Kawasaki ZZR400 1990 Fuel Problem
leepick
PostPosted: 15:48 - 14 Apr 2012    Post subject: Kawasaki ZZR400 1990 Fuel Problem Reply with quote
just purchased a kawasaki zzr400 as a project, it seems to be starved of fuel (no fuel being sucked into the carbs)
i was wondering if these bikes use a fuel pump? as there isnt one present.
any help would be appreciated
Aprilia RS125
Drake
PostPosted: 16:13 - 14 Apr 2012    Post subject: Reply with quote
its a early 90's bike, old pre efi, no need for a pump, gravity fed.
https://www.madebyhandsofbritain.com/useruploads/maker_142/box_image/reg%20saus-mountains-boston-sausage_520.png
try the fuel filter
oh and wrong section so the image dsoes apply
leepick
PostPosted: 16:24 - 14 Apr 2012    Post subject: Reply with quote
try the fuel filter
how sure are you its ''gravity fed'' ?. im sure a fuel pump is needed. i also have a honda cbr 400rr nc23 hurricane and that is an 1988 an that has a fuel pump.
Aprilia RS125
Drake
PostPosted: 16:28 - 14 Apr 2012    Post subject: Reply with quote
does it hjave a hole for a fucking pump you mongoloid
leepick This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Drake
PostPosted: 16:32 - 14 Apr 2012    Post subject: Reply with quote
u find something that the plugs wit not exactly rocket science.
if you had a brain, you would be very dangerous
oh and leanr to type not using text speak. kthnksby
leepick
PostPosted: 16:34 - 14 Apr 2012    Post subject: Reply with quote
listen, the fuel isnt being sucked into the carbs, my cbr400rr has a fuel pump and is a 1988, my honda cbr 600 from 1996 had a fuel pump. this kawasaki zzr 400 hasnt got a fuel pump in but it LOOKS like it should have. all im asking is does the 1990 zzr 400 have a fuel pump?.. simple question
Aprilia RS125
Drake
PostPosted: 16:38 - 14 Apr 2012    Post subject: Reply with quote
CHR15 wrote:
carbs dont suck.
gravity pulls fuel from the tank into them.
like i said, engine suck and you blow cock lee
leepick
PostPosted: 16:47 - 14 Apr 2012    Post subject: Reply with quote
drake1994 wrote:
CHR15 wrote:
carbs dont suck.
gravity does NOT pull fuel into the carbs because the tank tap is not above the carbs its inline. DICKHEAD
Aprilia RS125
Drake
PostPosted: 16:50 - 14 Apr 2012    Post subject: Reply with quote
no but gravety pulling down on the above fuel force it into the carbs cunt, its pretty simple physics
RhynoCZ
PostPosted: 16:58 - 14 Apr 2012    Post subject: Reply with quote
Open the fuel cap and set fuel tap on PRI position, if nothing then it could be floating valve or worse.
I used to have quite similar problem on my GPz550, the problem was fuel cap, there's a tank breather and my was full of dirt.
RhynoCZ
PostPosted: 17:03 - 14 Apr 2012    Post subject: Reply with quote
drake1994 wrote:
CHR15 wrote:
carbs dont suck.
The engine does not suck fuel into the carburetor, carburator has floating valve and float which closes the valve if the carb bowl is full of fuel. The engine sucks fuel from the bowl and mixes it with air Rolling Eyes
BTW if you've got a vacuum fuel valve then the engine does open it by sucking air of it. Wink
nowhere.elysium
The Pork Lord
PostPosted: 17:06 - 14 Apr 2012    Post subject: Reply with quote
Such an angry young person.
Is there not a prime setting on the tap?
Stonefly
PostPosted: 17:10 - 14 Apr 2012    Post subject: Reply with quote
The ZZR400 does in fact have (or should have) a fuel pump.
Are you absolutely certain that it is missing?
You should be able to get a replacement for about 25 squids!
Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250
RhynoCZ
PostPosted: 17:15 - 14 Apr 2012    Post subject: Reply with quote
if were splitting hairs ( and sausages ) the engine actually just sucks air, this causes a depression in the venturi which causes fuel to be forced out of the carb.
but really, that's neither here nor sausage.
And English is my 3rd language so I made it simple Rolling Eyes
Carvel
PostPosted: 17:16 - 14 Apr 2012    Post subject: Reply with quote
Roughly 4 seconds of googling suggests that not only does the zzr400 have a fuel pump, but also that you are a fucking sausage
https://homemade-sausage.net/wp-content/uploads/2011/03/sausage-6644.jpg
mr jamez
PostPosted: 21:02 - 14 Apr 2012    Post subject: Reply with quote
Wrong.
Sload
PostPosted: 21:24 - 14 Apr 2012    Post subject: Reply with quote
Might be worth perusing over there https://www.zxrworld.co.uk/zxr400oc/index.php
Have a quick nose here https://www.bikechatforums.com/viewtopic.php?t=187973
And most definitely take your meds or a chill pill Thumbs Up
The last post was made 14 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 106 Kb
