project KTMito
steven_191
PostPosted: 01:10 - 14 Feb 2011    Post subject: project KTMito Reply with quote
i might as well start the thread now then.
yes it a Mito KTM frankenbike.
so kind of sheer fortune meant that this project is a goer.
on ebay the other day i saw a KTM LC4 640 engine and though, yeah that looks good but the sprocket is on the wrong side to the Mito (which i already have) so i also found an aprilia RS125 front and rear end.
so me and chris-red went to pick it all up and had a go at bolting it together, bearing in mind i hadnt measured anything or investigated wheather or not this would work.
the RS125 swing arm fits in the Mito frame with around half inch of play. the swing arm wraps around the rear mount of the KTM engine like it was designed to fit it. Like a glove (in an ace ventura voice) and the engine also sits within the frame with small gap between what i think is possibly a water pump housing and the inside of the frame. the RS125 front end we put on just to see how it all looked.
so heres some pics adter about 2 hours work
steven_191
PostPosted: 01:20 - 14 Feb 2011    Post subject: Reply with quote
the problems i will be facing are
-carb hits the top frame crossmember
-most likely a custom exhaust
-mounting the rear shock
-lots of wiring!!
main problem looks like the rear shock. the RS125 and Mito have a linkage type shock, so on the swing arm the mount isnt visable from the top so cant bolt a shock in from above and because its a frame and swing arm off different bikes, it might not be easy to recreate a linkage. i think the swing arm it too far forward to have enough space. maybe.
as for the carb, the top crossmember is welded. so i can get that redesigned and moved and at the same time possibly redesign the rear shock mounting. not sure if i can move the carb around and change the intake track as it will have to have bends in it which i dont want really.
from the pictures it looks like the frame is too high in the middle. not sure how much it can drop as the left hanger mount touches when its lowered. so either cut it off and mount the hanger elsewhere or leave it high. but that means higher centre of gravity.
as for looks, im thinking of a naked style, black and gold possibly. might even go for renthal bar but we'll see.
PostPosted: 01:53 - 14 Feb 2011    Post subject: Reply with quote
Wrong Forum dickhead it should have been in show and tell.
More pictures.
https://img.photobucket.com/albums/v295/chris-red/IMG_0361.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0360.jpg
Exhaust Routing
https://img.photobucket.com/albums/v295/chris-red/IMG_0358.jpg
Comparing the angle of the bikes angles to a standard mito.
https://img.photobucket.com/albums/v295/chris-red/IMG_0357.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0354.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0355.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0348.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0345.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0342.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_0340.jpg
PostPosted: 01:56 - 14 Feb 2011    Post subject: Reply with quote
I don;t thing the exhaust or wiring will be a problem you have the full KTM loom, and the exhaust isn't far of fitting stock.
The rear shock will be the biggest problem followed by mounting the carb.
steven_191
PostPosted: 02:21 - 14 Feb 2011    Post subject: Reply with quote
your the problem Chris Middle Finger
hmmmnz
PostPosted: 03:22 - 14 Feb 2011    Post subject: Reply with quote
thats pretty damn good,
i wouldnt even call those problems,
just tiny little hick ups,
karma for both you 2 bitches Thumbs Up
the humans are dead
I kick arse for the lord
Frost
PostPosted: 04:13 - 14 Feb 2011    Post subject: Reply with quote
Maybe moving the engine forwards will get you some carb space?
https://cdn.bikechatforums.com/files/img_0447__small_.jpg
Even Seth Rogen is impressed.
mad4it028
PostPosted: 04:25 - 14 Feb 2011    Post subject: Reply with quote
can you not slant the engine forward enough to make room for the carb?
which will also lower the center of gravety or does the engine have to sit bolt upright?
steven_191
PostPosted: 09:20 - 14 Feb 2011    Post subject: Reply with quote
The carb is pointing slightly upwards. Dropping the front of the engine still causes it to hit the frame.
