suzuki bandit cut out at lights now started again
neiloggy1
PostPosted: 15:22 - 15 May 2013    Post subject: suzuki bandit cut out at lights now started again Reply with quote
hi all
bought a 99 600n bandit a few week ago.
its been running fine up until now
I have used the bike everyday for work and its never let me down.
on the way home yesterday at a set of lights it just cut out and has refused to start since.
I got the bike home last night in a van eventually.
I tried starting it for so long the battery went dead so I left the battery on charge overnight hoping to solve the problem today.
so I get home from work battery on everything works
bike turns over fine but will not start
things I have tried so far ...
petrol fresh and plenty in tank.
petrol getting through to carbs and plugs are wet.
air filter is fine.
no loose connections or shorting out.
also when I taken no 1 plug out and put against frame then turned over spark was weak then would get loud backfire(boooom) Laughing
so I cleaned plugs up put back in and it started for about 30 secs then died again.
iam guessing could need new plugs or coil packing in.
any other ideas as don't want to spend a fortune on plugs,leads,coil pack,cdi etc
need the bike to get to work thanks in advance.
98 zx9r
sickpup
Old Timer
PostPosted: 15:32 - 15 May 2013    Post subject: Reply with quote
Try cleaning up all the points where the coils connect to the frame with emery cloth. The trim the HT leads where they go into the plug caps by about 5mm and then screw back into the caps. Also clean up the tangs where the wiring loom connects to the coils as well as the earth point on the back of the engine and the earth terminal on the battery.
Check the condition of the spark on all 4 plugs and report back to us.
neiloggy1
PostPosted: 15:36 - 15 May 2013    Post subject: Reply with quote
will crack on with this one now report back asap
battery only 3 week old
plugs look old and are 9eix ????
98 zx9r
hondakawasaki
PostPosted: 15:42 - 15 May 2013    Post subject: Reply with quote
get some new spark plugs Wink
neiloggy1
PostPosted: 15:54 - 15 May 2013    Post subject: Reply with quote
I would do but 9 quid a plug from local bike shop Shocked
want to make sure it is the plugs before I splash out
98 zx9r
Linux
PostPosted: 16:20 - 15 May 2013    Post subject: Reply with quote
Get the Mrs hair dryer out.
Two wheels are all I need.
neiloggy1
PostPosted: 16:28 - 15 May 2013    Post subject: Reply with quote
are you inplying bandits are dodgy in the rain Wink
98 zx9r
PostPosted: 16:46 - 15 May 2013    Post subject: Reply with quote
9 quid. Just buy some online if you can't be bothered to wait Laughing
neiloggy1
PostPosted: 17:32 - 15 May 2013    Post subject: Reply with quote
just found another local bike shop 27 quid for 4 ngk plugs
gonna cleanup and dry all connections trim leads
and buy new plugs tomorrow
report then
98 zx9r
duzzer
PostPosted: 17:47 - 15 May 2013    Post subject: Reply with quote
do u have a spark? a mate bought 4 plugs only to find out it was his 1-3 coil pack had gone? allso on my old rd125 flying down the road the cdi just stoped, check you do have a spark if not check, ht leeds, coil pack, loose wires on the coil pack, brakes/damage to wires, cdi or check to see if you have power from the fly wheel
Ariel Badger
PostPosted: 18:30 - 15 May 2013    Post subject: Reply with quote
Clean and dry all the plugs, it has flooded.
PostPosted: 18:58 - 15 May 2013    Post subject: Reply with quote
That is a different bike, coils do 1+4 or 2+3 Wink
neiloggy1
PostPosted: 19:11 - 15 May 2013    Post subject: Reply with quote
all connections cleaned up and dry
no loose wires or connections
all leads trimmed down 5mm
I have good spark from 1+4 at lead and plug end
not been able to test 2+3 as battery went dead again so quick charge and try 2+3 later
what I did notice when I taken tank off was that with fuel tap turned to on or reserve no fuel comes out
but trickles out when switched to prime
there is plenty of fuel in as fuel level is far higher than both filters inside the tank
hope that makes sense
also when I try to start the bike on prime you just get a loud BANG Laughing
98 zx9r
Poseidon
PostPosted: 19:28 - 15 May 2013    Post subject: Reply with quote
I don't know the ins and outs of bandits, but my fuel tap is the same on the triumph. Mine has a vacuum hose on the back, so that when it's in the run/reserve position, the fuel will flow. Without the vacuum (so when engine is off/hose isn't attached) you don't get any flow.
As for the "bang" with it on prime... Would suggest to me that there's a problem with your fuelling. I would start at the tank, work my way though the filter, taps, hoses, carbs etc trying to find something out of the ordinary.
1977 Honda CG125
Drake
PostPosted: 19:44 - 15 May 2013    Post subject: Reply with quote
£27, they saw you coming and got the lube out ready...
neiloggy1
PostPosted: 20:36 - 15 May 2013    Post subject: Reply with quote
Haven't bought any yet and cheapest on fleabay are 26 so if u know a cheaper place let me know ??
98 zx9r
PostPosted: 20:57 - 15 May 2013    Post subject: Reply with quote
If you can't afford CR9EK, just use CR9E. My bandit runs fine on them, all they do is spark..
Do you have an alarm fitted?
neiloggy1
PostPosted: 22:16 - 15 May 2013    Post subject: Reply with quote
Yes I have an alarm fitted but that works fine
Is the fuel tank as described above normal
98 zx9r
PostPosted: 22:21 - 15 May 2013    Post subject: Reply with quote
Yes it's normal. PRIME by-passes the vacuum tap.
What alarm do you have fitted?
duzzer
PostPosted: 23:55 - 15 May 2013    Post subject: Reply with quote
yes my bad sorry
neiloggy1
PostPosted: 10:29 - 16 May 2013    Post subject: Reply with quote
The alarm is a v2 m357t
Unsure of make
But it has a little key fob which you press to diactivate alarm or immob
But it works fine anyhow
So I put battery back on the bike about 6 this mornin before work
So checked spark to leads 1+4
And leads 2+3
And I have good spark to all leads
Cleaned up plugs and checked they all spark good
Put plugs back in
tank on
turns over won't start
So tank off again
And now I have no spark to any leads ???
I have disturbed no wires all fine
At this point was late for work so left it and got the bus
Will have a try again later
98 zx9r
duzzer
PostPosted: 12:57 - 16 May 2013    Post subject: Reply with quote
do you have a multimeater? test to see if theres power to the coils or from the ecu/cdi to the coils, sounds like the cdi's playing up or the ignition is falty
jjdugen
PostPosted: 13:04 - 16 May 2013    Post subject: Reply with quote
Kill switch contacts? Sidestand switch? Clutch switch?
neiloggy1
PostPosted: 14:02 - 16 May 2013    Post subject: Reply with quote
If any of these where at fault it wouldn't even turn over
But the bike turns over fine
Was sparking but now isn't
Multimeter it is and hours going through elecs I think
98 zx9r
neiloggy1
PostPosted: 17:40 - 16 May 2013    Post subject: Reply with quote
Well she runs again
Got in from work
taken tank and side panels off
Pulled all wiring out to check every connection taped up where needed
and put wires back in tidy
put battery on again after another charge And I have spark to all pugs and leads
Tank back on and she started on the button
I don't know if this is a good thing or bad
As this problem may not have gone and may leave me stranded again
98 zx9r
The last post was made 13 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 130.92 Kb
