
TiN
Pocket Tin
PostPosted: 10:19 - 18 May 2003    Post subject: Reply with quote
<addition>Oh, and fair point about cutting hose and nicking bike, but:
1.) If they're willing to nick the bike without brakes, then they've probably got a van (or suicidal) anyway, so a disc lock would be useless anyway in that situation.
2.) Unless the disc lock is very clearly visible, then there's that chance of the theives attempting to push your bike away, only to drop it once the lock hits the wheel or whatever.
TiN
dotgems.net
PostPosted: 10:29 - 18 May 2003    Post subject: Reply with quote
If the van isn't right there it's a whole load more hassle and dodgy to carry the bike down the block then push it IMO
True, though.. I'm just thinking along these lines because a friend had an attempted theft on his disclocked bike by some pikeys... really knackered up the discs, but they didn't get the bike.
Scotty
Scooter Boi
PostPosted: 10:46 - 18 May 2003    Post subject: Reply with quote
Well a brake disk is alot cheaper to replace than an entire bike really...
Regards
Scott
Doddmaster
PostPosted: 10:49 - 18 May 2003    Post subject: Reply with quote
I can't be bothered with disc locks, even if you have a disc lock it is only going to take 2 blokes and a van to steal the bike
Phoenix
Twisted Firestarter
PostPosted: 11:58 - 18 May 2003    Post subject: Reply with quote
exactly, so why bother using a disclock at all, let's make it easier for them Rolling Eyes
PostPosted: 12:07 - 18 May 2003    Post subject: Reply with quote
A disc lock should prevent your average pikey theft though Smile
Jon
Anyone for donuts?
PostPosted: 16:09 - 18 May 2003    Post subject: Reply with quote
Interested in the Grip Lock. May just get a cheap disc lock now.
Danny
Ask Me About Stoppie School
PostPosted: 19:21 - 18 May 2003    Post subject: Reply with quote
Too bad you were not at the BMF show today, there were some mega cheap disk locks there and they were quality Oxford ones.
I would advise using a chain anyway, then it is much more difficult for them to push it into the back of a van Very Happy
Jon
Anyone for donuts?
PostPosted: 19:40 - 18 May 2003    Post subject: Reply with quote
I've got a chain, just need a disc lock for when I park up outside a mates house or something (you know what pikeys are like)!
The last post was made 23 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 118.14 Kb
