How bad is this?
jaxx
PostPosted: 22:16 - 17 May 2010    Post subject: How bad is this? Reply with quote
Ill save us all a lot of hassle, and cut a long story short...
Whilst riding to a training session earlier, the chain became loose on my gsxr750. Thumbs Down
Then the back wheel locked... Thumbs Down Thumbs Down
It then freed up Thumbs Up
and the chain trashed everything it came into contact with... Thumbs Down Thumbs Down Thumbs Down
Crying or Very sad
Basically, its smashed something containing coolant, just behind the clutch adjustment cover on the engine.
What is this? Is it the pump housing? Are they mega-bucks? Is it fubar'd? Should I keep Crying or Very sad , or just Sad
Thanks in advance for any help
Karma accordingly...
Cheers,
Jack
PostPosted: 22:28 - 17 May 2010    Post subject: Re: How bad is this? Reply with quote
That's the place the expansion bottle will typically go.
It's not mega-essential, but worth replacing.
When the radiator gets too hot, it will vent into there - as it cools it sucks it back into the radiator.
Often taken off on race bikes and the like.
jaxx
PostPosted: 22:35 - 17 May 2010    Post subject: Reply with quote
Ok, sounds good... Thumbs Up
Just for my own piece of mind, is that normally made out or a metallic material?
Because there was a big old shard of metal in the bottom of the fairing when I stopped... Question
Hopefully thats all it'll be, or something equally minimal...
Cheers G Karma
PostPosted: 22:40 - 17 May 2010    Post subject: Reply with quote
Usually plastic - however there's likely to be bits of metal around.
Might be best if you could get some pics.
jaxx
PostPosted: 22:45 - 17 May 2010    Post subject: Reply with quote
My plan is to get the fairing off 1st thing tomorrow, then have a proper survey of the damage... Praying
Ill keep you posted, possibly with pics...
Cheers for the tips, gives me somewhere to start...
Jack
Phoenix
Twisted Firestarter
PostPosted: 00:04 - 18 May 2010    Post subject: Reply with quote
Did your chain actually snap or come off? You need to remove the front sprocket cover really and make sure it hasn't cracked the crankcase anywhere (the main 'shell' of the engine). That lump of metal must've broken off somewhere so find it. You might be lucky and it's just part of the sprocket cover or something else that can be replaced, not always that lucky.
prawny1
PostPosted: 00:13 - 18 May 2010    Post subject: Reply with quote
It's unusual for a chain to suddenly become loose, if you have damage around the front sprocket area i'd say the sprocket has come adrift or the teeth have sheared maybe output shaft or rear wheel bearing collapsed even.
If your lucky the metal will be just part of the sprocket cover, if not it could be part of the crankcase.
hellkat wrote:
jaxx
PostPosted: 09:47 - 18 May 2010    Post subject: Reply with quote
Ok, Cheers for the tips guys, always nice to know where to start....
It is now the morning after, and I am feelin a little calmer about the whole situation. Neutral
A friend/neighbour has offered to lend me a bike of theirs to use until I get my baby fixed/evaluate the damage...
Im just headin outside to start stripping the fairing etc...
Expect updates,
Jack
jaxx
PostPosted: 11:12 - 18 May 2010    Post subject: Reply with quote
Meant to say before, the chain broke.
The fairing is off, i've stripped it down to the damaged parts Thumbs Up
The sprocket cover has taken the brunt of it, but is just about still usable, only one fitting point sheared off.
The part thats confusing me is the part that was holding a lot of coolant, its not the reserve tank I dont think, as tis is mounted by the fairing. Its round, and appears to bolt on to the engine, directly infront of the front sprocket.
All in all, pretty repairable I would say at this point, but we shall see. Neutral
Next job is to take the unidentified damaged part off, and head to my local garage, to find out A) What is it, B) How much is it & C) How soon can they get me one!!!
