What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 53, 54, 55, 56, 57  Next
blurredman
PostPosted: 08:47 - 29 Apr 2025    Post subject: Reply with quote
Grumpy Grandad wrote:
Very Happy Thumbs Up I agree ....Hoard ...Hoard ... Hoard Chequered Flag
Hmmmm... maybe I will just keep all the crap specifically to prevent someone else 'enjoying' it Laughing
blurredman
PostPosted: 08:45 - 01 May 2025    Post subject: Reply with quote
Fitted new inner (and outter) seal to master cylinder on ETZ250. Brake lever no longer creeps. Finally got around to fixing the brake light switch too. Cool
blurredman
PostPosted: 10:00 - 03 May 2025    Post subject: Reply with quote
Finally got around to changing clutch plates on ETZ251, and replaced gear change shaft o-ring oil seal whilst the clutch cover was off as that was leaking. Now need to fix leaking core plug, and also take piston out and see whether anti-rotation pins for the rings aren't recessed in the cheapo pistons (this happened on another bike of mine on a cheapo piston thankfully without too much damage).
PostPosted: 10:34 - 03 May 2025    Post subject: Reply with quote
Thoroughly tested my brakes after the bike's service when some c*nt cut across me to get to their oh so important turning. Less SMIDSY and more "if I don't see you, you're not really there" - Schrodinger's Motorbike or some such Sad
recman
PostPosted: 20:48 - 04 May 2025    Post subject: Reply with quote
I hope there was plenty of futile fist shaking.
DaddyStu
PostPosted: 12:55 - 10 May 2025    Post subject: Reply with quote
Spray painted my red hand guards black - to mask some damage. Looks alright. Sprayed up the coolant pipes too as corrosion was starting to kick in. Rustoleum works wonders!
Daddystu
blurredman
PostPosted: 07:46 - 13 May 2025    Post subject: Reply with quote
Bike wouldn't start yesterday- did 110 miles though on Sunday no problem. Felt like ignition - no kickback - and I see there's no spark at the points. They had worn off square and the spark was intermittent at best. I used my tiny file to file the contacts square with eachother again and we're back in action.
recman
PostPosted: 16:18 - 13 May 2025    Post subject: Reply with quote
A deep clean.
I'm planning on a spin with an ex-colleague in the morning to consume a small amount of bacon and he's under the illusion that I take better care of my bike that I actually do.
The last couple of days have caked the bike in all manner insect life so a scrubbing it got.
I bought a pistol gun for the jetwash which worked really well. It had a nice wide spray setting which while feeling powerful, was actually quite gentle.
to v or not to v
PostPosted: 21:39 - 13 May 2025    Post subject: Reply with quote
woke the bike up from its winter hibernation and went out for a couple of hours.
it still takes me by surprise just how much fun the bike is after ive not ridden it for a while.
Moto Guzzi V7.
blurredman
PostPosted: 08:09 - 14 May 2025    Post subject: Reply with quote
Spark has gone again to-day Rolling Eyes Crying or Very sad
PostPosted: 11:50 - 14 May 2025    Post subject: Reply with quote
Once you start filing points, you know they're on limited time.
I'd suggest fitting new with a new condenser too as this help suppress
the arcing that burns the feckers out
blurredman
PostPosted: 14:46 - 14 May 2025    Post subject: Reply with quote
Potentially. I believe (but not quite sure) this is an factory set of points which are obviously far better quality than the crappy aftermarket stuff. I put this set of points on 12k miles now which is fairly reasonable before any sort of issues. I've barely looked at the things let alone maintained them.
So tonight I've done some fiddling with some washers to get the pivoting contact to land even more squarely (perfectly infact) on the static contact- and filed them really nicely. We'll see how this goes. I did test the condenser (admitably cold) but that tested fine and the symptoms did not indicate any failure for this case - I have no reason to even think about replacing that test or no test. I'm not one to just change components without making sure they are defective. And as I say aftermarket points are crap- friend of mine had the heel break on two sets within 30 miles. Good job he had two spare...
