| mirax |
 mirax Scooby Slapper
 Posted: 17:43 - 02 May 2006 Post subject: name that noise |
what the hell is making this noise of my vfr400 (the ticking noise you can hear) or do all of these bikes do it. the bikes running ok apart from a bog down if you fully open the throttle from first (gudders a bit) while doing this, apart from that its ok. note the carb hunting tho.
please help its driving me  |
| McGee |
 McGee O RLY?
| map |
 map Mr Calendar
 Posted: 17:47 - 02 May 2006 Post subject: |
Can't listen at the moment.
However, the symptoms you describe I'd be thinking tapet (i.e as McGee said, valve) adjustment plus syncing the carbs. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| craigs23 |
 craigs23 Mr Muscle
| Shaun |
 Shaun Likes 'em bent
| 0ddball |
 0ddball World Chat Champion
| mirax |
| map |
 map Mr Calendar
 Posted: 18:19 - 02 May 2006 Post subject: |
| tony532 |
 tony532 World Chat Champion
| ram_doom |
 ram_doom World Chat Champion
 Posted: 18:26 - 02 May 2006 Post subject: |
Omg that video is like seeing from the viewpoint of some mutant killer b-movie bee's flying around trying to get into the fairing...
I'd go with valve clearance's ____________________ TL1000s, KDX200 |
| geordiecbrblo... |
 geordiecbrblo... Trackday Trickster
 Posted: 18:37 - 02 May 2006 Post subject: |
Hmmmm does the noise alter if you pull the clutch in and rev?  |
| mirax |
| Flip |
 Flip Super Spammer
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 21:03 - 02 May 2006 Post subject: |
| NSR Mick |
 NSR Mick World Chat Champion
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 21:21 - 02 May 2006 Post subject: |
Sounds like the starter isn't disengaging and it's being spun up. Other than that, i thought my bike sounds comical!
On that note, never put "comical" into google images search.
I'd like to point out that i don't work on four strokes.  ____________________ "because one stroke isnt enough and four strokes waste two" |
| Flip |
 Flip Super Spammer
| mirax |
 Posted: 22:06 - 02 May 2006 Post subject: |
supose yeah does sound a bit like a sewing machine at times
would the valve cause the bike to hunt ???
rofl at that pic  |
| McGee |
 McGee O RLY?
| mirax |
 Posted: 22:17 - 02 May 2006 Post subject: |
12 bore i think ,
no seriously if the valves need adjusting would it cause the bike to rough idle? |
| McGee |
 McGee O RLY?
 Posted: 22:19 - 02 May 2006 Post subject: |
Not related but I got a mitsibushi colt which valves are all messed up, it wont idle tidy and it wont pull of tidy, shudders not matter how much throttle you give it.
Also gets sh*tty mpg
So maybe that is the proplem like I said earlier or your down pipes are farked.
How many miles has your bike got and has it had a major service and had them adjusted ? ____________________ ◙◙► K6 GSXR 600 ◄◙◙◙◙► K5 GSXR 1000 ◄◙◙◙◙► K5 GSXR 600 ◄◙◙◙◙► 96 RF600r ◄◙◙
Its pronounced Jixxer! |
| mirax |
 Posted: 22:28 - 02 May 2006 Post subject: |
Not sure when they were last done, ive had the bike a year now and its done 36,000km (22 369 miles). its been doing it for a little while now havent had time to sort it as it my only for of transport to work. but i really need to get to the bottom of the cause before it becomes a problem might see if i can pop down to honda tomoz and let them have a listen  |
| Whosthedaddy |
| tony532 |
| element |
 element World Chat Champion
 Posted: 02:01 - 03 May 2006 Post subject: |
that noise sounds scarily like my speedy 100 at the minute .. Ill record a sound and post it up tomoz cos its really pissing me off now since I cant find out what it is.. Very unlikely to be the same problem since my bike has nothing to compare against yours.. My bike has also feels like its lost a little power in the mid-range since ive replaced a worn belt and rollers in an attempt to cure the noise but that could be answered by the fact the rollers are heavier and the old belt im starting to wonder if it actually was a kevlar one... Im starting to think its worn/dry crank bearings else the clutch or piston is the only thing left that is constantly moving .. Hoping its not the crank bearings but Im guessing Id know if it was?
could you describe it as shaking a bearing in a full spray can? ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
The last post was made 20 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
