Filling up a bike rad without getting an air lock?
PostPosted: 15:01 - 07 Feb 2011    Post subject: Filling up a bike rad without getting an air lock? Reply with quote
What is the best way?
PostPosted: 15:11 - 07 Feb 2011    Post subject: Re: Filling up a bike rad without getting an air lock? Reply with quote
Slowly and with much squeezing of pipes.
Tristan.
PostPosted: 15:20 - 07 Feb 2011    Post subject: Reply with quote
Rev it untill you stop getting bubbles, squeeze pipes, tip about and repeat
PostPosted: 17:22 - 07 Feb 2011    Post subject: Reply with quote
Should I fill the expansion bottle or just the rad.
PostPosted: 17:47 - 07 Feb 2011    Post subject: Reply with quote
Most bikes fill from the radiator then top up the expansion bottle once it's full.
PostPosted: 17:51 - 07 Feb 2011    Post subject: Reply with quote
Have a look and see if there is a bleed screw in the system.
Only bike that has caused me major problems getting the radiator to bleed through was the CX125. All others have just been a case of fill the radiator and squeeze a few pipes then start the engine.
Frost
PostPosted: 19:46 - 07 Feb 2011    Post subject: Reply with quote
I usually just fill it up, run the bike for a minute or so, bleed from the screw just above the water pump and top it up again.
PostPosted: 20:25 - 07 Feb 2011    Post subject: Reply with quote
Well the bike idled for several minutes and the temp didn't go above 80 so I guess it is sorted. Thumbs Up
On a side note how much coolant should an IL4 600 take roughly. I put the best part of 2 litres into the Triumph and still couldn't see any in the expansion bottle.
Frost
PostPosted: 20:40 - 07 Feb 2011    Post subject: Reply with quote
There shouldn't be anything in the expansion bottle until the bike is up to running temp.
Tavares
PostPosted: 21:04 - 07 Feb 2011    Post subject: Reply with quote
changed the coolant in my 600 hornet at the weekend and used just shy of 2 litres including filling the expansion bottle.
It should state in the manual too if you happen to have one.
Shaun.
2006 Eurostrada RX8 125(sold)>2004 Kawasaki ER-5(sold)>2002 Honda CB600F Hornet
PostPosted: 03:08 - 08 Feb 2011    Post subject: Reply with quote
Don't, whatever you do, take the radiator filler cap off when the temperature guage is reading 118 degrees Celcius. It'll explode boiling coolant all over your face and you'll have to spend the night in hospital.
Oh, wait...
https://www.bikechatforums.com/viewtopic.php?p=2762192
colin1
Captain Safety
PostPosted: 03:26 - 08 Feb 2011    Post subject: Reply with quote
I have a tt600 you have a speed four. They are practically the same bike so I can tell you that you need to find the bleed screw and undo it until fluid starts pissing out of it. Only then will you have unblocked the airlock which is likely to be there.
I have a feeling there may be two, definitely at least one.
If you cant be arsed with this, and your bike later on pisses out coolant, an airlock will be why, so you will need to find the bleed screw. Its on the side of the bike on a coolant pipe.
The last post was made 15 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 73.62 Kb
