| neiloggy1 |
 neiloggy1 Renault 5 Driver
 Posted: 15:22 - 15 May 2013 Post subject: suzuki bandit cut out at lights now started again |
hi all
bought a 99 600n bandit a few week ago.
its been running fine up until now
I have used the bike everyday for work and its never let me down.
on the way home yesterday at a set of lights it just cut out and has refused to start since.
I got the bike home last night in a van eventually.
I tried starting it for so long the battery went dead so I left the battery on charge overnight hoping to solve the problem today.
so I get home from work battery on everything works
bike turns over fine but will not start
things I have tried so far ...
petrol fresh and plenty in tank.
petrol getting through to carbs and plugs are wet.
air filter is fine.
no loose connections or shorting out.
also when I taken no 1 plug out and put against frame then turned over spark was weak then would get loud backfire(boooom)
so I cleaned plugs up put back in and it started for about 30 secs then died again.
iam guessing could need new plugs or coil packing in.
any other ideas as don't want to spend a fortune on plugs,leads,coil pack,cdi etc
need the bike to get to work thanks in advance. ____________________ 98 zx9r
| sickpup |
 sickpup Old Timer
| neiloggy1 |
| hondakawasaki |
 hondakawasaki Nova Slayer
 Posted: 15:42 - 15 May 2013 Post subject: |
get some new spark plugs  |
| neiloggy1 |
| Linux |
 Linux Nova Slayer
| neiloggy1 |
| P.addy |
 P.addy Red Rocket
 Posted: 16:46 - 15 May 2013 Post subject: |
9 quid. Just buy some online if you can't be bothered to wait  |
| neiloggy1 |
| duzzer |
 duzzer Borekit Bruiser
| Ariel Badger |
 Ariel Badger Super Spammer
| P.addy |
 P.addy Red Rocket
| neiloggy1 |
 Posted: 19:11 - 15 May 2013 Post subject: |
all connections cleaned up and dry
no loose wires or connections
all leads trimmed down 5mm
I have good spark from 1+4 at lead and plug end
not been able to test 2+3 as battery went dead again so quick charge and try 2+3 later
what I did notice when I taken tank off was that with fuel tap turned to on or reserve no fuel comes out
but trickles out when switched to prime
there is plenty of fuel in as fuel level is far higher than both filters inside the tank
hope that makes sense
also when I try to start the bike on prime you just get a loud BANG  ____________________ 98 zx9r |
| Poseidon |
 Poseidon World Chat Champion
| Drake |
 Drake World Chat Champion
 Posted: 19:44 - 15 May 2013 Post subject: |
£27, they saw you coming and got the lube out ready... ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| neiloggy1 |
| Pete. |
 Pete. Super Spammer
 Posted: 20:57 - 15 May 2013 Post subject: |
If you can't afford CR9EK, just use CR9E. My bandit runs fine on them, all they do is spark..
Do you have an alarm fitted? ____________________ a.k.a 'Geri'
| neiloggy1 |
| Pete. |
 Pete. Super Spammer
 Posted: 22:21 - 15 May 2013 Post subject: |
Yes it's normal. PRIME by-passes the vacuum tap.
What alarm do you have fitted? ____________________ a.k.a 'Geri'
| duzzer |
| neiloggy1 |
| duzzer |
| jjdugen |
 jjdugen World Chat Champion
| neiloggy1 |
| neiloggy1 |
The last post was made 13 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
