| 2006 _p1 |
 2006 _p1 Crazy Courier
| Vincent |
 Vincent Banned
 Posted: 11:07 - 15 Feb 2008 Post subject: |
I would imagine it's held on with a woodruffe key. if it is, you'll need a puller but if it's the one I think, they're fairly cheap Do you have any pics? |
| 2006 _p1 |
 Posted: 11:52 - 15 Feb 2008 Post subject: |
| 2006 _p1 |
 Posted: 16:52 - 15 Feb 2008 Post subject: |
| skinny |
 skinny Nitrous Nuisance
 Posted: 17:04 - 15 Feb 2008 Post subject: |
Get a puller or ask some one on here ZX6R I think he suggests using a bloody great hammer  ____________________ oops I did it again.... |
| Vincent |
 Vincent Banned
 Posted: 18:36 - 15 Feb 2008 Post subject: |
Yup, looks like you need one of these:-
https://i77.photobucket.com/albums/j71/Drewskovitch/P1010566.jpg
You screw the fatter part into the flywheel, then tighten the thinner "bolt" up and give it a good solid "Thwack" with a lump hammer. Don't make the same mistake I've seen made loads of times where people think they can loosen the flywheel by just tightening up the puller. Whereabouts are you? You're profile doesn't say Those pullers aren't too expensive but if you're local I can lend you mine. |
| 2006 _p1 |
| Vincent |
 Vincent Banned
 Posted: 20:30 - 15 Feb 2008 Post subject: |
Not quite local enough If it's the same size as this one, and you look around, you should be able to pick one up fairly cheap - about a fiver I should think. A decent bike shop should knock it off for you for a packet of fags  |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Vincent |
 Vincent Banned
 Posted: 21:05 - 15 Feb 2008 Post subject: |
I can't make it out in the pic, is there a thread on the flywheel for the above puller to screw into  |
| Vincent |
 Vincent Banned
 Posted: 21:15 - 15 Feb 2008 Post subject: |
| 2006 _p1 |
| finpos |
 finpos World Chat Champion
| truslack |
 truslack World Chat Champion
| joseph.griffin |
 joseph.griffin Renault 5 Driver
 Posted: 16:19 - 16 Feb 2008 Post subject: |
i did this recently on a little 33cc engine, talked about it here
https://www.bikechatforums.com/viewtopic.php?t=138723 (already linked by big-ham)
I did it by holding the engine in the air by the flywheel (easy on an eninge that small ) and hitting the shaft with a hammer, after soaking in in WD40. Just let the engine drop onto something soft. You can see the tapered shaft/key in the last pic on my thread.
Joe ____________________ 1999 Honda NSR125RX F Black and Silver (but with loads of scratches)
13/04/08 - Now a 1991 Honda VFR400R-M NC30 Black and Grey (Not road legal yet) |
| The Tot |
 The Tot World Chat Champion
| J.K.R |
 J.K.R World Chat Champion
 Posted: 03:14 - 17 Feb 2008 Post subject: |
Get someone to give you and the engine a lift to the local bikeshop and ask one of the mechanics if you can bring the engine in and use the tool or have one of them do it.
A thanks and a pack of biscuits goes a long way too
Also as you see there are the other methods of doing it but can you afford to replace a crank? Wouldnt risk it  ____________________ www.oldskoolsuzuki.info |
| Vincent |
 Vincent Banned
 Posted: 13:07 - 17 Feb 2008 Post subject: |
| 2006 _p1 |
| 2006 _p1 |
| Vincent |
 Vincent Banned
 Posted: 15:42 - 20 Feb 2008 Post subject: |
Put the lump hammer away  |
| 2006 _p1 |
| Vincent |
 Vincent Banned
| 2006 _p1 |
 Posted: 15:57 - 20 Feb 2008 Post subject: |
| Vincent |
 Vincent Banned
The last post was made 18 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
