1990 ns125r k HELP Please
gene_cann
PostPosted: 03:43 - 03 Mar 2004    Post subject: 1990 ns125r k HELP Please Reply with quote
Hi guys just wondering if you could help me my mate said he could de-restrict my bike but he couldn't and he did not put the bike back together i have a manual obtained a copy from scotty with thanks!.
so i can get it back together just wanted to know if you guys know how to de-restrict it as i can only get 65 out of it and my "MATE" has the same bike and can get 90mph out of it and it has not been modified in any way
any help is greatly appreciated Thumbs Up
Regard's
Gene
"If your not part of the solution then your part of the problem"
NSR125-Kid-UK
Attention Whore
PostPosted: 03:51 - 03 Mar 2004    Post subject: Reply with quote
https://www.nsr125.com/derestrict.htm
This page refers to bikes from 1993 onwards so I'm not sure how much help it could be, but I'd imagine the principles are the same.
I'm afraid that although I own an NSR (125R - 2000) myself, it was derestricted when i bought it so i've not actually carried out the process myself.
In any case, I hope this is of some help to you, although as I say there may be differences in your bike's workings, so i'd wait for further advice before opening your bike up.
Best of luck whatever happens mate. Thumbs Up
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
gene_cann
PostPosted: 04:14 - 03 Mar 2004    Post subject: Nsr 125 Reply with quote
Hi yeah it looks good but is what there saying remove the exhaust look in there to see how thick the walls are then is the big thing what they say remove that big black box which the tube goes into the engine and thats where the restrictor plate is if so i will do that then could you explain to me about the front sprocket restriction thing please i know this must sound really dumb but i am quite dumb when it comes to bike i don't really know what all the bits are called!LOL Laughing
All help much appreciated!
Cheer's
Gene
gene_cann
PostPosted: 04:30 - 03 Mar 2004    Post subject: nsr 125 Reply with quote
Hi all
Just a quickie straying away from the other question but still help with it please! Mr. Green
My friend wants to know what is the best type of paint to spray his nsr with??????? also what colour scheme do you think would be cool??
Cheer's
Gene & Martin
ZaphodBeeble
PostPosted: 05:12 - 03 Mar 2004    Post subject: Reply with quote
There isn't any restriction on the sprockets on the NSR. For that matter there isn't a restrictor on a sprocket at all. The only way it would be considered as restricted is if the gearing was made lower by having a smaller front sprocket. This does not affect engine power but mainly acceleration and top speed. There is a trade-off you see, if you want higher top speed you must sacrifice acceleration and vice-versa.
As for the exhaust restriction, it will be inside the pipe when you take it off, it shouldn't be inside the engine exhaust port (as far as I know). The other restrictor will be on the opposite side of the engine between the engine head and the carburettor. (Usually a rubber pipe about 2 or 3 inches long.) There will be a plate between that rubber connector and the engine. That can be removed. Be careful not to remove the reed block though as that is an important part of the engine. (It has plastic 'flaps' on it that can be moved.)
Hope this helps Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Hex
Party Boy
PostPosted: 09:43 - 03 Mar 2004    Post subject: Reply with quote
The ns isn't restricted the same way as the nsr. I used to have one and it would do 90ish with an after market system on (came with the bike).
Count the teeth on the sprockets to see if your gearing is the same as your mates. Thats the easiest way to see if your both looking at similar gearing.
I think your problem is probably going to be down to the fact your engine needs its rings changing though. How long ago where they done?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
gene_cann
PostPosted: 10:29 - 03 Mar 2004    Post subject: ns125r-k Reply with quote
what and where are the sprokets????? and rings????
Thanks for your help it is much appreciated
Regards
Gene Cann
gene_cann
PostPosted: 10:32 - 03 Mar 2004    Post subject: ns125r k Reply with quote
hi again just taking of the exhaust but one of the alenkey screws i cant get to due the the bend in the exhaust what could i use to get it off??
Regards
Gene Cann
Ian (GPX)
PostPosted: 10:40 - 03 Mar 2004    Post subject: Reply with quote
Huh ?
Why are you trying to take off the can ? Leave the 3 alenkeys alone.
Just undo the bolt that hold it to the rear foot rest and from under the bike too, then undo the 2 nuts at the front of the engine, the zaust will fall off then.