Jack
Jimbo6_uk
PostPosted: 11:31 - 18 May 2010    Post subject: Reply with quote
Post some pics up so we can try and identify it?
nightshaddow
PostPosted: 11:39 - 18 May 2010    Post subject: Reply with quote
theirs allot of knowledgeable guys here, and there not in it for profit, always get a couple of opinions if the bike is not going to the garage, they might get confused lol
pics are always handy
jaxx
PostPosted: 12:33 - 18 May 2010    Post subject: Reply with quote
Whoop! Parts Identified!
They are, The Water Pump Housing, Obliterated, but the mountings are ok-ish...
Front Sprocket cover, Badly Damaged - will replace if I can find one for the right price.
So, to summarise, the parts I need are
Arrow New Chain
Arrow New Sprockets
Arrow New Pump Housing
Arrow New Sprocket cover
Im gonna have a look about for prices now, what would you expect to pay for that little lot?
Cheers again all
PostPosted: 12:55 - 18 May 2010    Post subject: Reply with quote
Arrow New Chain Arrow New Sprockets - £100 or so for a set, maybe a little more.
Arrow New Pump Housing - maybe £25 or so, depends on the year of the bike and how lucky you are, on the second hand market.
Arrow New Sprocket cover - you don't NEED a sprocket cover, again £10 or so, depending on the second hand market (racers often don't use them, so worth looking that way.
StevenF
PostPosted: 13:30 - 18 May 2010    Post subject: Reply with quote
This thread needs pictures! Smile
jaxx
PostPosted: 21:56 - 18 May 2010    Post subject: Reply with quote
Well, thanks for all the input, its been most appreciated.
I've got the chain and sprockets, cost £120 for the kit.
I've had no luck sourcing the new parts, other than new, and thats gonna cost... Sick
Also, just realised that the clutch push rod was sheared too, will need replacing.
Have looked into it, and the part I was calling the sprocket cover encorporates the clutch adjuster, so is an unfortunate nessescity.
Am waiting on a few places, so when I hear, I will let you know.
Also, Im working on the pics, if only to whore the damage Laughing , but my camera has decided to freak out. Would buy a new one normally, but im afraid fixing the bike will cost everything I have... Thumbs Down
Will try and borrow a friends...
Ps. The FZX750 I have been loaned is a winner! Cheers Paul!
Cheers,
Jack
tutton
PostPosted: 14:01 - 19 May 2010    Post subject: Reply with quote
Uhhm why exactly did the chain snap tho?
poor maintainance? way pasts its replacement mileage? no lubrication?
jaxx
PostPosted: 15:45 - 19 May 2010    Post subject: Reply with quote
All of the above!
I've always been pretty lax in the maintinence department, not that thats an excuse. Confused
Im fully aware that it is my own fault, and that I have cost myself a fair few quid, not to mention a f@*kload of hassle. Evil or Very Mad
But its made a lot easier with all of the helpful replies I've had on here, and of course, by my neighbour loaning me a bike. Thumbs Up Thumbs Up
Time to dust off the toolkit I guess... Thumbs Down
tutton
PostPosted: 15:47 - 19 May 2010    Post subject: Reply with quote
Wasnt ment as a jibe just a reminder that neglecting that kind of thing could have turned out much worse, have seen pics of chains slapping peoples legs after snapping and causing some nice damage.
jaxx
PostPosted: 20:43 - 19 May 2010    Post subject: Reply with quote
Cheers mate, I wasn't sure in what context you had said it, think I just took slight umbrance at someone pointing out my blatant lack of maintinence... Embarassed
No harm done, and I appreciate the amount of damage that could have been done, to me, not the bike! Was very lucky...
As Im hoping to start teaching Kung Fu soon, my legs are pretty important to me... Laughing Thumbs Up
https://www.southfloridaracing.com/forums/showthread.php?t=53317&page=1&pp=15
Shocked
Its a 98 model, GSXR 750SRAD.
Do you think they'd fit?
Would be most interested if they do... Thumbs Up
Cheers all
Jack
temeluchus
PostPosted: 23:39 - 19 May 2010    Post subject: Reply with quote
I doubt it. Engines are not related.
PostPosted: 18:06 - 20 May 2010    Post subject: Reply with quote
Shouldn't be too hard to find a srad water pump. Try on the oldskoolsuzuki forum.
The last post was made 16 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 114.64 Kb
