my chain rusted
kawashima
PostPosted: 14:45 - 26 Apr 2010    Post subject: my chain rusted Reply with quote
Today I noticed my chain had rusted slightly.
I sprayed chain lube on it. Is it ok or not? Should I remove the rusted surface? If so, how should I do it?
I didn't think it rusts only in 4 months, and I was told once that I spray lube too much, I didn't spray intentionally but it was wrong.
https://i21.photobucket.com/albums/b295/kawashima_/rustedchain.jpg
own:2020 Serow 250
snomag
PostPosted: 14:53 - 26 Apr 2010    Post subject: Reply with quote
You should have seen the state of my chain during the winter. Once I wasn't using the bike for a week and when I got back on it, you couldn't see a single bit that wasn't covered in rust on the chain. Yours is still in a pretty good condition compared to that.
To be honest I wouldn't worry about it too much, try to wipe off as much as you can, lube it, ride it, and it will be good as new. (well, almost) Oh and check for stiff links .
lewis87
PostPosted: 14:54 - 26 Apr 2010    Post subject: Reply with quote
Give it a good scrub with some WD40 and a brush or a rag. Then wipe the WD40 off and put some more chain lube on Thumbs Up
kawashima
PostPosted: 15:03 - 26 Apr 2010    Post subject: Reply with quote
Thanks Thumbs Up I'll try WD40(=CRC56 here) and rag scrubbing Smile
own:2020 Serow 250
Paxovasa
PostPosted: 15:07 - 26 Apr 2010    Post subject: Reply with quote
I wouldn't use wd40 on a chain.
It is only surface rust, give the chain a good covering with chain lube and take the bike for a ride. That should get rid of the worst of the rust Smile
Hazylogic
PostPosted: 15:17 - 26 Apr 2010    Post subject: Reply with quote
the gods will name you beast if you use wd40 on your chain. engine oil plenty good!
lewis87
PostPosted: 15:19 - 26 Apr 2010    Post subject: Reply with quote
Why not? Neutral
I always clean my chains with WD40 before cleaning it off and putting new lube on.
L4Isoside
PostPosted: 15:23 - 26 Apr 2010    Post subject: Reply with quote
Paraffin and a toothbrush!
Then wipe it off with a rag
and a good spray with chain lube! should be fine after that Smile
Paxovasa
PostPosted: 15:38 - 26 Apr 2010    Post subject: Reply with quote
lewis87 wrote:
Why not? Neutral
As WD40 is a penetrating oil it will remove the grease from inside the X/O rings.
If you need to clean the chain, then I use cheap engine oil on a rag, and then wipe the chain.
StevenF
PostPosted: 15:55 - 26 Apr 2010    Post subject: Reply with quote
I debated wither or not to use WD40 to clean my chain, but after some research online I decided just to go ahead and do it.
PostPosted: 16:02 - 26 Apr 2010    Post subject: Reply with quote
lewis87 wrote:
Why not? Neutral
WD40 gets inside the o rings and removes the grease which will shorten chain life, just lube it, I clean mine with petrol and one of these.
https://www.chaparral-racing.com/Chaparral/assets/product_images/W68185B.JPG
badas
PostPosted: 16:23 - 26 Apr 2010    Post subject: Reply with quote
chris-red wrote:
whats the name of that and where can i get one from? and cost?
ty
t121anf
PostPosted: 16:33 - 26 Apr 2010    Post subject: Reply with quote
try here
https://www.mandp.co.uk/productinfo/571638/Chains-and-Sprockets/Chain-Cleaners/Bike-It
Charlie
PostPosted: 16:51 - 26 Apr 2010    Post subject: Reply with quote
Arh piss! I used WD40 a month or so ago.... Guess I can hope it hasn't gotten in the o-rings Praying
Paxovasa
PostPosted: 17:15 - 26 Apr 2010    Post subject: Reply with quote
If it was a one off I wouldn't worry about it.
But continual use of WD40 on a drive chain will shorten its life.
PostPosted: 17:18 - 26 Apr 2010    Post subject: Reply with quote
t121anf wrote:
I'm sure I paid half that for mine, can't remember where from though so not much use Laughing
What I do is get a rag soak it in petrol, and rub it into the chain then you the brush to shift the stubborn stuff then a cleaner rag. I would just the brush on it;s own first if it was really dirty.
Charlie
Well the chain hasn't needed adjustment after fitting just a front sprocket. Everything else was fine so I bought a cheap front sprocket and thought it might give me a 1000 miles and my chain will die. Or it could last, and it seems to be lasting. I guess running with a Scot Oiler will help. I'd really recommend a Gold DID chain.
lewis87
PostPosted: 17:28 - 26 Apr 2010    Post subject: Reply with quote
WD40 is safe to use on O-Ring chains, the O rings are sealed and it does not get inside. I always use it to clean my chains and it does not shorten the life of my chains. WD40 guys say it is safe to use to clean chains too.
WD40 does not even damage rubber even if it did happen to get to the O-Rings...
PostPosted: 17:34 - 26 Apr 2010    Post subject: Reply with quote
If the WD40 is getting past the O ring, the O ring has already failed.
lewis87
PostPosted: 17:35 - 26 Apr 2010    Post subject: Reply with quote
Exactly, Paxovasa is talking out of his arse.
PostPosted: 17:39 - 26 Apr 2010    Post subject: Reply with quote
...never fails Thumbs Up And cheap as chips. Very safe degreaser/cleaner.
PAt
Paxovasa
PostPosted: 17:40 - 26 Apr 2010    Post subject: Reply with quote
You continue to use WD40 then.
I choose not too Thumbs Up
I dont seem to be the only one to believe that WD40 is bad for a chain.
And please keep it civil.
supZ
PostPosted: 17:45 - 26 Apr 2010    Post subject: Reply with quote
i also wouldnt use WD40 on my chain
CBR954RR - Daily toy
CBR600RR - Trackbike
skatefreak
PostPosted: 17:52 - 26 Apr 2010    Post subject: Reply with quote
Now i know this isnt quiet the same thing but my BMX i used to get to work (fairly long ride with a biigg hill or two) has survived 2 years and after not using it over winter it was practically rusted solid!
Threw a bunch of old engine oil over it, kept turning the pedals and after a few days of riding, bobs your unkle, looks nearly new again (black oil acting as camoflauge maybe?) but still works just fine heh.
The sprockets on my nsr were worn something horric (thin and almost wavey (on a bike allegedly 7,000 miles old Neutral), chain in about the same condition lol. New chain and sprockets, am looking at some wax as i only have the sprey outt'a a can stuff at the mo which cant be that great Neutral
-Jvr
lewis87
PostPosted: 17:53 - 26 Apr 2010    Post subject: Reply with quote
Ok sorry Very Happy
Arguing about WD40 is a bit like arguing what oil is best.
The last post was made 16 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 132.1 Kb
