Economy riding.
EDBANGER
PostPosted: 14:58 - 15 May 2006    Post subject: Economy riding. Reply with quote
So then, whats the best gears and speeds to use to get the most out of your petrol?? Times is hard Shocked
If you can't spot the sucker in your first half hour at the table, you are the sucker.
Sephiroth
PostPosted: 15:00 - 15 May 2006    Post subject: Reply with quote
Hmm, push your bike down the road and hope some kind person gives you petrol.
Keep doing that Smile.
On a more serious note (slightly), turn your engine off when at lights for more than 20 seconds, ride in a higher gear etc...
I'd go for the free petrol idea myself Thumbs Up Mr. Green.
killa
Won't Shut Up
PostPosted: 15:08 - 15 May 2006    Post subject: Reply with quote
Go out looking for 80’s fords, siphon some petrol from them.
Bendy
Mrs Sensible
PostPosted: 15:30 - 15 May 2006    Post subject: Reply with quote
I got insane mileage from my CBR when sitting on the motorway at about 85 for ages (was about 7000rpm and I was barely accellerating or decellerating at all.
Reserve light usually comes on at about 130 with normal riding. Pulled into the petrol station showing 165 and still only managed to get £12 into it, so there was probably enough left to hit 200 if I'd kept cruising. Cool
So in short, cruising good, stop/go bad.
veeeffarr
PostPosted: 15:41 - 15 May 2006    Post subject: Reply with quote
Speed: 70mph
Gear: Neutral
Coasting 20 miles: FTW
Rookie
PostPosted: 15:50 - 15 May 2006    Post subject: Reply with quote
Unless you were stopped for over a minute or so, I don't think that would be beneficial. Starting the bike uses a lot of fuel.
Also riding in a higher gear is good, if you're not labouring the engine. For example, doing 70 in 4th at 6k or so your fuel efficiency will be better if you're doing 70 in 6th, at 3.5k or whatever. But 30 in 6th, doing 1.5k is going to be very poor fuel efficiency.
The best tactic is to avoid hard acceleration and braking. If you see a junction or a hard corner coming up, just let the bike coast to it, instead of riding all the way up to it, and then braking. Apparently riding your bike like this gives you around 30% more mileage for the same amount of fuel. That's why cruising for long periods has this effect. In my car, I found I was getting about 200 miles to the tank (£35. Rolling Eyes ) When I went up to Nottingham, not stopping once on the way or the way back, I got about 330 miles to the tank.
mr.z
Oddly just came back from a rally yesterday fully loaded.. my tank usually shows empty when i get to 100miles on the odometer.. but its still at halfway and ive done nearly 80 since the fillup on the way home...
Simple
PostPosted: 17:00 - 15 May 2006    Post subject: Reply with quote
short shifting rather than revving out the engine before changing gear
constant throttle is usually best as opposed to stop start commuting.
I found with the NSR it was thirstier cruising at 80mph than hooning arund town, GPZ is the opposite it likes to short shift, low revs, pootling about. still out accelerat cars off lights etc unless they are attempting a race Rolling Eyes
Also make sure your chain is lubed up and correctly adjusted,
your brakes arn't binding on the disks /drum.
don't forget to go for a crap in the morning before you set out (weight saving and cheaper than carbon fibre) Laughing
simple
Insta - FemFeral
Itchy
PostPosted: 17:05 - 15 May 2006    Post subject: Reply with quote
adopting a racing crouch everywhere? , wearing slick clothing , tieing up all lose straggly clothing and fastners,
losing weight
go slow
barely use the choke
set your carb to go lean (watch out for overheating problems + need new plugs regularly).
ride dangerously * (slip stream off lorries or skitch off them if you dare)
remove everything that serves no purpose , ie foot pegs for pillions
bar ends (watch out for white vibration finger and carpel tendon syndrome)
anticipation , using engine braking vs brakes , since shifting down turns your speed into revs rather than heat in the brakes.
using the tab on your helmet straps so the thing does not hand down and cause drag.
more later.
kawakid
PostPosted: 18:32 - 15 May 2006    Post subject: Reply with quote
Get about 76mpg at a steady 70 for an hour.
75miles cost me about 4.28
But start stop riding then its not as good.
I've a twin and a 4.
Simple
PostPosted: 19:35 - 15 May 2006    Post subject: Reply with quote
Itchy wrote:
remove bar ends (watch out for white vibration finger and carpel tendon syndrome)
more later.
I have both of those, and my bar ends are still attached Crying or Very sad
maybe if I remove them it will go away? Confused
Insta - FemFeral
EDBANGER
PostPosted: 19:59 - 15 May 2006    Post subject: Reply with quote
Simple wrote:
more later.
You need heavier bar ends.
Simple
PostPosted: 20:01 - 15 May 2006    Post subject: Reply with quote
It has huge ones as is, stock gpz ones... other than tie bricks to the bars..
though that would help limit the damage when dropped...hmm Thinking
Insta - FemFeral
swanny
PostPosted: 01:01 - 16 May 2006    Post subject: Reply with quote
getting roughly 80mpg out of my er5.. riding away from lights and not racing it.. coasting into lights and sticking to speed limits in hihgest plausible gear..
M SWANNY.. see a sig !
The last post was made 20 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 84.8 Kb
