Zxr750/900 build
kat250
PostPosted: 22:15 - 12 Jun 2010    Post subject: Zxr750/900 build Reply with quote
Well the time has come to finally do something with the zxr750 sitting in the garage for the last couple of years doing nothing.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2140003.jpg
Picked it up as a crash damaged bike just needing a few bits sorted. Well when i dove in i discovered more often than not with projects a lot more of the bike was f*cked than i had initially realised. The rad bracket that goes onto the engine was beyond use as was the radiator it had also managed to hole the pipe that feeds the cams om the left hand side. Tried to change it and the bolt holding from the bottom broke. I lost interest at this point.
Due to lack of fund and moving it sat again without me looking at it till now.
I had looked into putting a 900 engine in the bike for a while after reading the guide on Andy's zxr7500 site. Luckily a family friend happened to be breaking a 900b so picked up a head gasket failed 900b engine.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2140002-1.jpg
It appeared to be all there and if anything was missing i could get anything off his spare 900 Smile .
So i dug it out today and started stripping bits off so the engine so i could drop it out.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1270045.jpg
The engine was dropped out and given away promptly (J1 model crappy capped 100bhp new)
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1270047.jpg
Drilled top yoke and fitted some risers with a set of renthals.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1270048.jpg
This is far as i got today.
The plan is a fighter project its for my step dad really as he cant take the strain with clip on's also i never got any fairings with bike so not going to spend money trying to get any.
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
Barry_M2
PostPosted: 08:44 - 13 Jun 2010    Post subject: Reply with quote
Nice Wink Thumbs Up
I've done this mod in the past on a ZXR750, but I put on a big bore kit taking the motor up to 950cc. I've also recently brought a ZX7 with ZX9 motor in it which I use as my track bike.
The swap is very easy on the ZXR chassis, you just need to drill out the two engine mounts on the head as it is a few mm out. You will also need to grind a little of the front left mount away as the oil plate and line fouls it ever so slightly.
Oh, and remember to use the ZX9 ECU too as it has a low red line than the ZXR and you don't want to go blowing the motor! Wink
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
kat250
PostPosted: 22:29 - 13 Jun 2010    Post subject: Reply with quote
Yeah that's pretty much what i did today Barry
Well started a bit late today but hey. Dug out the engine and proceeded to check the barrels finding one of the cylinders full of water blew it out and pulled the barrels off and had a check.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1270040.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1270041.jpg
All appeared OK so cleared away the rust and and put the barrels back on. Fitted the complete top end roughly without the cams to get an idea of the dimensions.
Sat the lower back engine mount and used a jack to raise the engine into place. As stated in the guides on Andy's zxr site a small chunk needed to be removed from the left hand frame mount for the oil way.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1280051.jpg
Thus begun a long repetitive cycle of lowering and raising the engine till it sat right.
Got the rear engine mounts into place and then drilled the top engine mounts to line up with the frame. Last thing for the night was to take a bit out of the back of the engine mount so a nut would onto the bolt.
Will get picture later with the engine mounts and the engine sitting later.
kat250
PostPosted: 22:37 - 16 Jun 2010    Post subject: Reply with quote
Well the engine is now to a point where all the mounting points are sorted drilled and ground out enough
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1290043.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1290042.jpg
Was fairly surprised at how easy it was to do.
Got the carbs and airbox sat in place with the tank and seat and it all seems to sit ok. Was a bit worries with the height difference mating up the airbox and carbs to the engine but seems fine.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1290040.jpg
So dropped the engine back out to start sorting it.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1300045.jpg
Pulled the head and barrels back off to strip the crap paint a previous owner had put on. Also popped the valves out to clean then and re grind them back in. Also checked for warp but appears to be within tolerances.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1310049.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1300048.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P1310050.jpg
So next thing is to clean the gasket faces and mask the head and barrels off and give them coating of some heat resistant paint when i can get some and if i can find any PJ1 in silver..
Tattoo Artist
PostPosted: 18:39 - 17 Jun 2010    Post subject: Reply with quote
nice man, and seeing your ashtray in the background made me clean mine lol, karma Smile
Grimnir
PostPosted: 20:27 - 17 Jun 2010    Post subject: Reply with quote
You gonna clean those valves?
kat250
PostPosted: 22:30 - 17 Jun 2010    Post subject: Reply with quote
Yeah they'll get cleaned before i have the fun task of putting all 16 valves back in Neutral kinda been putting it off since re grinding them.
Grimnir
PostPosted: 22:56 - 17 Jun 2010    Post subject: Reply with quote
Fairynuff. Keep the pics coming!
Barry_M2
PostPosted: 13:36 - 18 Jun 2010    Post subject: Reply with quote
If you do think this is a problem, I have a set of short intake rubbers which will allow the carbs to sit about 10mm closer to the motor, giving a little more clearance.
Looking good so far Thumbs Up
kat250
PostPosted: 22:27 - 21 Jun 2010    Post subject: Reply with quote
Barry will let you know if i need any thanks Thumbs Up . Hopefully should be fine got a set of 750 and 900 inlet rubbers to go on.
