anyone out there really clued up on zx7r
SPIKEYMIKEY
PostPosted: 00:25 - 25 Dec 2011    Post subject: anyone out there really clued up on zx7r Reply with quote
as mine has been in two garages and has still not been fixed has had three sets of carbs and new set of needles and rolling roaded and still has the hesitation it was like a bucking bronko bike has been in there 4 months now pulling my hair out now happy xmas guys
Noxious89123
PostPosted: 00:41 - 25 Dec 2011    Post subject: Reply with quote
People can't help you with the problem if you don't tell us what the problem is Wink
Merry christmas.
Lipsmoker
PostPosted: 00:44 - 25 Dec 2011    Post subject: Re: anyone out there really clued up on zx7r Reply with quote
SPIKEYMIKEY wrote:
as mine has been in two garages and has still not been fixed has had three sets of carbs and new set of needles and rolling roaded bike has been in there 4 months now pulling my hair out now happy xmas guys
... I'm the only sad Bugger posting here on Christmas
Hi Smile
1. What year bike is it?
Why Would You Get another 2 set of carbs fitted after the new first one you got fitted didn't fix it?
If a new set of carbs didn't sort it the first time
Then another new 2 set wont fix it either
It also help's if we know the problem?
What the bike is doing?
Does it start
Is it bogging?
Is it reacting under load?
Is it a standard bike?
Smile
Four wheels move the body. Two wheels move the soul.
SPIKEYMIKEY
PostPosted: 01:11 - 25 Dec 2011    Post subject: sorry will explain a bit better Reply with quote
its a zx7r p2 model it started of buy have a hesitation so i was not happy with it as it was quite dangerious so i booked it in to a garage as i took it as far as i could without a dyno so when it went it to the first garage they rolling roaded it and said it was running to rich and could not lean it down as the emoulsion tubes were worn in carbs so that cost me £160 they said get another set of carbs so this is what i did so took it to another garage as i was not happy with the one had been two so another set of carbs fitted rolling roaded and then get a call to say that the carbs i brought needed new needles as same again was running two rich so new needles fitted set up again got a call say all done picked it up riding it home and no joy was even worse was like riding a bucking horse shocking scary as hell so took it back so he insisted that it was still fuel related so my friend had a set of carbs he said worked fine so dropped them of fitted no god so returned to the set with new needles and still cant work out why its like it he said it some times rubs fine then changes back again sorry this is long windid
Lipsmoker
PostPosted: 01:26 - 25 Dec 2011    Post subject: Reply with quote
I think Noxious89123 should help you with this one.
I can only reccomend this
https://en.wikipedia.org/wiki/Punctuation
Merry Christmas
SPIKEYMIKEY
PostPosted: 01:31 - 25 Dec 2011    Post subject: ok Reply with quote
will try and pm him cheers have a good one
mab
PostPosted: 01:51 - 25 Dec 2011    Post subject: Re: sorry will explain a bit better Reply with quote
Lets see if I can make your post a little clearer
SPIKEYMIKEY wrote:
its a zx7r p2 model. It started to hesitate so i was not happy with it, as it was quite dangerious.
I booked it in to a garage and I took it as far as I could without a dyno. So when I went to the first garage they rolling roaded it and said it was running to rich and could not lean it down as the emulsion tubes were worn in carbs. That cost me £160.
They said get another set of carbs so this is what i did.
I took it to another garage as i was not happy with the one I had been to.
I got the bike rolling roaded again. I then get a call to say that the carbs i brought needed new needles as it was running too rich. I got new needles fitted and got a call saying "all done"
I picked it up, whilst riding it home but had no joy. It was even worse, like riding a bucking horse. It was scary as hell.
I took it back and he (the mechanic) insisted that it was still fuel related so my friend had a set of carbs that he said worked fine so I dropped them in and returned the carbs with the new needles.
I still can't figure out why the bike is acting the way it is. The mechanic said it sometimes runs fine, then changes back again.
Sorry this post is long winded.
So you have ruled out the carbs being the problem.
Have you checked that you are getting enough fuel flow from the tank?
Vacuum hose from the fuel tap in good condition and seated correctly on both ends?
Is the fuel filter clean and not clogged?
Are you getting good fuel flow?
Is your air filter clean?
Drake
PostPosted: 11:24 - 25 Dec 2011    Post subject: Reply with quote
any modifications to the exhaust system or engine?
hornetmike
PostPosted: 11:39 - 25 Dec 2011    Post subject: Reply with quote
any leaks on inlet rubbers or air box ?
Bucking could be a miss fire under load, check HT leads and coils
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
robocog
PostPosted: 12:47 - 25 Dec 2011    Post subject: Reply with quote
Or if it has been running rich to the point of plug fouling/wetting....throw those plugs away and put new ones in
I chased a similar fault and did everything BUT change the plugs...after spending loads of hours and cash changing wiring, earth paths, coilpacks , HT leads , re-flashing firmwares on the ignition etc....a new set of plugs 100% sorted it (once I discoverd and rectified why my plugs were getting fuel wetted under certain conditions)
after I had discovered (think it was either a Dave Vizzard or Dave Walker article I read) that once plugs get wet to the point of shorting they can create a micro path in the insulation they are in fact 100% junk reliability wise and no matter how much heating them cherry or blasting them or meticulously polishing/cleaning them - you are on to a loser till they have been replaced - even if they spark like good uns outside the engine
Regards
...and Merry Xmas
Rob
Needs a bigger garage...
