What have you done to your bike today?
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 55, 56, 57, 58  Next
PostPosted: 18:37 - 14 Jul 2025    Post subject: Reply with quote
Had a queue of things for the GT.
I think either the kickstarter or main sprocket seal has gone, quite common on these engines. There's still some oil spraying off the chain and it's not letting up so probably not down to an over-oiled chain. Anyhoo, getting to the seals means taking the right hand cover off so may as well do an oil change. And if the cover's off may as well investigate the "anti-vibration plate" Hitchcocks sell. 50/50 whether it's just snake oil from the various opinions in various forums. Worth a go and an easy job with the right tools.
One seal is behind the main sprocket. For some reason I made the mistake of glancing at a quick Google search (possibly the AI) saying a 36mm socket was needed. Wrong! 46mm, which I don't have Rolling Eyes Now to drum my fingers while I wait for one ordered from eBay.
Grumpy Grandad
PostPosted: 15:32 - 16 Jul 2025    Post subject: Reply with quote
Went to Weymouth for a Dorset Apple Cake flavoured Icecream.
Then went onto West Bay (Bridport) for a cup of Tea along the coast road. Lovely ride and No Bloody Camper Vans blocking the road. Thumbs Up
Quick 100 miles and that OLD suspension is definately testing this OLD body. Sad
Changed the Fork Seals recently. Fronts not too bad. Think I'll have to save up and get the Monoshock sorted.
Cheers Chequered Flag
Life may begin at 30, but it doesn't get interesting until about 75 mph.
to v or not to v
PostPosted: 17:40 - 16 Jul 2025    Post subject: Reply with quote
was the ice cream worth it?
Moto Guzzi V7.
Grumpy Grandad
PostPosted: 18:06 - 16 Jul 2025    Post subject: Reply with quote
Definitely was mate Thumbs Up
Felt a bit of a Twat sat there with all the gear on amongst a lot of Grockles in swimming costumes. Rolling Eyes
Makes a change from riding 50 miles for a bag of chips though Very Happy
PostPosted: 22:25 - 18 Jul 2025    Post subject: Reply with quote
I finished replacing the kickstarter and main sprocket seals today. Obviously 5 seconds with the Li-Ion impact driver and the previously mentioned 46mm socket sorted things out Smile
As it turns out the final kickstarter seal was absolutely caked with oil, the main sprocket seal not so much. I'd did weigh up "if it's not broke don't fix it" but that sounded weak. I have the seals literally in my hand, let's do this thing! Cue half hour of quietly swearing to myself trying to get the old seals out Rolling Eyes I did manage it in the end without fucking shit up, very happy Very Happy
However...
The main sump plug threads are 50% fucked. There's quite a lot of thread left so I did weigh up getting a longer sump bolt but M14 by 1.25mm pitch is surprisingly difficult to get a hold of compared to M14 by 1.5mm.
I have a thread repair kit on order. I went with the "spark plug style" over the traditional helicoil as the former has a bit of a lip. It's not massively important given it's only hot oil it has to hold back and no real pressure to speak of.
jeffyjeff
PostPosted: 01:42 - 19 Jul 2025    Post subject: Reply with quote
Easy-X wrote:
...I have a thread repair kit on order. I went with the "spark plug style" over the traditional helicoil as the former has a bit of a lip. It's not massively important given it's only hot oil it has to hold back and no real pressure to speak of.
Alternatively, I've used Fumoto valves on VFR's and BMW boxers with success. If the drain plug is somewhere along the centerline of the bike, you needn't worry about reduced ground clearance. If the bike does mileage off road, that might be an issue. If you have enough threads to achieve a leak tight seal, the Fumoto valve need never be removed.
PostPosted: 11:25 - 19 Jul 2025    Post subject: Reply with quote
The sump bolt on the GT is at the lowest point in the engine but not necessarily the lowest point on the bike when I think of the frame and exhaust Thinking
Again, M14 x 1.25 isn't common so I'd probably need to import one from the US or gamble with a knock-off from China Sad
jeffyjeff
PostPosted: 11:56 - 19 Jul 2025    Post subject: Reply with quote
Easy-X wrote:
...Again, M14 x 1.25 isn't common so I'd probably need to import one from the US or gamble with a knock-off from China Sad
A quick check confirms the M14x1.25 Fumoto valve is available if you want to go that route. Fits the Ford Powerstroke diesel engines 6.0, 6.4, and 7.3 Litre displacements.
https://www.ebay.com/itm/172656467832?var=0&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5338590836&toolid=10044&loc_physical_ms=87264&customid=60ff59ece35815c0e62f319761881781&gclid=60ff59ece35815c0e62f319761881781
PostPosted: 20:19 - 20 Jul 2025    Post subject: Reply with quote
I think I'll leave the fancy valve idea and just fix the threads but I'll give it serious consideration on my cars Thumbs Up
One thing of note: I pulled the sprocket and shifted the chain out of the way, the chain felt... lethargic. Not your typical stiff link problem but the whole chain just didn't feel as flexible as it should be Thinking
AFAIK it's whatever the brand Royal Enfield uses so nothing fancy. Surely the engine oil splattering on it from the previously leaking kickstarter seal wouldn't do any harm?