Ian (GPX) This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
McJamweasel
BCF Junkie
PostPosted: 10:44 - 03 Mar 2004    Post subject: Reply with quote
Ian. WTF??
People have to start somewhere - not everyone is born with an intimate knowledge of motorcycle parts, as I assume you were from that comment.
Ian (GPX)
PostPosted: 10:48 - 03 Mar 2004    Post subject: Reply with quote
McJamweasel wrote:
Ian. WTF??
Shocked
Mc -- No, I did not have intimate knowledge of motorcycle parts when I was born, but I did learn fast by reading books and asking questions at an early stage in life, by the time I was 12 I knew what was what.
PostPosted: 10:49 - 03 Mar 2004    Post subject: Reply with quote
Thumbs Up McJam.
You don't know anything until you are ask and find out, or you look it up. Well, most of us don't. Laughing
PostPosted: 10:51 - 03 Mar 2004    Post subject: Reply with quote
But not everybody was reading up about engines and motorcycle mechanics at the age of 12. Rolling Eyes
McJamweasel
BCF Junkie
PostPosted: 10:53 - 03 Mar 2004    Post subject: Reply with quote
...asking questions at an early stage in life, by the time I was 12 I knew what was what.
And he's asking those questions now. At 12 I had no interest in bikes at all, I was more interested in playing computer games than playing with engines. I very much doubt I'm the only one who was like that.
Ian (GPX)
PostPosted: 10:55 - 03 Mar 2004    Post subject: Reply with quote
Fair point Ste ......
OK, sorry for the sarcasm...... Embarassed
Ian (GPX)
PostPosted: 10:58 - 03 Mar 2004    Post subject: Reply with quote
Never had a computer when I was 12, they was not about then, my 1st computer was a ZX81, cor, that dates me a bit Embarassed
gene_cann
PostPosted: 12:06 - 03 Mar 2004    Post subject: ns125r k Reply with quote
HI dont i have to take the end part of the exhaust off becouse i think the restriction is in the end part?
THANKS for your help it is much appreciated
Regards
Gene Cann
Ian (GPX)
PostPosted: 12:52 - 03 Mar 2004    Post subject: Reply with quote
If your bike is an NS125 and not an NSR125 then no, the restrictor is at the front of the zaust, it's a round ring thats welded into it and has to be drilled and filed out.
Does your bike look like this one ?
https://hayabusa.bikepics.com/honda-nsr125-87-bikepics-073878.jpg
SKIN2537
PostPosted: 14:14 - 03 Mar 2004    Post subject: Reply with quote
Gene...If you get your rings done, please let me know how much it cost. i've just become a NSR owner too. i'm 65 flat out, i reckon i gotta do th exhaust thing and the rest. Thumbs Up
If you've done yours, let me know how you got on.
ilovens125f's
PostPosted: 16:54 - 03 Mar 2004    Post subject: Reply with quote
Hi there is another restriction in the Exaust...
Where it says "HERE" its a collor!!!
Hope this helps
Kev Thumbs Up
Kev the Ns125F lover!!
!!!Dont ignore me!!!
Scooby
Scrappy Doo
PostPosted: 21:09 - 03 Mar 2004    Post subject: Re: ns125r-k Reply with quote
Sprockets are those round things with teeth that have the chain going round it Doh!
Rings --- These are around the piston, inside the top part of the engine Brick Wall
Have you ever kissed a girl?
Ian (GPX)
PostPosted: 21:17 - 03 Mar 2004    Post subject: Re: ns125r-k Reply with quote
Shocked Confused
Yes, I'm married to one too ! Razz
Valentino Mossy
PostPosted: 21:57 - 03 Mar 2004    Post subject: Reply with quote
Derestricted Ns125r are fun when they work ! Silence
Dont ask me on how to rebuild the things ! Laughing
OT
Parts came today Ian !
Whats the last number on the regulator mean ?
My old one says : sh522b-12 0.2
New one : sh522b-12 7.1 Confused
BTW : That photo of the ns, was it yours as its very nice ! Thumbs Up
Ian (GPX)
PostPosted: 22:09 - 03 Mar 2004    Post subject: Reply with quote
Part no..... no idea mate !
Nah, that was not mine, same as mine, mine was all red in colour.
Restrictor in can, depends on the can, mine never had the standard end can, so it did not have one. I had a spare can and that did have the plate in it.
The last post was made 22 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 130.83 Kb