SPIKEYMIKEY
PostPosted: 16:19 - 25 Dec 2011    Post subject: things i have done and garage has done . Reply with quote
Has had new plugs ,garage has run the bike with the air filter with out it being oiled and with it being oiled ,run on dyno with & with out fuel tank ,run with out fuel pump,checked all pipes one was missing but replaced and not made a difference.this garage is a place called Race tec engineering they are supposed to be highley recommended i belive that the bike is cursed lol
mods done full akropovic exhaust system,k&n filter.
Hope this helps you guys more .
have asked the guy wear it is at if it is electrical and he said no its fuel related .
Noxious89123
PostPosted: 19:30 - 25 Dec 2011    Post subject: Reply with quote
Well if it's running rich there are two ways of looking at it;
Something is causing it to aw in far too much fuel...
Or something is stopping it getting enough air.
Leaking inlet rubbers or airbox would cause it to run lean, as would aftermarket filter and exhaust if I am correct...
Also, Lipsmoker was just being a smartarse as he couldn't/wouldn't decipher your post Laughing I am far from an expert, merely willing to try and help Smile
The sets of carbs you tried, were they brand new or second hand? The reason I ask is did they have the standard needles and jets? If they had been messed with then it would just make finding the problem harder. The carbs you borrowed, were they from the same model of bike? (Silly question as I imagine they were).
How is the bike to start? Does it start from cold without the choke or not? If you take out the spark plugs, what colour are they?
How did the mechanics you took it to decide it was running rich? I'd have thought that if it wasn't firing properly then you'd get alot of unburnt fuel in the exhaust, making it look like it was running rich? (Someone tell me if I'm talking crap here, I'm just trying to think logically)
Really need someone like kickstart or stinkwheel in here Laughing
EDIT: Will it run without the airfilter? My otherhalves 125 would run like a bag of shit with the filter in but was fine without it. Also, have you checked that the air ducts aren't blocked?
Have you still got standard exhaust and air filter? Also, is the Akrapovic just a slip on end can or entire system?
Importantly, when did the problem start? Had you made any changes to the bike recently before?
Noxious89123
PostPosted: 19:43 - 25 Dec 2011    Post subject: Reply with quote
Your not running it with the choke on are you? I know some people buy a bike and don't realise which way is on and which way is off for the choke lever / plunger... Laughing
Does it do it all the time or just sometimes? At high rpm, low rpm or both?
hadden
PostPosted: 20:32 - 25 Dec 2011    Post subject: Reply with quote
lmao i didn't ride my rs for about 2 weeks a few months back because i was waiting for a new clutch cable.anyways it came and it ran just like what this bloke is describing and it took me best part of 2 days to realise i had left the choke on and the symbols had rubbed off before i owned it.it sounds stupid but easily done.Smile
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
Robby
Dirty Old Man
PostPosted: 13:26 - 26 Dec 2011    Post subject: Reply with quote
It's fair to say that this forum won't be able to advise on the fuelling side any better than the place you have been to. If it has been set up on a dyno then it should be ok on the fuelling.
Which makes electrics look more of a likelihood.
If it runs well sometimes, and poorly at other times, then the joy of an intermittent electrical fault is a possibility. In no particular order, possibilities are:
1. Corroded earth points.
2. Knackered plugs
3. Knackered HT leads
4. Knackered battery or regulator/rectifier
Diagnosing intermittent poor running is very tricky from afar. Even more difficult on a bike with a highly modified fuel or exhaust system that has been played with by someone else, some of which might not know what they are doing.
SPIKEYMIKEY
PostPosted: 20:45 - 26 Dec 2011    Post subject: Thinking of breaking the bike now Reply with quote
It has a full akroprovic system on it ,brand new chain and sprokets,brand new metzler reinsports,wheels just been painted white,all body work been painted in new kawaski green,hugger under tray,led clear rear light,new arrow indicators,forkseal s just been done,double bubble screen so guys what do you think i would get back if i break this bike any ideas ,sorry for the spelling mistakes.
hmmmnz
PostPosted: 23:22 - 26 Dec 2011    Post subject: Reply with quote
when was the last time you did the valve clearances,
its my go to answer, but i had similar issues with my zxr750, i was chasing my tail for ages before i bit the bullet,
turned out a few of the valves were so tight i couldnt actually get a feeler guage in there,
once i sorted it, bike ran like a dream,
the humans are dead
I kick arse for the lord
ZRX61
Victor Meldrew
PostPosted: 23:26 - 26 Dec 2011    Post subject: Re: Thinking of breaking the bike now Reply with quote
SPIKEYMIKEY wrote:
led clear rear light.
There's the problem right there!
or more likely tight valves...only needs one to be tight...
They're not one night stands, they're auditions.
The last post was made 14 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 103.76 Kb
