kawasaki zzr 400 problem
KAWIguy14
PostPosted: 12:14 - 10 Dec 2009    Post subject: kawasaki zzr 400 problem Reply with quote
i recently bought a 2nd hand 1993 kawasaki zzr 400 and its not in "running condition" when i got it. then i immediately took it to my certified bike mechanic so after a week of dismantleling it and repairing the carbs,flushing radiator water,checking water pump etc..it runs smoothly the only problem is that after a few kilometers while riding it ,,first the bike jerks like misfiring then it suddenly stalls and the engine dies but after a few minutes or so the engine runs again then the problem starts all over again after a kilometer ride...can you pls help me what causing this problem??my mechanic told me that all cooling system is great i even saw it while the radiator cap is off the water runs great and the engine in normal state of temperature...is this electrical problem?or maybe the CDI is worn out?
all inputs are very much appreciated thanks
from the philippines ride safe ya'll
CaNsA
PostPosted: 12:48 - 10 Dec 2009    Post subject: Reply with quote
get over to
https://www.zxrworld.co.uk/zxr400oc/index.php
and ask for help, they are awesome Smile
PostPosted: 12:58 - 10 Dec 2009    Post subject: Reply with quote
My first guess with a problem like that would be fuel starvation, probably from a blocked breather hose for the fuel tank (could just be kinked). Takes a while to have an effect, but as fuel is used and air cannot get into the tank to replace it, it builds up low pressure in the tank until the pressure is low enough to stop fuel getting out of the tank. When it happens try opening the fuel cap while listening carefully. If you hear air being sucked in and then the bike starts fone then that is the problem.
Could also be other things, such as a blocked fuel filter, dodgy fuel pump (think the ZZR has a fuel pump), coil getting too hot, etc, but the breather would be the first thing I would check.
Barry_M2
PostPosted: 13:21 - 10 Dec 2009    Post subject: Reply with quote
The first thing that sprung to my mind when reading the symptoms was also fuel starvation.
Go with Keith's suggestions above and then come back...
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
KAWIguy14
PostPosted: 14:18 - 10 Dec 2009    Post subject: thanks man Reply with quote
CaNsA_temporary wrote:
get over to
really appreciate it will try this site ASAP!!
KAWIguy14
PostPosted: 14:20 - 10 Dec 2009    Post subject: Reply with quote
sir me and my mechanic have cleand all fuel lines especially the tank my zzr 400 has no fuel pump...any idea sir? Question
PostPosted: 14:27 - 10 Dec 2009    Post subject: Reply with quote
The breather is not a fuel line, it is to allow air into the tank. Possibly comes off the top of the tank and is a hose going down from the back of the tank to near the rear wheel. Possibly just a small hole in the fuel cap. Try taking the bike for a run and removing the fuel cap immediatly when it stops.
Theoutsider
PostPosted: 14:41 - 10 Dec 2009    Post subject: Reply with quote
Hi.Try a new set of spark plugs and carb balancing,it should do the trick. Thumbs Up
PostPosted: 14:43 - 10 Dec 2009    Post subject: Reply with quote
I agree with Keith, all the bikes I have had have had 2 hoses coming from the bottom of the tank that go to the bottom of the bike you should see them hanging down slightly. Lift the tank up then put it down but as you are putting it down get somebody to pull on these lines gently to keep them taught this should stop them being kinked.
https://img.photobucket.com/albums/v295/chris-red/06052009225.jpg
Here is a picture of mine from the Speed Four.
temeluchus
PostPosted: 15:05 - 10 Dec 2009    Post subject: Reply with quote
Cant be a good mechanic then, the ZZR400 has a fuel pump.... Without one fitted you will get the fuel starvation problems you describe.
You can download the fiche with all the part numbers here:
https://ybrclub.com/_files/books/kawasaki/kawasaki_zzr400_microfiches.zip
Id imagine the fuel pump from a ZZR600 will ge the same. Also a Facet or other pattern pump should do the job also.
KAWIguy14
PostPosted: 15:10 - 10 Dec 2009    Post subject: Reply with quote
thanks keith i will try this tomorrow and will keep this thread updated.
and thanks for the picture man i will try this also
PostPosted: 15:44 - 10 Dec 2009    Post subject: Reply with quote
There might well be 2 non fuel pipes. One as a breather and possibly another to allow water to drain away from around the filler cap.
steveh
PostPosted: 18:58 - 11 Dec 2009    Post subject: Reply with quote
Out of interest its not a purple one is it? friend of mine sold one not so long back, i do have a few spares lying around aswell if you need anything.
cheers, steve.
The last post was made 16 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 81.45 Kb
