kick start problem
carl1990
PostPosted: 22:25 - 29 May 2006    Post subject: kick start problem Reply with quote
hello,
this isn`t the greatest way i wanted to join this forum, but i have a problem with my bike Embarassed
i have one of those midi bike things, but its running a 4 stroke 70cc honda c70 replica engine.
the problem i have is that my kick start is solid, you try and kick down to start the bike and it is stuck, you could put all of your weight on it and it wont move.
is it something serious, or is it just it maybe needs some more oil ??
can anyone help me as it is the only way i can start my bike
thanks
carl Very Happy
lee125
PostPosted: 22:28 - 29 May 2006    Post subject: Reply with quote
can you push it along when it is in gear? cos if you cant it might be seized Thumbs Up
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
carl1990
PostPosted: 22:33 - 29 May 2006    Post subject: Reply with quote
its a semi automatic, so no clutch, but i have never been able to push it along in gear even before the kick start messed up.
p.s - I had it running fine the night before, not just idling, it was going fine
the grim reaper
PostPosted: 16:36 - 30 May 2006    Post subject: Reply with quote
The only experience I have with a stuck kickstart was when I seized the bottom end on my MTX125. Same thing, I could stand on the lever and it wouldn't budge. Mind you, when I got the main bearing out, it wasn't a surprise, the dust seal had come loose and wound itself in and out of the bearings.
Grim
carl1990
PostPosted: 22:49 - 30 May 2006    Post subject: Reply with quote
thanks for the help!
i think the only thing i can do is a strip down and rebuild, put some new oil in and change to a new plug.
thanks
carl
shager
PostPosted: 23:26 - 30 May 2006    Post subject: Reply with quote
might be a bit of your piston gone down the crank shaft happend to me
Rit
PostPosted: 00:01 - 31 May 2006    Post subject: Reply with quote
You need to find out if its the starting gear or engine thats seized before you go any further. My guess is if you remove the left engine casing there will be a nut that you can turn over the engine with. If you can you need a manual and take a look at the starting gear. If you cant turn the engine over using the nut.....ouch!
Just a thought, have you taken the kickstart off yet and put it back on? Just incase of a broken return spring.
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
Rit
PostPosted: 00:03 - 31 May 2006    Post subject: Reply with quote
Oh, welcome to the forum Thumbs Up
www.ritzbitz.co.uk
carl1990
PostPosted: 00:36 - 31 May 2006    Post subject: Reply with quote
yes, i have removed the right hand side engine casing to reveal clutch, fly wheel kick start spring ect... but i cannot get any further as the clutch blocks the entrance from the right hand casing...
as for kick start it moves down around half way, but no further, and goes back up fine :?: :!:
PostPosted: 01:28 - 31 May 2006    Post subject: Reply with quote
You need to try turning the end of the crank and see if the engine will turn over. If it does, chances are the fault lies in the kickstart area (good). If it doesn't, your engine is seized for some reason (bad).
Take the left hand side cover off. You will see the magneto rotor (a big round metal thing). This is attached to the end of the crank, try to turn it round (make sure the ignition is switched off, the engine might start!).
Jenks
PostPosted: 12:52 - 31 May 2006    Post subject: Reply with quote
Welcome to the forum, when this happened to a bike i know, it was because of some "Rubbish" in the clutch plate, strip it out.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
carl1990
PostPosted: 12:55 - 31 May 2006    Post subject: Reply with quote
Exclamation i took the left hand casing off and found the magneto rotor with a little nut in the middle, turned the nut, my engine turned over so i put the casing back on and my bike now kicks, but doesn`t start... Rolling Eyes
i think i need to clean the carb out as it is flooding...
thanks for the help
carl Smile
Jenks
PostPosted: 13:04 - 31 May 2006    Post subject: Reply with quote
Make sure you give it a RIGHT GOOD clean out! Nothing worse than it getting all "Gooey"
carl1990
PostPosted: 13:06 - 31 May 2006    Post subject: Reply with quote
carb cleaner i use when its open Wink
The last post was made 20 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 80.33 Kb
