Side stand snapped frame - welding possibly?
Nandonian
PostPosted: 15:27 - 21 Jun 2013    Post subject: Side stand snapped frame - welding possibly? Reply with quote
Had the rs around a month now and the side stands been a but dodgy since I bought it. Got home from work today, put it on the stand and it's just given in.
After closer inspection, it seems like the part of the frame that holds the side stand with two bolts has snapped from the frame and now it won't go on without coming away. I tried tightening it up a lot so the bolt wouldn't move but don't really trust it.
Would I be looking along the lines of welding to fox this issue?
Picture showing the snapped bottom whole :
https://www.imgur.com/gnx6Ubj.jpeg
Suzuki Katana AY50; Peugeot Jetforce C-Tech 05+06; Honda CG125 ; Yamaha YBR125; Aprilia RS125 FP; Lexmoto XTRS 125; Aprilia RS125 Race Replica; Aprilia RS125 Extrema FP; Seat Ibiza FR 1.9 TDI
PostPosted: 17:44 - 21 Jun 2013    Post subject: Reply with quote
Bolt it up through the holes but with thick washers both sides. When it's in the correct place, weld the washers to the frame.
Nemo
PostPosted: 18:55 - 21 Jun 2013    Post subject: Reply with quote
Gaffa tape Smile
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Sako
PostPosted: 19:19 - 21 Jun 2013    Post subject: Reply with quote
Yeah looks like your bottom hole has been ripped apart, might need stitches and a topical lotion.
The other Paul Rudd
PostPosted: 19:47 - 21 Jun 2013    Post subject: Reply with quote
Seems you're not having a huge amount of luck with this bike. As much as I was rooting for you to get it running again you have to admit that maybe it's time to cut your loses. How much did you pay for it?
Copycat73
PostPosted: 20:16 - 21 Jun 2013    Post subject: Reply with quote
using a mig. machine that will weld... any fillin in to the hole can be drilled out.
caveat emptor
Derivative
PostPosted: 21:59 - 21 Jun 2013    Post subject: Reply with quote
This kind of post makes me glad I have both centre and side stand.
WTF do you do if you go out and the only stand breaks? Try and lean the bike against a post? Put it down gently?
Drake
PostPosted: 23:01 - 21 Jun 2013    Post subject: Reply with quote
ali frame = a whole world of ball ache Wink
nightshaddow
PostPosted: 23:14 - 21 Jun 2013    Post subject: Reply with quote
Nemo wrote:
Gaffa tape Smile
are you mad?????? zip ties Thumbs Up
Ariel Badger
PostPosted: 23:44 - 21 Jun 2013    Post subject: Reply with quote
Clean paint and oil off it before attempting to weld it as it will corrupt the weld and make striking up difficult. Disconnect your battery before welding.
base
PostPosted: 13:39 - 22 Jun 2013    Post subject: Reply with quote
looks easy enough to fix, I assume its a alloy frame? find someone that is handy with a AC TIG welder to weld/fill and re-drill the mounting points.
bladerunner
PostPosted: 17:53 - 22 Jun 2013    Post subject: Reply with quote
As base said.....TIG welder for a better job at such a stressed point for a permanent repair!
Drake
PostPosted: 22:33 - 22 Jun 2013    Post subject: Reply with quote
you want a big tig plant, AC/DC circa 250amps, anything with a circuit board off the bike due to it being high frequency also if you have a pacemaker gtfo of there.
HTH
el_oso
PostPosted: 23:30 - 22 Jun 2013    Post subject: Reply with quote
welding a new plate would be my suggestion to.
Depending on the availability of a good welder I would consider getting a nice thick metal plate drilling four holes in that and bolting it to the frame, then bolting the stand through the plate and the old holes. see attached detailed plan
Duke 390
Car: Jeep Wrangler 4.0L
Nandonian
PostPosted: 03:31 - 23 Jun 2013    Post subject: Reply with quote
Think I'm going to get a friend of my brothers to weld a new plate to the frame as suggested, the bikes been on autotrader for a while and I've had a ton of offers at £1000.
Got another couple of people coming to have a look tomorrow. I think I'll be booking an intensive driving course for a car with the money and go back to a cheap run around like a CG til I've passed my car licence - probably come back to bikes when u turn 19 and can get a decent 400cc Thumbs Up
The last post was made 12 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 14 - Page Size: 84.77 Kb
