oil drain plug repair
at106
PostPosted: 17:23 - 22 Jul 2011    Post subject: oil drain plug repair Reply with quote
Whilst waiting for electrical parts to arrive to make my suzuki ts50x run i've decided to repair a few more problems which i've come across.
The gearbox oil drain plug was leaking until i drained the oil from it, after cleaning the area i found that the area around the plug was cracked and it looks to have been previously repaired. The thread has also been repaired with helicoil.
https://i448.photobucket.com/albums/qq202/at106/PICT0001-41.jpg
I'm looking for opinions on the best way to repair this. I dont have access to welding equiptment. I was thinking of using instant gasket silicone but i've read it breaks down sfter prolonged contact with oil.
Thanks in advance!
Bru
PostPosted: 17:46 - 22 Jul 2011    Post subject: Reply with quote
Many swear by JB Weld, which is a putty when applied; hardens to be relatively temperature-resistant, and is oil resistant too. You may find the best option (ie. bodge) is to clean the area around the plug with a good solvent (petrol, carb cleaner, white spirits, etc.) and scrubbing brush, and then massage up some putty and build it around the plug.
Be aware that the crack will still seep oil, although less so if you do the job in-between oil changes. This will affect how well the putty sticks to the metal. Try scoring the surface with a file to help the putty to key better to the metal. Work fast - the putty only has a few minutes before it begins to harden, which in this case is a minor bonus.
As to the effectiveness of the repair: that is down to you. All I know is, I have seen it used to seal a cracked waterpump casing, and that job has lasted years. Not pretty, though.
at106
PostPosted: 17:52 - 22 Jul 2011    Post subject: Reply with quote
Thanks for your reply! I'll see if i can get some JB weld tomorrow and give it a go. Currently the engine is out of the bike and on the kitchen table and it has no oil in it. I've tried using carb cleaner to get most of the oil out from between the cracks but theres still some there. Could i use a blow lamp to burn out the rest of the oil?
Drake
PostPosted: 17:56 - 22 Jul 2011    Post subject: Reply with quote
or you can take the bike to a welder and let them weld it, if the engine comes out then its better as a tig will fry any electronic brain in the bike plus it will last
BigGeeking
PostPosted: 18:11 - 22 Jul 2011    Post subject: Reply with quote
yeah for what it is takes. welders you dont want to be dripping oil on the tread path to your back wheel then run you engin dry of oil then bang.
get it welded also i dont want to ride over your oil Twisted Evil
Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
MickC
PostPosted: 18:12 - 22 Jul 2011    Post subject: Reply with quote
Jb Weld is the cheaper option, it does take a couple of days to set though. Having said that you can file and sand it afterwards to get a really good finish, i have used it in the past to repair broken engine fins so heat is no problem, and as already said by 'Bru' it is oil and petrol resistant. Just make sure the area is good and clean and free from paint.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Bru
DO NOT use a blowlamp to cook off the residue around the crack!!
2-stroke engines have a mixture of oil and PETROL in their crankcase = BOOM!
OK, so it may be the gearbox section but still - I reckon NO.
Drake
PostPosted: 18:14 - 22 Jul 2011    Post subject: Reply with quote
its for his gearbox as its 2 stroke so it wouldnt go bang as if it was for the crank, it wouldnt get any fuel,depending on where you go your probbally tokkin at upto £30 for that maybe less depending on welder, and you might need to get it hellicoiled again
jimbothe
PostPosted: 18:15 - 22 Jul 2011    Post subject: Reply with quote
JB weld is for amateurs.
Use quicksteel, the epoxy of the gods.
https://www.hemmingsdiy.co.uk/quickste.htm
I have used this many times and it's got myself and plenty of mates right out of the poo from gashed engine casings to blown exhausts to sump repairs.
Search the net and I'm sure you'll agree.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 18:18 - 22 Jul 2011    Post subject: Reply with quote
Before it's welded all that crap is going to have to be ground out of it with a die grinder.
at106
PostPosted: 18:35 - 22 Jul 2011    Post subject: Reply with quote
If i could get it welded i would but i can't find anywhere local that can do it. I'll have a look for quicksteel and i'll either use that or JB weld. And if it doesn't hold then i'll look at getting it welded.
So is it a bad idea using a blow lamp to clean up the area?
jimbothe
PostPosted: 18:38 - 22 Jul 2011    Post subject: Reply with quote
And nobody on here with a welder knows where you live because you didn't add a map location. Wink
PostPosted: 18:40 - 22 Jul 2011    Post subject: Reply with quote
No, but do it outside and watch you don't get it too hot because it will go from engine casing to soggy blob on the floor in the blink of an eye.
Get some normal soap and rub it on the casing. Watch for the soap turning black.
temeluchus
PostPosted: 18:45 - 22 Jul 2011    Post subject: Reply with quote
Give the area a thorough clean with solvents and allow to dry before applying the jbweld etc. Brake cleaner is a good one to use for this.
Make sure you let the epoxy set for at least 24 hours.
I have had carburettor float bowls held together with plastic metal, superb stuff.
ZRX61
Victor Meldrew
PostPosted: 21:37 - 22 Jul 2011    Post subject: Reply with quote
Horse shit.
They're not one night stands, they're auditions.
The last post was made 14 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 87.33 Kb
