| gene_cann |
 gene_cann Renault 5 Driver
 Posted: 03:43 - 03 Mar 2004 Post subject: 1990 ns125r k HELP Please |
Hi guys just wondering if you could help me my mate said he could de-restrict my bike but he couldn't and he did not put the bike back together i have a manual obtained a copy from scotty with thanks!.
so i can get it back together just wanted to know if you guys know how to de-restrict it as i can only get 65 out of it and my "MATE" has the same bike and can get 90mph out of it and it has not been modified in any way
any help is greatly appreciated
Regard's
Gene ____________________ "If your not part of the solution then your part of the problem" |
| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
 Posted: 03:51 - 03 Mar 2004 Post subject: |
https://www.nsr125.com/derestrict.htm
This page refers to bikes from 1993 onwards so I'm not sure how much help it could be, but I'd imagine the principles are the same.
I'm afraid that although I own an NSR (125R - 2000) myself, it was derestricted when i bought it so i've not actually carried out the process myself.
In any case, I hope this is of some help to you, although as I say there may be differences in your bike's workings, so i'd wait for further advice before opening your bike up.
Best of luck whatever happens mate.  ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
| gene_cann |
 Posted: 04:14 - 03 Mar 2004 Post subject: Nsr 125 |
Hi yeah it looks good but is what there saying remove the exhaust look in there to see how thick the walls are then is the big thing what they say remove that big black box which the tube goes into the engine and thats where the restrictor plate is if so i will do that then could you explain to me about the front sprocket restriction thing please i know this must sound really dumb but i am quite dumb when it comes to bike i don't really know what all the bits are called!LOL
All help much appreciated!
Cheer's
| gene_cann |
 Posted: 04:30 - 03 Mar 2004 Post subject: nsr 125 |
Hi all
Just a quickie straying away from the other question but still help with it please!
My friend wants to know what is the best type of paint to spray his nsr with??????? also what colour scheme do you think would be cool??
Cheer's
Gene & Martin ____________________ "If your not part of the solution then your part of the problem" |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 05:12 - 03 Mar 2004 Post subject: |
There isn't any restriction on the sprockets on the NSR. For that matter there isn't a restrictor on a sprocket at all. The only way it would be considered as restricted is if the gearing was made lower by having a smaller front sprocket. This does not affect engine power but mainly acceleration and top speed. There is a trade-off you see, if you want higher top speed you must sacrifice acceleration and vice-versa.
As for the exhaust restriction, it will be inside the pipe when you take it off, it shouldn't be inside the engine exhaust port (as far as I know). The other restrictor will be on the opposite side of the engine between the engine head and the carburettor. (Usually a rubber pipe about 2 or 3 inches long.) There will be a plate between that rubber connector and the engine. That can be removed. Be careful not to remove the reed block though as that is an important part of the engine. (It has plastic 'flaps' on it that can be moved.)
Hope this helps  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| Hex |
 Hex Party Boy
 Posted: 09:43 - 03 Mar 2004 Post subject: |
The ns isn't restricted the same way as the nsr. I used to have one and it would do 90ish with an after market system on (came with the bike).
Count the teeth on the sprockets to see if your gearing is the same as your mates. Thats the easiest way to see if your both looking at similar gearing.
I think your problem is probably going to be down to the fact your engine needs its rings changing though. How long ago where they done? ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| gene_cann |
| gene_cann |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| Ian (GPX) |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
| McJamweasel |
 McJamweasel BCF Junkie
| Ian (GPX) |
| Ste |
 Ste Not Work Safe
 Posted: 10:49 - 03 Mar 2004 Post subject: |
McJam.
You don't know anything until you are ask and find out, or you look it up. Well, most of us don't.  |
| Ste |
 Ste Not Work Safe
| McJamweasel |
| Ian (GPX) |
| Ian (GPX) |
| gene_cann |
| Ian (GPX) |
| SKIN2537 |
 SKIN2537 L Plate Warrior
 Posted: 14:14 - 03 Mar 2004 Post subject: |
Gene...If you get your rings done, please let me know how much it cost. i've just become a NSR owner too. i'm 65 flat out, i reckon i gotta do th exhaust thing and the rest.
If you've done yours, let me know how you got on. |
| ilovens125f's |
 ilovens125f's Renault 5 Driver
 Posted: 16:54 - 03 Mar 2004 Post subject: |
Hi there is another restriction in the Exaust...
Where it says "HERE" its a collor!!!
Hope this helps
Kev  ____________________ Kev the Ns125F lover!!
!!!Dont ignore me!!! |
| Scooby |
 Scooby Scrappy Doo
| Ian (GPX) |
 Posted: 21:17 - 03 Mar 2004 Post subject: Re: ns125r-k |
| Valentino Mossy |
 Valentino Mossy World Chat Champion
 Posted: 21:57 - 03 Mar 2004 Post subject: |
Derestricted Ns125r are fun when they work !
Dont ask me on how to rebuild the things !
OT
Parts came today Ian !
Whats the last number on the regulator mean ?
My old one says : sh522b-12 0.2
New one : sh522b-12 7.1
BTW : That photo of the ns, was it yours as its very nice !  ____________________ Ducati 916,white framed corse replica https://www.bikechatforums.com/viewtopic.php?t=239309
https://blauschatfroums.freeforums.net/ |
| Ian (GPX) |
The last post was made 22 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
