| at106 |
 at106 Brolly Dolly
 Posted: 17:23 - 22 Jul 2011 Post subject: oil drain plug repair |
Whilst waiting for electrical parts to arrive to make my suzuki ts50x run i've decided to repair a few more problems which i've come across.
The gearbox oil drain plug was leaking until i drained the oil from it, after cleaning the area i found that the area around the plug was cracked and it looks to have been previously repaired. The thread has also been repaired with helicoil.
https://i448.photobucket.com/albums/qq202/at106/PICT0001-41.jpg
I'm looking for opinions on the best way to repair this. I dont have access to welding equiptment. I was thinking of using instant gasket silicone but i've read it breaks down sfter prolonged contact with oil.
Thanks in advance! |
| Bru |
 Bru Trackday Trickster
 Posted: 17:46 - 22 Jul 2011 Post subject: |
Many swear by JB Weld, which is a putty when applied; hardens to be relatively temperature-resistant, and is oil resistant too. You may find the best option (ie. bodge) is to clean the area around the plug with a good solvent (petrol, carb cleaner, white spirits, etc.) and scrubbing brush, and then massage up some putty and build it around the plug.
Be aware that the crack will still seep oil, although less so if you do the job in-between oil changes. This will affect how well the putty sticks to the metal. Try scoring the surface with a file to help the putty to key better to the metal. Work fast - the putty only has a few minutes before it begins to harden, which in this case is a minor bonus.
As to the effectiveness of the repair: that is down to you. All I know is, I have seen it used to seal a cracked waterpump casing, and that job has lasted years. Not pretty, though. |
| at106 |
 at106 Brolly Dolly
 Posted: 17:52 - 22 Jul 2011 Post subject: |
| Bru wrote: | Many swear by JB Weld, which is a putty when applied; hardens to be relatively temperature-resistant, and is oil resistant too. You may find the best option (ie. bodge) is to clean the area around the plug with a good solvent (petrol, carb cleaner, white spirits, etc.) and scrubbing brush, and then massage up some putty and build it around the plug.
Thanks for your reply! I'll see if i can get some JB weld tomorrow and give it a go. Currently the engine is out of the bike and on the kitchen table and it has no oil in it. I've tried using carb cleaner to get most of the oil out from between the cracks but theres still some there. Could i use a blow lamp to burn out the rest of the oil? |
| Drake |
 Drake World Chat Champion
 Posted: 17:56 - 22 Jul 2011 Post subject: |
or you can take the bike to a welder and let them weld it, if the engine comes out then its better as a tig will fry any electronic brain in the bike plus it will last ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 18:11 - 22 Jul 2011 Post subject: |
yeah for what it is takes. welders you dont want to be dripping oil on the tread path to your back wheel then run you engin dry of oil then bang.
get it welded also i dont want to ride over your oil  ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,, |
| MickC |
 MickC Spanner Monkey
 Posted: 18:12 - 22 Jul 2011 Post subject: |
Jb Weld is the cheaper option, it does take a couple of days to set though. Having said that you can file and sand it afterwards to get a really good finish, i have used it in the past to repair broken engine fins so heat is no problem, and as already said by 'Bru' it is oil and petrol resistant. Just make sure the area is good and clean and free from paint. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| Bru |
| Drake |
 Posted: 18:14 - 22 Jul 2011 Post subject: |
| divetime wrote: | yeah for what it is takes. welders you dont want to be dripping oil on the tread path to your back wheel then run you engin dry of oil then bang.
get it welded also i dont want to ride over your oil  |
its for his gearbox as its 2 stroke so it wouldnt go bang as if it was for the crank, it wouldnt get any fuel,depending on where you go your probbally tokkin at upto £30 for that maybe less depending on welder, and you might need to get it hellicoiled again ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| jimbothe |
 jimbothe World Chat Champion
 Posted: 18:15 - 22 Jul 2011 Post subject: |
JB weld is for amateurs.
Use quicksteel, the epoxy of the gods.
https://www.hemmingsdiy.co.uk/quickste.htm
I have used this many times and it's got myself and plenty of mates right out of the poo from gashed engine casings to blown exhausts to sump repairs.
Search the net and I'm sure you'll agree. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
 Posted: 18:18 - 22 Jul 2011 Post subject: |
Before it's welded all that crap is going to have to be ground out of it with a die grinder. ____________________ a.k.a 'Geri'
| at106 |
 at106 Brolly Dolly
| jimbothe |
 Posted: 18:40 - 22 Jul 2011 Post subject: |
No, but do it outside and watch you don't get it too hot because it will go from engine casing to soggy blob on the floor in the blink of an eye.
Get some normal soap and rub it on the casing. Watch for the soap turning black. ____________________ a.k.a 'Geri'
| temeluchus |
| ZRX61 |
 ZRX61 Victor Meldrew
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
