| ts50x0 |
 ts50x0 Spanner Monkey
| mr.z |
 mr.z World Chat Champion
 Posted: 16:58 - 20 Dec 2004 Post subject: |
Yes the older japanese made ones are a bit quicker, i think the carbs were changed for emmissions laws or something when they moved to brazil. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kickstart |
 Kickstart The Oracle
| sickpup |
 sickpup Old Timer
| ts50x0 |
| juggla |
 juggla Borekit Bruiser
| ts50x0 |
| gsxrboy |
 gsxrboy Scooby Slapper
 Posted: 18:05 - 22 Dec 2004 Post subject: |
I have an even easier way, it involves a car and a piece of rope....  |
| Guest |
 Guest Brolly Dolly
 Posted: 18:45 - 22 Dec 2004 Post subject: |
Or a very high cliff  |
| ts50x0 |
 Posted: 22:01 - 22 Dec 2004 Post subject: |
or put it in the back of a van.
yes ive heard them all before!  |
| dodsi |
 dodsi Dirty Carny
| Jrod |
 Jrod Page 3 Girl
 Posted: 02:32 - 23 Dec 2004 Post subject: |
But that won't make a CG go faster will it now.  |
| ts50x0 |
 Posted: 12:13 - 23 Dec 2004 Post subject: |
thank you zxr, i have a cg for a yewar as i need to get a no claims bonus.
i am taking lessons but i still wont be able to afford insurance on a bigger bike!
this whole topic was how to get a CG to go faster not how do I go faster.  |
| BlueNinja |
 BlueNinja Trackday Trickster
| Kye |
 Kye Scooby Slapper
| kasandrich |
 kasandrich Trackday Trickster
 Posted: 22:06 - 25 Dec 2004 Post subject: |
| whymore? |
 whymore? Derestricted Danger
| Scooby |
 Scooby Scrappy Doo
| Kickstart |
 Posted: 12:16 - 02 Jan 2005 Post subject: |
Don't think the CG185 was ever imported to the UK. There was the XL185 which used basically the same engine as the CB125S, but that would be 20+ years old. The CB is an OHC engine while the CG is a pushrod engine so I very much doubt the barrels can be interchanged.
Skimming the head is normally done to make it flat again, but otherewise to increase the compression ratio.
Gas flowing is cleaning up and reshaping the ports to flow better.
Both could be done to the CG.
At the end of the day the CG is not going to produce large amounts of power or a high top speed. The CB125S, its sportier brother, would barely do over 70.
| Mister James |
 Mister James I want to believe!
| sickpup |
 sickpup Old Timer
| cliff |
 cliff Doctor Sicknote
| Kickstart |
| whymore? |
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:04 - 06 Jan 2005 Post subject: |
I think i may know what you mean. The manifold where the carb meets up with the engine is probably the wrong size. This is often a technique used by companies to restrict bikes. You can tell if there are completely clean bits on either of the connecting pieces of metal. If there is simply draw the line of it on the carb and file it down. This might be why the other carb makes the bike faster, or not BUT for gods sake if you do file down the manifold remember to remove and clean ALL of the swarf and filings, if those get into your piston they will grind along the cylinder walls and cause a loss of compression  ____________________ Will work for petrol
My Design Blog |
The last post was made 21 years, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
