Kh 125 Help
abc123321
PostPosted: 16:33 - 05 Sep 2012    Post subject: Kh 125 Help Reply with quote
Hello I have an old K9 P reg kh 125 2 stroke.
The problem is when I kicked her over the kick start snapped of the shaft that goes into the engine Sad
A bike shop told me some can be removed and a new one just slotted in but mine happens to be an engine out job to split the case.
Im bumping at the minute and was told to bump it in 2nd which seems to be working ok.
Anyone local to Coventry that knows how to do this job as I dont mind paying and supplying the tea Smile I have an indoor garage that can be used. If not I just have to bump her Smile
The bike shop quoted me £200 lol.
Another problem I had was the carb was blocked up with what looked like fluff when it was blown out with air, reassembled and she now pulls and runs without cutting out Smile
Anyway thanks for reading.
You get what you give in life.
Drake
PostPosted: 18:15 - 05 Sep 2012    Post subject: Reply with quote
not sure if you will have to split the cases, if you do i would pay the £200
WannaBeDude
PostPosted: 21:50 - 05 Sep 2012    Post subject: Reply with quote
At risk of the dreaded spam Karma , ramp and wrench on a45 will sort you out at 25 quid an hour, top bloke there, highly recommended. Karma Thumbs Up
PostPosted: 21:54 - 05 Sep 2012    Post subject: Reply with quote
Cases need to be split.
What bit did you break exactly. Friend snapped the little flappy kickstart pawl(sp) inside and engine out, cases split etc.
karthead
PostPosted: 11:16 - 06 Sep 2012    Post subject: Reply with quote
I do believe this has the same engine as i fixed. If I'm correct, there is the magneto cover on the left, then the left and right engine case, then the clutch/kickstart cover on the right.
I don't believe it would be that big of job as all you have to do is take the kickstart lever off, take off the clutch/kickstart gear cover (to do this you'll need to disconnect carby cover, carby and rubber tube from airbox), replace the shaft or whatever needs raplacing, put back together. Oh and drop the oil before doing it. You can take the clutch/kickstart cover off without having to take the cylinder/head off.
200 pounds seems a bit deer to be honest.
Good luck Smile
abc123321
PostPosted: 14:13 - 06 Sep 2012    Post subject: Reply with quote
Its the bit that just sticks out the engine for the kick start to clamp on to.
Im happy to just bump it as its easy enough. Maybe when I get some more knowledge I will attempt to fix or get it fixed.
Thanks anyway.
abc123321
PostPosted: 16:07 - 06 Sep 2012    Post subject: Reply with quote
Hey thanks mate. I can post a pic tomorow and yes saturday would be awesome if you had the time to have a look.
Coffee supplied mate Smile
Vincent wrote:
I had to do exactly the same on my sons bike, must be a weak point. I've still got a spare kickstart shaft if you need one. £200 for a garage to do the work is probably about right. the shaft is probably about £50, + gaskets, 2-3 hours labour and new oil.
EDIT: I've just remembered that I actually managed to fix R kids bike without splitting the motor. That's why I've still got a spare shaft. Can you post a pic of the offending shaft on your bike? I might be able to have a look at it for you on my way home on Saturday.
mccluskeyd
PostPosted: 19:10 - 06 Sep 2012    Post subject: Reply with quote
Yes, It does seem to be a weak point ; I had a KH125 engine for a while that was going to go into a project bike.
The splined shaft that came out of the RH casing was sheared in two, just where you would put the bolt through to hold it.
It seemed to be enough to get a grip on a kickstart to push it over without a sparkplug, but I never tried it in anger in case it rounded it off.
They were a damn good bike in their day ; and I have fond memories as I sat my test on one (back when two stroke dinosaurs ruled the earth !!)
abc123321
PostPosted: 20:37 - 06 Sep 2012    Post subject: Reply with quote
I will do a few pics in the morning ish mate as the camera leads at me mums.
Its a 4 speed (i think).
I got about 1/2 " left sticking out the engine mate it seems to have broke close to it.
Check the post tomorow please for the pics.
Thanks.
PostPosted: 20:42 - 06 Sep 2012    Post subject: Reply with quote
The old KH was rather nippy for it's day, 15hp standard I think. I had a nice metallic orange one which I swapped for a MBX50 and £200 for a bike for my stepson. The poor lad had it nicked and they sprayed it matt black over the perfect original paint Sad
DMCpro
PostPosted: 21:27 - 06 Sep 2012    Post subject: Reply with quote
Hi if your looking for a cheap fix find a nice solid think steel rod and weld it to the little chunk thats hanging out cut it down and make teeth in it it will take time but your own time doesnt cost you anything!
get a pic up of the damage
Honda CB-1, TS125X
VW Golf Estate
Tristan.
PostPosted: 23:53 - 06 Sep 2012    Post subject: Re: Kh 125 Help Reply with quote
covlad1970 wrote:
Anyone local to Coventry that knows how to do this job as I dont mind paying and supplying the tea Smile I have an indoor garage that can be used. If not I just have to bump her Smile.
I'd be happy to if Vincent isn't available. I'm a bit more local, willenhall. On some engines you only need to remove the clutch basket. Which is a piece of piss. Don't even need to drop the oil.
abc123321
PostPosted: 10:37 - 07 Sep 2012    Post subject: Re: Kh 125 Help Reply with quote
Thanks mate as im just in Walsgrave by the big Asda.
I think it needs a new piston and rings as there is a ticking niose now when I roll the bike back and forth.
Thanks
Here is a few pics.
abc123321
PostPosted: 10:41 - 07 Sep 2012    Post subject: Reply with quote
It had a replacement egine a few miles ago the guy told me as the old one blew up/
Its a k9 model but unsure of the engine gears.
Vincent wrote:
The early one was deffo a 6 speed, pretty sure the K9 is too Wink Count through them next time you go out. Idea
PostPosted: 10:49 - 07 Sep 2012    Post subject: Reply with quote
K9 is 5 speed.
karthead
PostPosted: 10:58 - 07 Sep 2012    Post subject: Reply with quote
Holy turdnugget that engine is way different to mine Laughing
Forget what I said before....
abc123321
PostPosted: 11:11 - 07 Sep 2012    Post subject: Reply with quote
Thanks mate. Yes beer tokens sounds good.
Do you want me to pm you my address later so you can send it of ?
The last post was made 14 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 131.63 Kb