Can't move it forward as it uses the rear mount which bolts through the frame, swing arm pivot and engine.
steven_191
PostPosted: 09:23 - 14 Feb 2011    Post subject: Reply with quote
Also I need to try to keep the engine level. For the oil level and for the carb. If it's not at the right angle I'm not sure how it will affect fueling.
steven_191
PostPosted: 13:48 - 16 Feb 2011    Post subject: Reply with quote
Because of the swing arm/frame combination I'm considering a custom swing arm. I've seen a few tubular types online which look good.
Does anyone know of any good engineering or bike shops in Essex that are worth contacting?
Tim..
PostPosted: 14:52 - 16 Feb 2011    Post subject: Reply with quote
Is putting the Aprilia wheel etc into the Mito swingarm not an option?
www.marshallracing.co.uk
KDub
PostPosted: 15:20 - 16 Feb 2011    Post subject: Reply with quote
Why would you want to lower the centre of gravity? It's better to leave it high.
Get ready for some propper engineering maths, taken from the book on Motorcycle Design and Technology:
(I'm going to use emoticons instead of real symbols though)
"There is only one precise angle of inclination that allows you to maintain your balance at any particular speed when cornering."
tan Very Happy = v^2 / (R^2 x g)
Where Very Happy is the lean angle, v is the velocity, R is the radius of the corner, and g is gravity (taken to be 9.81m/s^2, just use 9.81).
Of course in that equation there's no mention of the height of the centre of gravity, but you'll need the resullt of that equation for this one:
sin(ArrowVery Happy) = (t x sin Very Happy) / h - t
Where Arrow is a substitute for the symbol delta which means "the change in", t is the radius of the tyre (so a 160 size tyre has a radius of 80mm or 0.08m, there are further refinements to this, but I haven't learnt them yet), h is the height of the centre of gravity, and Very Happy is the result of the first equation.
Once you've got both answers just add them together and you'll find out the lean angle required for any given corner radius at any given speed.
You'll need to use SI units throughout, as in metres and metres per second.
So anyway the point of all this is that a bigger value for the height of the centre of gravity results in a smaller change in lean angle, which means you can go faster around corners.
It also proves that skinny tyres are the way forwards, anyone "upgrading" to a 180 section tyre from anything smaller is just kidding themselves. Especially on small bikes. The only time you need a wider tyre is when you're prepared to sacrifice mid corner speed for traction on acceleration.
steven_191
PostPosted: 16:35 - 16 Feb 2011    Post subject: Reply with quote
Because the mito has a banana shape arm the chain run on the left is flat. The right isn't and on the ktm the sprocket is on the right. So that was the idea of using the rs125. But they use a linkage type rear shock. The linkage mounts between the underneath of the arm and low down on the frame. The mito frame has a high up mount. I may be able to fabricate a linkage to cope with the big difference but then I don't think I could get the shock between the linkage and the top frame mount as it's not a clear run. (because they're from different bikes). The only options I cam see at the minute is custom swing arm or custom linkage, and whilst moving the top frame brace to suit the carb I also make it suitable for the shock. This option is good but how good would a tubular swing arm look?? Fucking good. That's how much Very Happy
steven_191
PostPosted: 16:41 - 16 Feb 2011    Post subject: Reply with quote
KDub,,,
That's excellent. I'm not going to try and move the centre of gravity at all. The engine is going where it fits and where it's straight and square. One question I had was about tires actually. I was wondering what it is that goes into the choice? I think the mito has a 110/60 or 120/60 or something.
So in short and without too much maths with faces instead of symbols, what's your advice on the setup? And when u say inclination, are you talking about the angle of the bike and it's other angles etc. If you look at my picture it looks like the swing arm pivot is too high but because of the shape of the frame if the 'suspension' (bit of wood) compressed the high point touches the frame. So I need to drop the front down of not have much suspension travel or have a high bike???
KDub
PostPosted: 17:18 - 16 Feb 2011    Post subject: Reply with quote
steven_191 wrote:
KDub,,,
There's a lot that goes into tyre choice, but ultimately it's a compromise between grip, lean angle, and cost. I would try and stick with what you have at the moment, if grip becomes an issue later on then it might be worth thinking about wider tyres or even better would be stickier rubber. Just out of interest, do you know how much power that engine's putting out?
