rs 125 flywheel removal?
2006 _p1
PostPosted: 08:48 - 15 Feb 2008    Post subject: rs 125 flywheel removal? Reply with quote
is there a way of getting it off with out a fly wheel puller? is it on a thread? or will it slide off?
thanks
2006 _p1
PostPosted: 11:52 - 15 Feb 2008    Post subject: Reply with quote
here it is! thanks
https://i77.photobucket.com/albums/j76/pit_bike/Picture004.jpg
https://i77.photobucket.com/albums/j76/pit_bike/Picture005.jpg
https://i77.photobucket.com/albums/j76/pit_bike/Picture006.jpg
2006 _p1
PostPosted: 16:52 - 15 Feb 2008    Post subject: Reply with quote
Smile Very Happy
skinny
PostPosted: 17:04 - 15 Feb 2008    Post subject: Reply with quote
Get a puller or ask some one on here ZX6R I think he suggests using a bloody great hammer Laughing Laughing
oops I did it again....
2006 _p1
PostPosted: 20:18 - 15 Feb 2008    Post subject: Reply with quote
ah right ok! that would be helpfull! i live in loughborough! thanks
PostPosted: 20:46 - 15 Feb 2008    Post subject: Reply with quote
Some good hints in this thread I thought. Laughing
https://www.bikechatforums.com/viewtopic.php?t=138723
2006 _p1
PostPosted: 23:25 - 15 Feb 2008    Post subject: Reply with quote
the only thread is on the crank axel. none on the fly wheel its self!
the first one looks the right one but how does it work because its pushing against the fly wheel. or does it push the crank out?
finpos
PostPosted: 10:09 - 16 Feb 2008    Post subject: Reply with quote
On some of those pictures there is a big metal plate supplied with the puller. You need to bolt the plate onto the flywheel, then the puller attaches to the plate. i.e. the puller on it's own (first link) isn't enough.
Looks like you would get away with using a general purpose puller (see other thread!)
f.
truslack
PostPosted: 14:34 - 16 Feb 2008    Post subject: Reply with quote
Bit of a bodge way of doing it, but put a nut onto the crank (so it protects the thread) then whack it with a hammer/brick/heavy object.
May require WD40 and a crowbar.
Try not to damage anything.
joseph.griffin
PostPosted: 16:19 - 16 Feb 2008    Post subject: Reply with quote
i did this recently on a little 33cc engine, talked about it here
https://www.bikechatforums.com/viewtopic.php?t=138723 (already linked by big-ham)
I did it by holding the engine in the air by the flywheel (easy on an eninge that small ) and hitting the shaft with a hammer, after soaking in in WD40. Just let the engine drop onto something soft. You can see the tapered shaft/key in the last pic on my thread.
Joe
1999 Honda NSR125RX F Black and Silver (but with loads of scratches)
13/04/08 - Now a 1991 Honda VFR400R-M NC30 Black and Grey (Not road legal yet)
The Tot
PostPosted: 00:30 - 17 Feb 2008    Post subject: Reply with quote
If your in lufbra can you not just ask Twiggers or John Monk if you can quickly borrow their tools? I'm sure that Mark at Twiggers might be able to lend you the tool (that is if you tell them before hand and bring the lump and say do it at their drive at the back?)Twiggers are very helpful.
Never argue with autism
J.K.R
PostPosted: 03:14 - 17 Feb 2008    Post subject: Reply with quote
Get someone to give you and the engine a lift to the local bikeshop and ask one of the mechanics if you can bring the engine in and use the tool or have one of them do it.
A thanks and a pack of biscuits goes a long way too Thumbs Up
Also as you see there are the other methods of doing it but can you afford to replace a crank? Wouldnt risk it Wink
www.oldskoolsuzuki.info
2006 _p1
PostPosted: 17:32 - 17 Feb 2008    Post subject: Reply with quote
i will try bodge it first when i got time thanks anyway!
2006 _p1
PostPosted: 15:38 - 20 Feb 2008    Post subject: Reply with quote
i have now got the flywheel off. but i carnt get the crank out haha. the crank bearing was siezed but i freeed it up. i have hit the crank with the bolt on and it shired the bolt off. the crank threads are ok though. any advise?
2006 _p1
PostPosted: 15:43 - 20 Feb 2008    Post subject: Reply with quote
i have now haha
2006 _p1
PostPosted: 15:57 - 20 Feb 2008    Post subject: Reply with quote
https://i77.photobucket.com/albums/j76/pit_bike/SP_A0511.jpg
i want to reuuse the crank. so i dont want to bodge it!
The last post was made 18 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 124.93 Kb
