Adding a Cigarette Lighter to your bike
kingsknight
PostPosted: 14:39 - 01 Jun 2010    Post subject: Adding a Cigarette Lighter to your bike Reply with quote
Alright guys,
Just wondering how many of you guys have added you own Cigarette Lighter sockets to you bikes? My understanding of adding one to my is that it is quite a simple job! My question is, is there a chance that I could fry the battery or something by adding one?
I'll only be charging my phone, GPS, and netbook on it! (one at a time)
I really want to hear from people who have done it! Had any problems?
I do believe the XR has quite small battery. Im sure it would have enough in it to charge all 3 of them devices and start the time. If not its a very easy bike to bump start!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
Mr.Everready
PostPosted: 14:41 - 01 Jun 2010    Post subject: Reply with quote
Do a quick search, there's been loads of posts about it. They can be bought from Ebay for under £5.
Doovy
PostPosted: 14:48 - 01 Jun 2010    Post subject: Reply with quote
I've done it.
Hein Gericke.
5 minute job.
too easy to warrant a proper explanation! just wire it to batter with inline fuse. hidden under seat.
kingsknight
im far to lazy to click the search button :-p
carlito8
PostPosted: 14:54 - 01 Jun 2010    Post subject: Reply with quote
If you use an accumate charger you can get a cigarette lighter or DIN type socket which clips on to your charger cable, bought one myself last week for a fiver.
MonkeyKnuckle
PostPosted: 16:28 - 01 Jun 2010    Post subject: Reply with quote
Look for a 12v marine socket, they're waterproof.
MKGaming.com
kitty kat
PostPosted: 17:42 - 01 Jun 2010    Post subject: Reply with quote
I got mine from Halfrauds, really easy to fit and I have used it to run my sat nav, charge rechargeable batteries and a scala rider, power the pump to inflate the airbed.
Once you have one fitted you will find it really useful.
PostPosted: 17:56 - 01 Jun 2010    Post subject: Re: Adding a Cigarette Lighter to your bike Reply with quote
Consider using a different kind of socket - I find the lighters ones cumbersone and insecure.
I bought some general sockets from vehicle wiring products (google for it) and used them - smaller and more secure for charging. Also daisy chained some for charging multiple things while riding, which worked nicely. Still often use it for a min-compressor.
The KTM nicely has 'accessory' wiring - if I didn't, I think I'd wire in a relay and fuse.
Whosthedaddy
PostPosted: 18:47 - 01 Jun 2010    Post subject: Reply with quote
I posted a step by step pic of my socket on the TRX, will find the link if I can be arsed later, or you could search for it instead.
deanoet
PostPosted: 18:53 - 01 Jun 2010    Post subject: Reply with quote
Powerlet
They do a kit that plugs into a tank bag and ends in a cigarette lighter style socket. Looks very neat and tidy, if a little expensive
Powerlet Solution
Inside the tank bag
Tank bag NOT included in powerlets costs
Pernig
PostPosted: 19:10 - 01 Jun 2010    Post subject: Reply with quote
I'm with G on this one in that as they are designed to stick out of car dashboards they are quite cumbersome.
I have a triple one which also has a USB port and I try and use the USB when I can as it takes up far less space. The socket itself doesn't take up too much space, it's the big chargers that stick out of it.
I can vouch for the £3.50 Hong Kong eBay triple sockets with USB port. I've had mine stuffed under my seat for two winters now and it still works just fine.
H100 Breaking for spares
Flip
PostPosted: 19:45 - 01 Jun 2010    Post subject: Reply with quote
I bought a kit (socket, wires & inline fuse) form HG that cost around a tenner and took 2 mins to fit. Very useful. Smile
https://www.hein-gericke.co.uk/shop/product_info.php/cPath/23_53/products_id/7041
kawakid
PostPosted: 19:53 - 01 Jun 2010    Post subject: Reply with quote
I use the extension type of cigarette socket, I cut the mail end of at wire it in to a relay.
Using a relay, means your not overloading the wiring (your cig socket gets its power from the battery directly), a trigger from something like a rear light tells the relay to open up.
If you need a wiring diagram let us know. It's really quite easy though.
I've a twin and a 4.
PostPosted: 19:59 - 01 Jun 2010    Post subject: Reply with quote
I found all my stuff at the bottom of a tool box in my garage so it cost me nothing to fit Razz
Clicky
I didn't bother with a relay for three reasons:
1. It would have cost me money.
2. My bike is kickstart.
3. My PDA doesn't hold charge very well so if I turned the bike off I'd have to boot it up again once the engine was running and that takes ages.
Whosthedaddy
PostPosted: 22:54 - 01 Jun 2010    Post subject: Reply with quote
"]https://www.bikechatforums.com/files/04092009787.jpg
They had several sockets but opted for this one as its designed for marine applications and its quite rugged to the touch with a splashproof cover.
First started by tinning the wires to then be crimped into the female terminals.
https://www.bikechatforums.com/files/04092009790.jpg
As the wires will be exposed to the elements as it were, I decided to tin them rather than just crimp in place. It should offer some form of resistance to corrosion anyways?
The wires were then cut to length after test fitting the securing plate to the frame. God bless a trellis frame!
https://www.bikechatforums.com/files/04092009797.jpg
After cutting, the other end of the wires were tinned and soldered to the spade fitments.
https://www.bikechatforums.com/files/04092009794.jpg
The socket was then screwed into the securing plate, wires secured along the frame and connected to the battery terminals.
https://www.bikechatforums.com/files/04092009796.jpg
All done!
https://www.bikechatforums.com/files/04092009798.jpg
https://www.bikechatforums.com/files/04092009800.jpg
It has an in line fuse now added to the +ve line. Cant for the life of me remember what size though (10 or 15 I think, probably a little over kill for what is needed but hey ho).
Dan79
PostPosted: 23:18 - 01 Jun 2010    Post subject: Reply with quote
As a non smoker I am slightly at a loss to comprehend why you need a cigarette lighter on a motorbike. Surely you need to take your gloves off to fish about in your pockets for a packet of fags and extract one from the packet, so why not grab your cigarette lighter at the same time?? Though as a non smoker I admit I am probably missing the whole point.
P.S. as a motorcyclist who is sick to death of car and van drivers tossing fag ends out of their windows in front of me I'm sure you are one of those rare mobile smokers who don't have the filthy habit of flicking little missiles of fire into your slipstream.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
Flip
PostPosted: 23:19 - 01 Jun 2010    Post subject: Reply with quote
Dan79 wrote:
As a non smoker I am slightly at a loss...
It's a 12v socket. Not a lighter. Wink
I do this. I'm not using the ashtray. The world is my ashtray. Wink
Dan79
PostPosted: 23:22 - 01 Jun 2010    Post subject: Reply with quote
An apology is due from me - I did not absorb the original message in full ! I do realise the other uses for a cigarette lighter.
Humbly
The last post was made 16 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 100.41 Kb
