| carl1990 |
 carl1990 Two Stroke Sniffer
 Posted: 22:25 - 29 May 2006 Post subject: kick start problem |
hello,
this isn`t the greatest way i wanted to join this forum, but i have a problem with my bike
i have one of those midi bike things, but its running a 4 stroke 70cc honda c70 replica engine.
the problem i have is that my kick start is solid, you try and kick down to start the bike and it is stuck, you could put all of your weight on it and it wont move.
is it something serious, or is it just it maybe needs some more oil ??
can anyone help me as it is the only way i can start my bike
thanks
carl  |
| lee125 |
 lee125 World Chat Champion
 Posted: 22:28 - 29 May 2006 Post subject: |
can you push it along when it is in gear? cos if you cant it might be seized  ____________________ cbt passed 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years |
| carl1990 |
| the grim reaper |
 the grim reaper World Chat Champion
| carl1990 |
| shager |
 shager Scooby Slapper
| Rit |
 Rit Trackday Trickster
 Posted: 00:01 - 31 May 2006 Post subject: |
You need to find out if its the starting gear or engine thats seized before you go any further. My guess is if you remove the left engine casing there will be a nut that you can turn over the engine with. If you can you need a manual and take a look at the starting gear. If you cant turn the engine over using the nut.....ouch!
Just a thought, have you taken the kickstart off yet and put it back on? Just incase of a broken return spring. ____________________ You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk |
| Rit |
 Posted: 00:03 - 31 May 2006 Post subject: |
Oh, welcome to the forum  ____________________ You watching this rubbish?
| carl1990 |
| stinkwheel |
 Posted: 01:28 - 31 May 2006 Post subject: |
You need to try turning the end of the crank and see if the engine will turn over. If it does, chances are the fault lies in the kickstart area (good). If it doesn't, your engine is seized for some reason (bad).
Take the left hand side cover off. You will see the magneto rotor (a big round metal thing). This is attached to the end of the crank, try to turn it round (make sure the ignition is switched off, the engine might start!). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jenks |
 Jenks World Chat Champion
| carl1990 |
 Posted: 12:55 - 31 May 2006 Post subject: |
i took the left hand casing off and found the magneto rotor with a little nut in the middle, turned the nut, my engine turned over so i put the casing back on and my bike now kicks, but doesn`t start...
i think i need to clean the carb out as it is flooding...
thanks for the help
carl  |
| Jenks |
| carl1990 |
The last post was made 20 years, 43 days ago. Instead of replying here, would creating a new thread be more useful? |