Well a bit of a slow time since the last update. Ordered the full gasket set at the nice sum of £160 odd quid from Kawasaki Shocked . To be told it would take two weeks as there wasn't one in the UK..
So pulled more of the engine apart and started to clean the bottom end up.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020040.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020041.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020042.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020043.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020046.jpg
Also did this to check for debris and found who ever did the clutch last had a big thing for instant gasket and it was everywhere. The oil strainer was clogged with it Sick . Also found that when the clutch was last done one of the tangs for the plate that sits under the clutch retaining nut had snapped and disappeared into the engine, apart from that all looks to be good.
So left the bottom end to look at the back end. The previous owner had slid it down the road so there was a few scars from this. Pulled the swinging arm off with a bit of force thanks to the pivot bolt being seized to the bushes(luckily every other bearing bush was ok.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020045.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2020044.jpg
So filled some of the deeper dings and flattened it off a bit still a bit to go. Also started stripping the rear wheel as the paint was a bit far gone in places.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/P2050050.jpg
So yeah my list of things to do slowly gets bigger..
kat250
PostPosted: 21:45 - 26 Aug 2010    Post subject: Reply with quote
Big jump since last update she runs and is almost back together Very Happy
Pics to follow.
CHR15
Turbo nutter bastard
PostPosted: 20:12 - 02 Sep 2010    Post subject: Reply with quote
pics?
Benson_JV
PostPosted: 20:34 - 02 Sep 2010    Post subject: Reply with quote
Pictures would indeed, be appreciated!
kat250
PostPosted: 21:34 - 02 Sep 2010    Post subject: Reply with quote
Yeah sorry been a shit week with deaths so not had a chance to update. I'm also away to stormin the castle tomorrow so might get pics up Sunday evening or Monday.
It will prob be in the show on the sat so look out for the scabby as f*ck zxr750 if your at stormin.
joe.
PostPosted: 23:41 - 02 Sep 2010    Post subject: Reply with quote
looks like a crackin project mate, will be nice to see how it looks when its finished. just a question how did you get the wheels to come up like that, the wheels on the bandit im picking up Saturday are shite and want to try and polish the rims myself
cheers
joe
current: firestorm
previous:gsxr 750, rsv, fz6, xj6, firestorm, bandit 600/825, zx7r, gpz500, gs500, zzr600, xj600, zzr600, cbr 600, xj600, cb500, Kawasaki Gpz500, Aprilia rs125, Suzuki gs 125, Kawasaki gpz 500, Suzuki gt 185, Yamaha dtr 125, Yamaha ybr 125, cagiva mito, Yamaha dtr 125, Honda ns 125, Honda cb 125t, derbi senda, gilera dna, peugoet speedfight, gilera runner, mbk mach G, gilera gsm, derbi gpr, peugeot speedfight, italjet formula, derbi predator. since january 2009.
c-m
PostPosted: 20:08 - 15 Sep 2010    Post subject: Reply with quote
I used to own a ZXR750, loved it.
Now i own a 9R.
Just wondering, why put a 9 engine in the z750. The J model is 195kg as it is. Adding the 9 engine will only add to this weight.
Would you not have a faster better handling and more comfortable bike if you just got a post 98 ZX9R?
Loving the pics though, looking forward to the next instalment.
There is a gap of 219 days between these two posts...
kat250
PostPosted: 10:46 - 23 Apr 2011    Post subject: Reply with quote
A quick update it was running made stormin the castle and decided it needed nicer bits.
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/DSC00031.jpg
https://i128.photobucket.com/albums/p183/babykat250/zxr750900/DSC00030.jpg
More to come when i get some spare time Laughing
CHR15
PostPosted: 11:32 - 23 Apr 2011    Post subject: Reply with quote
.....or 8 months later!!!
kat250
PostPosted: 15:45 - 23 Apr 2011    Post subject: Reply with quote
Yeah that to Laughing To be fair i was having too much fun on it Very Happy
Whosthedaddy
PostPosted: 20:00 - 23 Apr 2011    Post subject: Reply with quote
Very well done, I certainly wouldn't say no to another ZXR, add some extra ponies and jobs a good 'un.
dixiethedog
PostPosted: 19:32 - 26 Apr 2011    Post subject: love the swingarm! Reply with quote
Hi,im new to this site,have just spotted this build and think it looks great! Im doing a zxr fighter myself,which i'll post a build up thing here soon.
I was wondering about the swingarm??? What is it from,as i love the look???
Thanks in advance.
dixiethedog Very Happy
kat250
PostPosted: 21:59 - 26 Apr 2011    Post subject: Reply with quote
The swingarm is zx10r.
dixiethedog
PostPosted: 16:12 - 27 Apr 2011    Post subject: Reply with quote
Thank you Kat250,looks like i need me a zx10r arm for my zxr!!! Imitation is the most sincere for of flattery.....
The last post was made 15 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 128.52 Kb