Angle of inclination refers to the lean angle you're getting when cornering.
Frame geometry is complicated. I'd argue that the most important value to get right is the trail because it effects how quickly the bike falls into corners, round about 95mm is a good base to work off. If the forks you're using are roughly the same length as the stock forks, and the yokes have roughly the same offset then it shouldn't be too much of an issue. Just be really careful on the first ride, a lot of getting this right consists mainly of trial and error.
As for your swing arm, you want it sitting at somewhere between 10 and 12 degrees with nobody sitting on it. Most sport bikes seem to be around this mark. If it looks about right, then it probably is. When you say the swingarm touches the frame; where exactly and how much has the "suspension" compressed? You'll need to measure that between the mounting points, i.e. an uncompressed value, and a fully compressed value, and then work out the difference between the two; it the difference is more than your suspension can compress by then there's no problem.
Pictures of the suspension linkages would be a big help.
Don't let this put you off though, it's looking like a good project so far Thumbs Up
PostPosted: 17:21 - 16 Feb 2011    Post subject: Reply with quote
I was going to tell you I planned to put my maths a-level to use and work out the geometry of the standard Mito then we could try to keep the same/similar geometries.
Also surely lower CoG is better on a bike?
Someone should move this to S&T too.
JMC and Metchamex do swingarms, it won't be cheap mind.
PostPosted: 17:25 - 16 Feb 2011    Post subject: Reply with quote
KDub wrote:
steven_191 wrote:
KDub,,,
The engine is 55bhp (claimed), also I believe the RS125 wheel that is on it atm has a 130 wide tyre.
My idea was to keep the geometry of the new build as similar as possible to a standard Mito. The swingarm is about 50mm shorter though so the wheel base will be shorter.
PostPosted: 17:27 - 16 Feb 2011    Post subject: Reply with quote
Funny how this was posted a mere 16 hours after begging me to help you at the lock up. Wink
KDub
PostPosted: 17:48 - 16 Feb 2011    Post subject: Reply with quote
That tyre size shouldn't pose a problem, and sticking as close to stock geometry as possible will save an awful lot of messing around.
The swingarm being that much shorter is interesting though, on the one hand it should corner better, on the other you may lose a bit of traction on acceleration.
Another thing worth considering is where the CofG sits horizontally because having it towards the front will cause oversteer (and make stoppies easier) and having it towards the rear will cause understeer (and make wheelies easier). You can change it by mounting your engine accordingly. It's not an end of the world situation, more something to bear in mind on the test ride.
steven_191
PostPosted: 18:11 - 16 Feb 2011    Post subject: Reply with quote
you were only there to hold things. stop sounding like your doing any work here. fucking labourer!!
i cant remember which swing arm was shorter. ill take some more pictures and measurements next time im there. should be sunday.
as for suspension travel, i dont think theres much.
the engine is in pretty much the same place as the standard mito engine. its slightly higher though i think and a bit heavier.
sticking to the original geometry is a good idea but i dont think its possible with this swingarm hitting the frame issue. to solve it i need to either cut off the hanger mount or cut something out of the swingarm.
need to get more pictures!!!
PostPosted: 18:19 - 16 Feb 2011    Post subject: Reply with quote
The RS swingarm was definately shorter, I'm pretty sure it was by 50 something mm. I vote we just cut bits off till it fits. Laughing Have you got your helicoil kit yet?
steven_191
PostPosted: 18:22 - 16 Feb 2011    Post subject: Reply with quote
yes its amazing, i helicoiled one of the bolt holes in the mito casing today.
PostPosted: 19:25 - 16 Feb 2011    Post subject: Reply with quote
Come round and do the Triumph
MaybeGuy
PostPosted: 19:28 - 16 Feb 2011    Post subject: Reply with quote
i predict a fail unless you modify the frame crossbar around the carb.
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 143.39 Kb