PostPosted: 19:30 - 23 Jul 2025    Post subject: Reply with quote
Tapped a new thread for the main sump plug. It was hard going to start with, I nearly lost hope TBH. Then I had my dinner and Round 2 went very easy. Bearing in mind it's something like an M16 being cut with the bike on the centre stand, I'm happy with how it went. The sump plug back in with a fresh copper washer, no one would ever know... till the next oil change anyway Smile
The previous owner gave me a box of bits with the bike including five RE branded oil filters, which was nice. I poured in roughly the right amount of oil and kicked over the engine a few times. After running for a few minutes the sight window was still showing empty Shocked Another 100ml though and it was just below the max mark, phew! I wouldn't recommend a Royal Enfield if you have anxiety issues Wink
to v or not to v
PostPosted: 05:52 - 24 Jul 2025    Post subject: Reply with quote
fitted an extender to the crappy little front mudguard. its still much smaller than id like!.
why is it only Enfield that seem to be capable of making decent front guards Mad
Moto Guzzi V7.
recman
PostPosted: 16:57 - 24 Jul 2025    Post subject: Reply with quote
What was the pitch for the M16 thread?
PostPosted: 17:15 - 24 Jul 2025    Post subject: Reply with quote
The original thread was M14 1.25mm so I'm assuming the drop in sleeve is something like M16 and 1.25mm. Visually the inside thread seemed the same as outside. Really I should have cut a M14 1.5mm replacement as that seems to be a very common sump plug size but straying from the OEM spec makes me irrationally uncomfortable Smile
In retrospect, the easiest solution would be bodging in an M14.1 oversized plug:
https://ae-pic-a1.aliexpress-media.com/kf/S515cd5a53c8d46b699451cdd0229d7b2r.jpg_220x220q75.jpg_.avif
blurredman
PostPosted: 10:06 - 01 Aug 2025    Post subject: Reply with quote
Don't they say it comes in threes?
The one car had to have new front brake pads and discs changed (£41.73) just last week.
The other car I have come to find yesterday after caliper disasembly needs new front pads (discs are fine, not warped or scored or lipped - asbestos pads you see) as brass rivets now touching disc, £8.48 for 4 new pads.
Also have to change rear shoes on ETZ300. £11. But will do that when I change the tyre as that's at minimum wear level now.
PostPosted: 17:32 - 07 Aug 2025    Post subject: Reply with quote
Bugger.
The sump plug had been bone dry since tapping the new thread. Went out on the bike today and parked up: drip of oil on the concrete Sad No worries, I never did it up tight anyway so I'll just give it a quarter turn and... fucked it completely Crying or Very sad Now it's dripping oil instead of just weeping.
I've set up a funnel and container under the bike for now. It'll take quite a while for over 2 litres to drip out at the current rate which will slow or even stop once the oil cools down. I'll drain it properly when I'm in the right frame of mind Neutral
Ho-hum, Plan B. After draining the oil I'll clean the area and jam in a new threaded sleeve with JB Weld in lieu of threadlock.
PostPosted: 15:20 - 10 Aug 2025    Post subject: Reply with quote
Attempt 2 at thread repair:
https://i.imgur.com/AIVbhRm.jpeg
Looks like I applied just the right amount of JB Weld and I'm feeling very confident the result should hold oil Smile
I've used the the original JB Weld - the "good stuff" - which unfortunately has a 4~6 hour set time and 15~24 hours for full cure but it is rated for relatively high temps and pressures. Way beyond what the oil can muster.
What I should do before throwing the oil back in is make sure the sump plug comes out without the thread sleeve coming with it but I've made the executive decision to make that a future me problem Wink
PostPosted: 19:56 - 10 Aug 2025    Post subject: Reply with quote
Easy-X wrote:
Bugger.
Have you just been unlucky or are all REs this, err problematic*?
PostPosted: 01:25 - 11 Aug 2025    Post subject: Reply with quote
Nah, just stripped threads from overtightening at some point in the past. Could happen to any engine case made of aluminium.
blurredman
PostPosted: 09:48 - 13 Aug 2025    Post subject: Reply with quote
The other day whilst going to Bristol I noticed that that batt/charge light was on dimmly whilst riding, but the thing was still charging when above 2k rpm - I have a voltage gauge fitted so could tell. Below 2k rpm the charge light was on fully instead of just dimly but no charging. (normally light isn't glowing even dimly unless idle is stupidly low (1k rpm) - typical idle 1,200-1,300rpm - and charge kicks in (when lights are off) at 1500rpm. The only annoying thing really was the high idle because of lack of draw dragging down the engine.