Additionally, because this bike let me down again - I went to work on the etz251 to-day - which I then got MOTed. It would be nice to have some backup machines. Monday I tried the TS185 too but it had a solidly stuck throttle when I tried to use it as a backup so as well as fixing the etz250 I fixed the Suzuki. Took carb apart this evening and cleaned it all out as it was full of crap, compressed air etc. So- now I got two backup bikes working.. I might need them too Rolling Eyes
Zen Dog
PostPosted: 12:42 - 15 May 2025    Post subject: Reply with quote
Had the back wheel off the CBF to see I could find anything causing the wobble, but I didn't find anything that seemed an obvious problem, and after putting it all back together it's still the same. Confused
Current - '94 VFR750FR (Dead), '00 VFR800FI, 2011 CBF125 Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
Robby
Dirty Old Man
PostPosted: 06:43 - 16 May 2025    Post subject: Reply with quote
I changed the battery on my Guzzi. First time I've owned a bike long enough to put a second battery in it.
So I think it's time to sell it.
PostPosted: 09:59 - 17 May 2025    Post subject: Reply with quote
Took the Skorpion out for a little test ride. Got to a corner and it felt like it wanted to go straight on..
..and these things are supposed to be a model of great handling..
Checked tyre pressures - all spot on. Thinking
sickpup
Old Timer
PostPosted: 13:33 - 17 May 2025    Post subject: Reply with quote
Replaced rear wheel on my main Deauville as the original was badly corroded on the bead seat and wouldn't hold pressure.
Cleaned up some connections in the loom on the ER6 as the headlight and horn had failed.
MOT'd the Mummy mobile. Need to order a new wheel as one is out of round and a new wing liner for the front left.
PostPosted: 15:21 - 17 May 2025    Post subject: Reply with quote
Is it something you could throw a tube in, keep as a backup?
hellkat
PostPosted: 23:37 - 18 May 2025    Post subject: Reply with quote
Started up the Suzuki for the first time in almost a year
(well ok, I didn't - my ex did, one of his chores whilst doing my front garden gate Laughing )
Took a while and some jump leads, but I think he flooded the engine cos the choke is a bit emotional.
But when he finally got it started, petrol started pissing out the side Thinking So we switched it off in rather a hurry.
Not sure if this is something to do with flooding the engine, but I think I will get the bike shop to pick it up, rather than risk having it blow up in a fireball when I fill it up at the petrol station Shocked
PostPosted: 09:24 - 19 May 2025    Post subject: Reply with quote
If it runs carbs the floats are probably stuck. Magicians tap the carb bowls with a screwdriver and presto-bongo! the leak stops Smile
to v or not to v
PostPosted: 09:26 - 19 May 2025    Post subject: Reply with quote
what are you thinking of replacing it with?
Moto Guzzi V7.
PostPosted: 11:15 - 19 May 2025    Post subject: Reply with quote
This is worth a try (assuming one or more is overflowing) but if its one of the middle ones tappety tap access might be tricky.
PS Ex needs dumping again if not aware of this trick.
blurredman
PostPosted: 13:54 - 19 May 2025    Post subject: Reply with quote
If it is running reasonably enough, you can also turn off the petrol tap and only turn it back on when the bike is struggling for fuel- then when it starts overflowing turn the tap off again. Sometimes that clears up float hangs - may require a few cycles.
Grumpy Grandad
PostPosted: 16:41 - 19 May 2025    Post subject: Reply with quote
Thought I'd start trying to get some large dents out of my 550s Fuel Tank by pressurising it with a foot pump.
Dont panic I didn't blow the seams, didn't get that far!
Managed to drop a large bolt into the tank Brick Wall
Learnt the Tank has a lip on the inside so you can't simply turn it upside down and shake it ..... Now fishing with a magnet on a bit of string!
Cheers Chequered Flag
Life may begin at 30, but it doesn't get interesting until about 75 mph.
panrider_uk
PostPosted: 12:32 - 20 May 2025    Post subject: Reply with quote
I washed it Shocked
Current bikes: Hondas - Forza 750, ST1100 Pan European
PostPosted: 18:00 - 20 May 2025    Post subject: Reply with quote
First MoT for the Husky. "I wish they were all as easy as this", said the MoT tester Smile Just the customary advisory for "noisy exhaust" Very Happy
Page 54 of 57
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.68 - MySQL Queries: 13 - Page Size: 137.99 Kb
