| KAWIguy14 |
 KAWIguy14 L Plate Warrior
| CaNsA |
 CaNsA Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 12:58 - 10 Dec 2009 Post subject: |
My first guess with a problem like that would be fuel starvation, probably from a blocked breather hose for the fuel tank (could just be kinked). Takes a while to have an effect, but as fuel is used and air cannot get into the tank to replace it, it builds up low pressure in the tank until the pressure is low enough to stop fuel getting out of the tank. When it happens try opening the fuel cap while listening carefully. If you hear air being sucked in and then the bike starts fone then that is the problem.
Could also be other things, such as a blocked fuel filter, dodgy fuel pump (think the ZZR has a fuel pump), coil getting too hot, etc, but the breather would be the first thing I would check.
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 13:21 - 10 Dec 2009 Post subject: |
The first thing that sprung to my mind when reading the symptoms was also fuel starvation.
Go with Keith's suggestions above and then come back...
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| KAWIguy14 |
 Posted: 14:18 - 10 Dec 2009 Post subject: thanks man |
really appreciate it will try this site ASAP!! |
| KAWIguy14 |
| Kickstart |
| Theoutsider |
 Theoutsider Scooby Slapper
 Posted: 14:41 - 10 Dec 2009 Post subject: |
Hi.Try a new set of spark plugs and carb balancing,it should do the trick.  |
| chris-red |
 Posted: 14:43 - 10 Dec 2009 Post subject: |
I agree with Keith, all the bikes I have had have had 2 hoses coming from the bottom of the tank that go to the bottom of the bike you should see them hanging down slightly. Lift the tank up then put it down but as you are putting it down get somebody to pull on these lines gently to keep them taught this should stop them being kinked.
https://img.photobucket.com/albums/v295/chris-red/06052009225.jpg
Here is a picture of mine from the Speed Four. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| temeluchus |
| KAWIguy14 |
| Kickstart |
| steveh |
 steveh World Chat Champion
The last post was made 16 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