Because it was at least charging when I was on the go, I didn't look at it for a while but eventually opened up the alternator cover to find one of the three phase wires broken away from the spade terminal at the stator. I just soldered it back in and away we go! I like easy fixes.
to v or not to v
PostPosted: 20:35 - 15 Aug 2025    Post subject: Reply with quote
took the Thunderace in for an MOT.
mechanic was talking to me for close to an hour before he started the mot Laughing
its nice to find a garage with an old school, laid back atmosphere, where you can have a laugh and a joke, without worrying about someone getting their knickers in a twist .
Moto Guzzi V7.
blurredman
PostPosted: 11:45 - 18 Aug 2025    Post subject: Reply with quote
Depends, I had an MOT tuesday which I kinda didn't want to hang around because technically I was playing hooky Laughing Still ended up having a coffee and then picking up a random broken down biker to deliver him to his wife. Laughing
Yesterday: replaced the 10mm core plug on the 251. Old one had too deep a reach so was being pushed out by shaft it was hiding, which cracked the epoxy and lead to transmission oil leak. New one much shallower. While that was setting I filtered the gearbox oil that I did drain out in order to exact a proper repair and topped up the remaining that was lost.
Been for a few runs now already and so far so good no oil leaks.
Kawasaki Jimbo
PostPosted: 18:42 - 18 Aug 2025    Post subject: Reply with quote
I replaced the flexible rubber mount on the Kawasaki’s left front indicator. I’m not sure if I’d knocked it in the garage but I know they rot anyway. It involved taking the upper cowling/nose off and then removing some of the air intake ducting. Then there was some faffing when putting the cowling back on because the indicator bullet connectors became detached, plus the usual problems with old, hardened rubber mounts and rounded fasteners. I’ve ordered some replacements from Fowlers. The Cornwall/Cradley/Colchester Kawasaki websites all seem to have a glitch.
https://i.postimg.cc/x1g1yy5T/IMG-1910.jpg
Oddly, I found a couple of missing fairing-fastening components too. I’ve learned that if you find a mysterious object on the garage floor, keep it. In 6 month’s time you’ll notice something’s amiss somewhere and recall that thing you chucked away. The most recent one turned out to be a plastic end piece for the handle on the toolbox. It wouldn’t have been a great loss but still…
The Yamaha burns a bit of oil (I’m told they all do that, sir) and the oil level warning light was illuminating up the hill (but not down). I recognise it now so I don’t fret. Back home I may have overfilled it by 2-3mm above the maximum mark but I reckon it will be ok.
Next the EXUP valve wouldn’t stop initiating. Cable tension looked good so it was apparent that the valve had seized, -for the first time in 22 years. My mileage is down lately which probably explains it. All the stupid Allen bolts in that rust-prone location look rounded out but I got lucky with a wooden mallet and the valve freed up. Very Happy
Both bikes need an MOT. The tyres on the Yamaha are not only worn but are over a decade old. Pale
'93 Yamaha XJR400 grey import (p-ex’d), '99 Kawasaki ZX6R (nicked), another '99 ZX6R (still got it) and '03 Yamaha YZF-R1 (still got that too.)
jeffyjeff
PostPosted: 21:11 - 18 Aug 2025    Post subject: Reply with quote
On the EX500, Kawasaki fit a metal plate that sandwiches the rubber mount to the inside of the fairing. Problem is that plate fixes the turn signal mount rigidly to the fairing, resulting in turn signal breakage or fairing cracks when the turn signal suffers a blow. Removing the plate and fitting the turn signal stalk without it loosens the mount slightly. The turn signal will pop off if struck, hanging by the wires. You can then easily work it back in place, good as new.
Maybe your ZX6R has a similar mount on the front turn signals.
Kawasaki Jimbo
PostPosted: 21:32 - 18 Aug 2025    Post subject: Reply with quote
Yep, same as. It still has enough flex though. I crashed it way back when and the indicator survived so I’m happy with the design, I just think the rubber finally perished. I replaced the one on the right side a few years ago.
blurredman
PostPosted: 11:16 - 19 Aug 2025    Post subject: Reply with quote
And yet I just installed a tyre from 2012. Thinking Took it from the tip three years ago - finally have use for it.
If it was a case that your indicator stalk had brewers droop effect, could you not just swap it with the other side to eventually over time counter the effect?
Page 56 of 58
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 147.16 Kb
